Welcome to the North American Subaru Impreza Owners Club Wednesday January 17, 2018
Old 01-29-2006, 11:20 PM   #1
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
Default Need wiring help
alright, so ive about had it with my swap, ive mostly whined on legacy central, but havent got anywhere over there, so here it is.
first of all, its an EJ22T in a 1995 impreza. we did a hack job of wiring by modifying the 1.8 harness to plug into the EJ22t, but all of the wires get to the ECU correctly. please dont tell me i shouldnt have wired it that way, because i already know
so it "starts" but it idles at 2000-3000, and is beyond lean, i can hear/smell how terribly lean it is. things i could read from the ECU that are alarming are the 44* of timing advance
MAF and injector pulse width SEEM to be in spec, the 1.8 fuel pump is in there (ill change it soon) but that shouldnt effect fuel pressure at idle correct?
here the BIGGEST problem, my TPS signal is backwards... it is supposed to go from 4.7V at fully closed to 1.6V fully open, when properly wired it goes from 5.10 to 5.02 when i measure the resistance it goes from 3ohm-12ohm gradually. both TPS's ive tried do exactly the same thing. when i was idling it the TPS was unplugged.
big issue #2- the 02 sensor. can i use my imprezas sensor with the legacy ecu? they are both 3 wire but they look a little different.
can anyone tell me what the wires are on the sensors that have 1 black and 2 white wires? is black signal, and the white ones are power and ground? are the white ones interchangeable..?
sorry to blab on, but these are my problems right now, and i cant seem to figure it out myself! thanks for any help.
Natoe is offline   Reply With Quote
Old 02-01-2006, 05:27 AM   #2
Natoe
Member#: 90353
nobody...? anything?
ok a cliff notes version:
answer the fuel pump question- even though it doesnt make sense to me, would having a 1.8L fuel pump with the 2.2T ECU make it run rich at idle?
and are the 02 sensors the same?
thanks
Old 02-01-2006, 12:10 PM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
No...
thanks
I can't say for sure, but I doubt it. Turbo o2s almost always read over seperat voltages.
jamesfacts is offline   Reply With Quote
Old 02-01-2006, 03:08 PM   #4
Natoe
Member#: 90353
yeah i figured it wouldnt...
the O2 sensor looks a little different i just thought that they all give 1v signal's...
i tapped power and ground to random wires in the engine bay, and left the signal shielded.
ok, so any ideas about the TPS!?
Old 02-01-2006, 03:38 PM   #5
azn2nr
Member#: 35276
are you using teh legacy throttle
azn2nr is offline   Reply With Quote
Old 02-01-2006, 03:47 PM   #6
Natoe
Member#: 90353
yup... legacy TB and TPS, have tried 2 different TPS's, both did the same
Old 02-01-2006, 04:58 PM   #7
azn2nr
Member#: 35276
thats really weird. dont know what to tell ya man
Old 02-01-2006, 05:28 PM   #8
Natoe
Member#: 90353
it makes sense that i might just have ground and signal switched... BUT ive checked it a million times...
weird thing with the legacy electrical system is that out of the ECU the ground wire is WHITE and signal is BLACK, then it goes through the conjuction and they change colors........... i have a diagram somewhere where it shows this. unless i read it wrong, and josh said the same thing i believe. soooooooooo maybe ill just try swapping them back again. i know the power and idle switch are correct. i even sheilded the whole wire from ecu to sensor...
greddy gauges - need wiring help hybrid gti 2 Electrical & Lighting 7 09-13-2005 06:27 AM
Need wiring help with '05 Outback/Legacy smosh Car Audio, Video & Security 0 04-23-2005 10:34 AM
Need Wiring help! Infest Car Audio, Video & Security 8 12-03-2004 01:27 PM
Need wiring help, ASAP Greg Sharpe General Forum Archive 0 02-17-2001 08:25 AM
Field SFC, need wiring help - someone w/ owners manual Tony Technical Forum Archive 2 08-02-2000 04:06 PM
