01-30-2007, 06:04 PM | #1 |
Member#: 128760
RMIC
Vehicle:2017 STI Silver |
Blouch Dominator III VS. FR Red
If you have either one of these products please respond. I want to get feedback from those that use these turbos first hand. I would also like to hear from shops that sell them. Include WHP, WTQ and boost. I am looking for the strongest bolt on out there for my 06 WRX TR. Please include Dyno graphs if you have them.
01-30-2007, 06:06 PM | #2 |
Member#: 1170
BAIC
Vehicle:2005 STi White |
I know the Blouch comes in 2.4 or 3" inlet size.
01-30-2007, 07:08 PM | #3 |
Member#: 106807
Vehicle:---> 2011 EVO X |
The Dominator III is a great bolt on turbo.
I made 441whp/427wtq (w/ meth) with this turbo and supporting mods. There is still more power left in my car once I open the flow up a little better (headers,turbo inlet, better boost control, port tgvs, etc) But that said, the car is still a monster. |
01-30-2007, 07:11 PM | #4 | |
Member#: 38016
SCIC
Vehicle:2017 STI 2016 F-150 XLT |
01-30-2007, 07:23 PM | #5 |
Member#: 106807
It's still the stock inlet haha
But It's only been a week since the tune... Got some new parts on order (Inlet included) Hope to see some extra power on the re-tune... |
01-30-2007, 07:30 PM | #6 |
Member#: 131460
Vehicle:2005 STI SR55'd w/ 44mm ewg! |
01-30-2007, 07:32 PM | #7 |
Member#: 38016
SCIC
To the OP I would go with an 8cm FP green. FP has really proven itself over the years. FP turbos always make power and have a good rep. Either way both turbos are good but my vote is the red.
01-30-2007, 07:41 PM | #8 |
Member#: 106807
01-30-2007, 08:18 PM | #9 |
Member#: 110648
PRSIC
Vehicle:2005 Hydramist 35R82 93oct 479whp 456tq |
FP Red, 8cm, check their new TD06H exhaust wheel with 11 blades (1 less) for more flow and angled vanes I guess for better spool.
01-30-2007, 09:40 PM | #10 |
Member#: 94494
NWIC
Vehicle:2005 Element 92x Black |
I vote GT52, but I like faster spool.
FP Red w/ 8cm is a nice option, but I wouldn't get one unless I was building my engine. |
01-30-2007, 10:02 PM | #11 |
Member#: 35742
W. Canada
Vehicle:2002 PPG + FPGreen Silver |
this is somewhat apples and oranges. The DomIII uses the same compressor wheel as a GT30R(52lbs) while the Red uses the same compressor wheel as a GT35R(65lbs).
A more direct comparison to the DomIII would be the GT52 from Element Tuning, or AVO500. |
01-30-2007, 11:24 PM | #12 |
Member#: 128760
RMIC
Thanks for all the posts and info from everyone. Back to this comment, since this is the case, which one of those would you recommend for a bolt on? Or would you recommend the FR Red over the Dom III since it will flow more? Thanks again to everyone and the info!!!
01-31-2007, 12:11 AM | #13 |
Member#: 115223
Vehicle:2005 Subaru STI silver |
Red .... w/ the red 8cm and meth people are putting down 506 awhp. I have a 7cm red (going to a 8cm). w/ the 7cm I put down 360 awhp on 20 psi and 93 oct. A 35r w/ a .63 a/r put down 365 awhp on 20 psi and 93 oct on the same dyno. The tuner told me that if I went w/ 100 oct I would be putting down close to 460. I am going w/ meth soon I am hoping/ expecting 475-500 at the wheels.
There is no tgv problems you could just unplug them if it is a problem. If you go that way you can PM me if you want more info. On 93 oct you don't need to build your engine w/ a red. If you go w/ meth you may need to but chances are not. I was worried about it also, this is my post on it. http://forums.nasioc.com/forums/show....php?t=1166339 |
01-31-2007, 12:15 AM | #14 |
Member#: 53756
Vehicle:2002 WRX WRB |
red ftw! =)
I think it will put out more power and also, I am selling one............ |
01-31-2007, 12:54 AM | #15 |
Member#: 122279
Vehicle:2004 STi Blue |
Go with the red!!! I have a red with the 7cm hotside and internal wastegate and I am making 503whp on race gas. I am trying to figure out what I would make with the 8cm hotside.
01-31-2007, 10:22 AM | #16 |
Member#: 12682
Thats insane numbers for a bolt on turbo let alone direct bolt on...can we say rotated mount territory..
01-31-2007, 12:16 PM | #17 |
Member#: 43449
Vehicle:2017 Colorado ZR2 Cajun Red |
yeah, the video is of my WRB STi. That is actually the very first Dominator III, being installed by the guys at Blouch Turbo. I would say go with the Dominator III. You can get 2.4" or 3" inlet, 7cm2 or 8cm2 hotside, and you can do internal or external WG. You will get faster spool with the DOm.
01-31-2007, 02:40 PM | #18 | |
Member#: 128760
RMIC
01-31-2007, 02:41 PM | #19 |
Member#: 128760
RMIC
01-31-2007, 02:58 PM | #20 |
Member#: 114096
01-31-2007, 07:37 PM | #21 |
Member#: 115223
w/ the 7cm red IWG I have had no creep problems at all in any gear. I did in the begining but that was do to the turbo getting un-metered air coming in i.e. vac leak. I havn't heard of anyone having creep problems w/ the reds. It doesn't mean that they aren't out there but I just have never come across one.
01-31-2007, 09:15 PM | #22 | |
Member#: 128760
RMIC
01-31-2007, 09:42 PM | #23 |
Member#: 128760
RMIC
It seems like people are getting similar HP levels out of the FR Red and Dom III, that seems strange since the Red has a 65 lbs compressor wheel and the Dom III has a 52 lbs compressor wheel. Does anyone know why this is the case?
01-31-2007, 11:08 PM | #24 |
Member#: 115223
it really depends on the dyno you are on, you can't / shouldn't compare dyno's. I would like to know what the dom III, a stock STI, and a 35r w/ .xx a/r put down on the same dyno. That will really tell you quite a bit more. Or at least a dom III vs. a 35r .xx a/r. Only because I know what the red 7cm puts down vs. a 35r .63. The dom III seems to be in the ballpark give or take of the FPgreen IMO.
01-31-2007, 11:43 PM | #25 | |
Member#: 128760
RMIC
I just want to get the strongest turbo for the stock location that I can. I like the ball bearing set up of the Dom III and I'm not sure if I would want to trade full boost at 3800 RPM's for what seems to be just a little more power on the top. Thanks for the input!! |
'05 Agile Tuned STi/Blouch Dominator III/430whp 388ftlbs | impreza_punk | Proven Power Bragging | 25 | 12-25-2008 04:51 AM |
Element GT52 vs. Blouch Dominator III | azn_ryder02 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 19 | 09-04-2008 02:59 AM |
Blouch Dominator III vs Deadbolt SZ55 | Special | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 03-20-2008 11:32 AM |
Agile Auto tuned Blouch Dominator III | WOR440 | Proven Power Bragging | 85 | 03-22-2007 06:50 PM |
Blouch Dominator III?? | kyleblix | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 26 | 01-14-2007 05:50 PM |
