07-29-2002, 02:04 AM | #1 |
Member#: 8350
Vehicle:2002 WRX Blue |
Help: Cant figuire out how to install headlight blub and harness back into headlight
i just cant get it to click... is there any special trick?> what am i doing wrong?
help gypsum2 <-- dummy
07-29-2002, 11:56 AM | #2 |
Member#: 4597
TXIC
Vehicle:2011 Mitsu Outlander Sport (Ex-Suby owner X3) |
you arent doing anything wrong...unlike the old schools that require about 3 secs to change bulbs...the WRX is bizatch......after removing the headlight housings, and the bulbs...the replacement is pretty confusing, it doesnt neccessarily go in reverse....the bulbs has got "markers" oin the sides to guide you ...first slide in the guides to the corresponding wedges on the housing, make sure its a tight fit....then twist the clip ring to a snug fit....then replace the rubber boot, then replug the bulbs...
07-29-2002, 12:25 PM | #3 |
Member#: 22043
its easy to do the driver side light but the pasenger side is tricky, just take the two blots off the airbox in the front and it should give you more room to work with. when i replaced mt bulbs, all u do is turn the cap that surrounds the harness, then press down on the clip and pull, it should come right off. good luck!
Just bough Eclipse Navi and can't figure out how to install speed sensor | JASWRX | Car Audio, Video & Security | 3 | 09-29-2010 03:24 PM |
I can't figure out how to remove my viscous coupling | mk2jettavr6 | Transmission (AT/MT) & Driveline | 3 | 01-15-2008 09:58 AM |
Can't figure out how to install clutch clips | noitseuq | Transmission (AT/MT) & Driveline | 1 | 02-25-2007 01:50 PM |
Can't figure out how to calibrate tps ?? | L80Killa87 | UTEC | 2 | 01-02-2007 08:12 AM |
I Can't Figure Out How To....(n00b ? inside) | binky | Off-Topic | 19 | 08-07-2004 06:01 PM |
