Brakes & Suspension Forum sponsored by The Tire Rack |
08-25-2016, 10:33 AM | #151 |
Member#: 353938
Vehicle:2007 STI WRB 18x8.75 +35 225/40 |
Not sure if this is the right place to post, but any suggestions here? Rear end links contact lateral arm which enlarged the hole.
I should probably try to find shorter end links. But still need to deal with this big hole. *edit - weld in a captive nut
09-29-2016, 11:15 PM | #152 |
Member#: 257757
Does anyone have seat of pants difference after installing the swaybar mount point reinforcement mod mentioned at end of first post?
Thanks |
10-03-2016, 03:37 PM | #153 | |
Member#: 201606
Vehicle:2013 STi Hatch PBP |
Thanks, Geoff |
10-31-2016, 03:29 PM | #154 | |
Member#: 214093
12-29-2016, 02:13 PM | #155 |
Member#: 418558
Vehicle:2015 WRX |
Looking for feedback on the 15 WRX Eibach F&R sway kit. I am lowered on their springs w aftermarket LCA's. I guess if I go this route I should replace both F&R endlinks. If so I may just go rear to start but unsure which one, decent deal on the Whiteline 24mm rear kit. Comments?!
12-29-2016, 02:24 PM | #156 | |
Member#: 428919
Vehicle:2016 WRX LBP |
I have both front and rear set to full stiff. It's a very good setup that gives the car a very neutral feel around corners. You can also set the front to soft and rear to stiff if you want more of an oversteer feel but I like the balanced feel of having them both on full stiff. Here's my video on them: |
12-29-2016, 02:34 PM | #157 | |
Member#: 201606
The 24mm bar you have from the factory is actually very stiff. I would just replace the D bushings on it as well as the front end links. This will help the bar react just as quickly as an after-market bar will on the rear of the car. In the back I would replace the sway bar as well as the end links and add a brace kit. What size to go with depends on your situation, but typically either 22mm adjustable or 24mm adjustable is what you want. Everybody is a little bit different with this though, so if you'd like to give me a call or shoot me a PM I would be happy to talk with you about this and give you some suggestions. Thanks, Geoff |
12-30-2016, 04:49 PM | #158 |
Member#: 201606
duplicate
02-23-2017, 01:16 AM | #159 |
Member#: 463453
Vehicle:2002 Impreza wrx World rally blue |
For sure!!
03-12-2017, 09:27 PM | #160 |
Member#: 463614
Vehicle:2007 wrx black |
one more
05-19-2017, 02:30 AM | #161 | |
Member#: 467938
Vehicle:2011 STi Grey |
2011 STi - sway bar plus coilover question
The car now is stock with the exception of an exhaust (purely for noise not performance - it came with the car) My question relates to the OP info on sway bars. I would like to increase mine and like the comment quoted above as this will be my daily and I dont plan on track days. So this configuration seems good to me but I wanted to know if it would still be good if I planned on adding coilovers and dropping the height a little. I only ask because the OP next option (option 3 i think - specific to 02-07m models only) made a comment about the addition of coilovers to that configuration. So I just thought I would ask. The coliovers are likely to BC Racing BR. Appreciate any comments. |
05-30-2017, 12:09 PM | #162 |
Member#: 222786
I am curious about upgrading the front swaybar on 2008 non-WRX 5 door Impreza. I just put Eibach & Koni around, and I see Eibach has a set of F/R sways for WRX but they only list the rear for the non-WRX.
Wouldn't the WRX front sway be the same basic shape as the non-WRX? It is tough getting information on non-WRX chassis. Thank you! |
06-08-2017, 08:33 AM | #163 |
Member#: 443357
Some good and helpful info here. I was gonna buy my buddy's eibach full kit for my 16 sti but between immediately seeing the front specs and then coming in here to read up, think I'm gonna pass. Suspension wise I plan on only doing the end links, bushings, rear sway, and spec r springs.
06-08-2017, 10:06 AM | #164 | |
Member#: 265783
RMIC
Vehicle:2017 Forester XT Niner ROS 9 |
the only N/A specific front bar i am aware of: https://www.rallysportdirect.com/fit...2mm-adjustable matching rear options (that also include D brackets and new endlinks): https://www.rallysportdirect.com/fit...2mm-adjustable https://www.rallysportdirect.com/fit...0mm-adjustable any 08+ rear sway will work for you, including the 2015+ stuff. I have a 20mm 2015 STi rear sway on my narrow body WRX. fits perfectly and cost $100 bucks from the dealer. I run a 19mm 2010-2014 STi rear sway on my wife's 2012 impreza sport. also fits perfectly. |
06-08-2017, 04:32 PM | #165 |
Member#: 161594
Vehicle:1972 Datsun 240Z V8 Can-am White |
Cobb Endlinks
Just a heads up. I have Cobb bars front and rear on my '07 STI. I had to ditch the rear Cobb end links for steel Moog components. The Cobb pieces were rubbing on the transverse link causing a clunk every time I hit a bump with one or the other wheel. Note that this is the solid bar Al links with spherical ends.
If you install the Moog links, pay attention to the clearance on the attachment studs. They have to go a certain direction to keep from rubbing other suspension components. However, they do work and they appear to be just as strong as OE. |
06-12-2017, 07:37 PM | #166 |
Member#: 450437
Vehicle:2013 Subaru WRX Black |
Hello hi,
I have a 2013 WRX and I just ordered 24mm front and rear white line swaybars with kartboy endlinks. I'm worried about my front endlinks since I didn't get a spacer for the front. Do I absolutely need them to function properly? Also I have 255/35/18 Bridgestone potenza RE-71R tires with BC coilovers with 6k front and rear swift springs. Will this setup be ok for circuit racing and spirited driving? What setting should I put the swaybars at and the coilovers are 30 way adjustable right now their at 15 front and rear should I change them and if so to what setting. I also have a front strut bar. Thank you very much. |
08-11-2017, 02:51 PM | #167 |
Member#: 317045
Vehicle:2012 WRX Hatchback SWP |
broken whiteline rear ball link endlink
Anyone here encounter a broken rear ball link endlink?
Made by Whiteline and sold by Cygnus Performance (although I don't think Geoff sells these rear ball links anymore). I bought them back in Dec, 2012. Found out today that the rear passenger side endlink was sheared clean through. The front and rear anti-sway bars are Whiteline adjustable, (22mm/22mm), front and rear are both 22mm. Is this a warranty issue that Whiteline can remedy? Geoff - if you are online - is there something you can do? What would be the best replacement endlinks? (mostly street, some track) Last edited by texascanuck; 08-11-2017 at 02:53 PM. Reason: Add photos |
08-14-2017, 11:38 PM | #168 | |
Member#: 201606
Thanks, Geoff |
08-15-2017, 09:13 AM | #169 |
Member#: 317045
Geoff - thanks for your ongoing advice and help - I do appreciate it.
Best, Keith |
09-15-2017, 12:00 AM | #170 |
Member#: 363394
Vehicle:2003 WRX |
If i use a different brand of endlinks, would that be an issue? For example, Kartboy in the front and Whiteline for rear.
Thanks! |
09-15-2017, 01:39 AM | #171 |
Member#: 337743
BAIC
Vehicle:2002 WRX Wagon WRC Blue |
Mixing brands is irrelevant for performance. There are different types of links that could produce really different responses, but the name on the box shouldn't.
10-11-2017, 09:25 PM | #172 |
Member#: 340078
Vehicle:2015 Impreza 2.0I White |
I’ve got a 2015 Impreza base sedan so there is no RSB and I’d like to add one. I’ve read through all the sticky posts and can’t quite nail this down.
What size is the OE front and rear sway bars for the 2015 Impreza base sedan? Second, what other vehicles can I steal an RSB and links from to fit my car? From what I’ve read, the WRX and STI are, to a degree, interchangeable. But what about the base Impreza? Can I use an OE 2015 WRX bar on my car? Subaru parts suggests not. Realistically, if the front is a 22mm then I’d go with a 20mm rear but I’m also weighing the cost/benefits. Especially since I have NO RSB at the moment. Car is a strict daily driver that will never see a track. It will likely just see spirited driving around the roads and highways in Pennsylvania with moderate to low snow and somewhat crap roads. |
12-17-2017, 03:10 PM | #173 |
Member#: 479326
Vehicle:2005 STI Silver |
Front adjustable Sway setting
I just installed an adjustable front sway (27mm Whiteline) on a 2005 STI. I'm looking for some guidance from others which setting best suits the car for track driving.
03-24-2018, 06:57 PM | #174 |
Member#: 425051
Vehicle:2016 HyperBlue STi |
10-16-2018, 10:59 PM | #175 |
Member#: 283138
SWIC
Vehicle:2011 WRX Rally Blue |
2018 STI Swaybars for autocross
I am getting more into autocross and eventually want to try a track day. This is also my daily driver. I have HKS Hypermax IV GT coilovers on the car already and am looking at adding stiffer sway bars next. I am looking towards doing option #4 with adjustable bars and end links which will kind of let me go stiffer to make option #6 based on your article. I am on street tires as well don’t think I will run slicks. Do you have any recommendations on one or the other for a 2018 STI?
4) 22mm front & rear 08+ or 24mm front & rear 02-07 This is my personal choice for the street and street tire autocross. The equal sized rear bar gives the car a more neutral feel. It really does a lot to counteract the car's tendency to understeer. I use this combination on my daily driver and with adjustable swaybars it can be set up to perform well on the street, track and autocross course. 6) 24mm front / 22mm rear 08+ or 27mm front / 24mm rear 02-07 This is another popular combination... Probably just as popular as combination #4. The stiffer front bar will give the car an improved turn in feel over combination #4. I find that this combination doesn't feel as neutral on street tires as combination #4. To me it feels like it gives you a flatter, better turn in feel at the expense of over all grip. If you are on a smooth track with grippy tires this is a different story. This combo is perfect for someone who does track days or time attacks. It is also the preference of many for daily driving. It does give more noticeably better handling than combo #4 for daily driving. It just doesn't suite my personal driving style as well as #4 does. National autocross champions have also confirmed that a bar this large in street tire autocross tends to make the car understeer. The fastest street tire autocross STis in the country for the past few years have used very soft front bars in combination with very stiff coilovers. Thanks, Brandon |
