Welcome to the North American Subaru Impreza Owners Club Wednesday December 2, 2020
Old 10-07-2014, 04:34 PM   #1
andysrt
Member#: 306130
06 foz xt
Default AVCS questions and missfires
Is there supposed to be a difference in degrees between left and right on start up? At idle avcs in left reads 22 to 25 degrees and avcs in right reads 7 degrees. My car idles rough on start up and throws missfire codes on all 4 cylinders along with PFFE . No issue's otherwise. The car is definitely not missfiring all the time. I did change from a dual mass flywheel to a singlemass stock flywheel. that was close to 30k miles ago and the codes didn't start until a few weeks ago. Any ideas? Its a 06 forester xt by the way.
Sent from my LG-LS995 using NASIOC mobile app
andysrt is offline   Reply With Quote
Old 10-07-2014, 04:45 PM   #2
Badler
Member#: 133597
Timing belt probably jumped a tooth or two.
Badler is offline   Reply With Quote
Old 10-08-2014, 10:36 AM   #3
elandman
Member#: 346897
2006 Foz XT
AVCS should match at all times within a degree or two
elandman is offline   Reply With Quote
Old 10-08-2014, 12:17 PM   #4
andysrt
Member#: 306130
06 foz xt
I'm going to do a log tonight on the way home from work. Any specific thing i should log other than avcs left and right and the ocv.
Old 10-08-2014, 07:10 PM   #5
andysrt
Member#: 306130
06 foz xt
Ok i data logged on the way home one side stayed between 23-25 the other was between 7 and 9 no matter how much throttle was applied. Whats the next step or how do i check the avcs and ocv?
Old 09-06-2020, 11:42 PM   #6
iRishman514
Member#: 378501
2011 STI Hatch
Plasma Blue Pearl
Bump this. I have the same issue. Anyone know?
iRishman514 is offline   Reply With Quote
Old 09-11-2020, 12:55 PM   #7
subaru_gc8
Member#: 29292
2004 WRX wagon
I had that problem with my jdm ecu, we changed the pulleys and it still persisted, come to find out it was the ecu that had the problem.. I would suggest if you can get another ecu first as it is alot easier to change than the pulley
Old 09-13-2020, 12:21 AM   #8
iRishman514
Member#: 378501
2011 STI Hatch
Plasma Blue Pearl
Thanks for the help. The ecu swap on my car is quite challenging with it needing to flash for the immobilizer.
Today I re-timed the car, tapped the AVCS gears with a rubber mallet, did an oil and filter change with disconnecting the battery.
Didnít really notice any slipped timing belt, though the drivers Intake cam may have been off by one tooth.
Drove the car for about 5 min and voila, AVCS on both sides went down to zero at idle and increased with the throttle.
Old 09-13-2020, 02:21 AM   #9
subaru_gc8
Member#: 29292
2004 WRX wagon
Didn***8217;t really notice any slipped timing belt, though the drivers Intake cam may have been off by one tooth.
nice glad you got it fixed, but I would change which ever one is sticking
Old 09-13-2020, 02:16 PM   #10
iRishman514
Member#: 378501
2011 STI Hatch
Plasma Blue Pearl
They both were stuck.
Old 09-13-2020, 05:48 PM   #11
subaru_gc8
Member#: 29292
2004 WRX wagon
so one was stuck on high and one on low?
Old 09-14-2020, 02:10 AM   #12
iRishman514
Member#: 378501
2011 STI Hatch
Plasma Blue Pearl
Correct. Passenger stuck on 6ish and driver stuck on 25ish
