Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 05-14-2002, 05:42 PM   #1
NotAnRS
Member#: 1004
2002 Forester L
Scratch-n-Dent Blue
Question VERY intermittent no start problem
After complaining that it happened twice, my wife was able to laugh at me when the '96 2.2 refused to start the other day.
Starter turns over fine.
Engine does not try to fire whatsoever.
Doesn't seem to matter if it's hot or cold.
Engine will eventually start normally after varying durations, no smoke or rich smell.
Joyous check engine light will gleefully shine, but eventually fix itself over time.
My gut feeling is it's electrical. Is anything more trouble prone on these? Crank sensor? Ignition amplifier? Any Suby techs hanging around?
NotAnRS is offline   Reply With Quote
Old 05-14-2002, 06:28 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
if you could get the code pulled, that would help alot.
it could be a multitude of things.
Jay
Old 05-14-2002, 06:37 PM   #3
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Battery perhaps? Does the starter sound like it's really "working hard" to kick the motor over?
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 05-14-2002, 07:29 PM   #4
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
I don't believe that would flip a cel though....I could be wrong but it didnt on mine.
Buster
EvasionOfTruth is offline   Reply With Quote
Old 05-15-2002, 12:07 AM   #5
quynce
Member#: 15409
I had this problem on my '92 Legacy less the CEL. Starter sounded normal, it just wouldn't turn over. A friend of mine had a similar problem in his Integra and it turned out to be a bad relay. I never got mine fixed, plus, like yours, it was very intermittent; maybe 5 times over the year I owned it, and it always eventually started.
josh
quynce is offline   Reply With Quote
Old 05-15-2002, 07:22 AM   #6
NotAnRS
Member#: 1004
2002 Forester L
Scratch-n-Dent Blue
Arrow
It's not the battery, as prolonged cranking when it won't start doesn't drain it any.
Pulling the code would be nice, but by the time I could get the car to the dealer the light will be off again. Plus, I don't believe in CEL's.
My Ranger had stored codes and a CEL and my dealer still couldn't diagnose it. All it took was me, a shop manual, and staring at the various systems for awhile. The codes aren't always accurate for what the problem is; they may only point to a system that was affected by the failure.
Old 05-15-2002, 08:39 AM   #7
Blindeye_03
Member#: 4418
2019 CTR
my buddies car at work (honda accord) had a prob like this. You could hear the starter turning like a mofo, but nothing else & after another try or another 2 tries it would start. He had a bad battery. The battery is relatively cheap to get tested at a auto place.
-justin
Blindeye_03 is offline   Reply With Quote
Intermittent no start condition, 2002 WRX, 95k miles austinramage Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-03-2009 06:13 PM
Help! another no-starting problem!! ltjake22 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-10-2007 05:52 PM
Intermittent no-start on a 95 L bigboss Normally Aspirated Powertrain 0 09-23-2006 07:09 PM
Random no-start problem wrxtremest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-03-2006 09:04 AM
weird intermittant no-start gtx1990 Normally Aspirated Powertrain 6 07-25-2002 12:30 PM
