07-21-2001, 06:23 AM | #1 |
Member#: 4043
Vehicle:JDM FREEK 2001 GC8 R.I.P. 2004 STI |
How to remove headlights on the 97-01 RS?
Is it hard to remove the headlights? Do I have to remove front bumper too? Any pics would be very helpful. Thanks
07-21-2001, 09:59 AM | #2 |
Member#: 2213
NESIC
Vehicle:1995 Impreza w/EJ257 Brilliant Red |
Easy
It's really easy. First lift hood. Then unscrew corner lamps from headlamps. Remove corner lamps by pushing them forward really hard. then look at grill, there will be two holes on either end of it. Push a flat head screwdriver down into the holes and wiggle it till your able to get the grill to unclip by bulling it backward and then up to remove in full. Now remove the wiring harness from the back of each unit. There will be two 10mm? bolts on the side of the headlamp where the corner lamp used to be. Make sure you look and remove the two going to the lamp and not the ones holding the fender on, it should be obvious. Do this for both lamps. Then go to the other end of the lamp where the grill was and you will see two more 10mm? bolts remove them from both lamps and they should just come free. Hope this helps it's really quite easy.
Joshua Subaru Salesman |
07-21-2001, 10:55 AM | #3 |
Member#: 2236
Vehicle:2000 Audi S4 silver/rally dirt brown |
All the below images were stolen from the piaa fog light change over that I found in the mods section with a detailed setup by step text, (use the above thoug, it is accurate) here:http://www.i-club.com/mods/piaa_80_xt.htm
DUMB question: how to remove headlights on 06? | Must@ng | Electrical & Lighting | 2 | 01-03-2010 11:00 AM |
How to remove headlight reflector on 2008+? | moorex | Interior & Exterior Modification | 2 | 12-10-2009 11:11 PM |
How to remove yellowing on the paint from tire shine???? | Subydude81 | Interior & Exterior Modification | 9 | 10-20-2007 09:50 PM |
Any tips to remove headlights on the XT? | BrysImpreza | Forester Forum | 4 | 10-16-2003 01:41 PM |
how to remove headlights | juztin180 | Newbies & FAQs | 3 | 01-06-2003 01:48 PM |
