09-08-2003, 03:52 AM | #1 |
Member#: 15055
International
Vehicle:2006 S204 CGM |
Ej 257 2.5 Sti
Im trying to find some 'non biased' info on the above stated engine.....i.e. factory mechanicals (forged pistons? rods, crank, injectors, c/r etc etc)
Also what sort of reliable flywheel horsepower is being extracted from this and whats required to do so whilst retaining standard internals (what turbo is being used, injectors, ecu etc) Reason for so much info is im looking at converting my GC8 wrx and being that the EJ257 is US spec only.....posting here seemed the most logical thing to do. Any info and links would be most appreciated, Thank you Jme www.perth-wrx.com
09-08-2003, 04:17 AM | #2 |
Member#: 18709
if i'm not mistaken it has a semi-closed engine block, forged crank and rods, and hyper-cast pistons. someone correct me if i'm wrong.
09-08-2003, 11:06 AM | #3 | |
Member#: 24463
Vehicle:2003 Chevy S10 91 Hunduh Civic BASE |
09-08-2003, 05:09 PM | #4 | |
Member#: 9794
TXIC
Vehicle:02 2.5LWRX-Retired 335i w/twins |
09-08-2003, 05:46 PM | #5 |
Member#: 7321
NESIC
Vehicle:.... 122 IggPoints Work... ahhh... so tired. |
well theres this thread
http://forums.nasioc.com/forums/show...hreadid=409100 I dont think its bias... If you want more then 400hp then the ej207 or the ej22t with internals would be worth some thought. From what ive heard the ej257 deck is the weekest part. How much do you want to spend? You could always get a block from one of the tuners... i speed, cobb, or axis. |
2.5 sti motor, 2.5 wrx motor | olsen726 | General Community | 19 | 09-24-2008 02:31 PM |
2.5 STI vs. 2.5 Na block | masterpickle | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 15 | 01-19-2008 02:21 AM |
2.5 wrx and 2.5 STI | 2wheeldrive | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 46 | 10-12-2007 10:10 AM |
2.5 STI block v 2.5 na | blacktalon606 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 9 | 04-20-2006 11:54 AM |
2.5 STi rods and 2.5 NA rods. Way to tell? | ebeck | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 06-21-2005 02:29 AM |
