Welcome to the North American Subaru Impreza Owners Club Monday July 26, 2021
Old 09-13-2020, 08:02 PM   #1
JayBob
Member#: 490166
2004 STI
Default Transmission negative battery harness
Hello. Iíve got an 04 STI with a battery harness the I cannot figure out where to hook up the negative battery wire near my starter. I do not have the special tab that others have right above the starter. Any ideas where to connect this negative terminal?
JayBob is offline   Reply With Quote
Old 09-17-2020, 08:34 AM   #2
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
You are missing the right angle piece that bolts behind the top starter bolt that allows you to bolt the negative harness down.
Part number 22442AA021
Elbert Bass is offline   Reply With Quote
Old 09-18-2020, 12:38 AM   #3
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
Wow E. Bass
U nailed it
I just looked at my 05 and I have that R angled bracket mounted to the top center(right)
starter mount bolt
AliBenn is offline   Reply With Quote
Old 09-18-2020, 04:18 PM   #4
JayBob
Member#: 490166
2004 STI
Awesome! Appreciate the help!
Old 09-18-2020, 08:23 PM   #5
Elbert Bass
Member#: 283429
You can leave it bolted to the ground wire and that way you don't loose it. Saves time too.
Old 09-18-2020, 08:27 PM   #6
Elbert Bass
Member#: 283429
Originally Posted by AliBenn View Post
Wow E. Bass
U nailed it
starter mount bolt
Subaru only has two starter bolts and/or nuts. Top one is always a bolt - bottom one can be a bolt or a stud with a nut. If it has the stud always remember to look for the hidden bell housing bolt hiding near that stud when pulling engine/transmission.
