Welcome to the North American Subaru Impreza Owners Club Wednesday November 25, 2020
Old 12-31-2018, 04:58 PM   #201
619in845
Member#: 479597
Originally Posted by CarmelValleyWRX View Post
m6x1. length probably wont matter a whole lot because they thread into places you don't see. i would say 15mm long would be a good length to cover all the bases to hold fenders and brackets in the engine bay. i usually buy a box of 100 of the longest i need for a project and trim a few if needed.
Thanks very much for your post! Happy New Year!
619in845 is offline   Reply With Quote
Old 03-01-2019, 12:49 AM   #202
Mac0955
Member#: 498429
Default Starter Stud
Bottom Starter Stud Size or Nut size that fits it on 2.5?
Mac0955 is offline   Reply With Quote
Old 04-15-2019, 04:08 PM   #203
ceniack
Member#: 300454
Need size for this flange bolt
https://parts.subaru.com/p/Subaru_20...010406160.html
Basically it is 0104S*B in the diagram here:
https://parts.subaru.com/a/Subaru_20...12-050-16.html
I dropped mine and I think it came to rest on the steering rack crossmember somewhere but I can't put eyes on it to use a grabber so I need a new one.
ceniack is offline   Reply With Quote
Old 03-31-2020, 09:25 PM   #204
blobeye_mia
Member#: 507789
2004 WRX
Default TPS sensor bolt size
Anyone happen to know what’s the bolt size is for the throttle position sensor on an 04 wrx?
Lost a screw to the engine bay
blobeye_mia is offline   Reply With Quote
Old 10-20-2020, 11:36 PM   #205
Shik
Member#: 132
05 WRX, 15 WRX 6mt
'02 WRX- ShinjiTuned
Looking for this bolt but brand new. It is one of the bolts that holds the top of the coolant expansion tank to the tank itself. Not available from Subaru(or Subaru of Japan). Not sure if this bolt is used anywhere else on the car, but I googled the size(m6x1.0x 60mm) as well as the "9B" or 9.8 maybe? No luck anywhere.
I just refinished a Spec C coolant tank and would like the exact brand new bolts to go along with it. Cleaning them up on a wire wheel brush will work, but if I could find brand new ones, I'd go with those.
It seems restorers of Japanese motorcycles run into hard-to-find bolts with certain markings on them that may be specific to certain manufacturers as well.
Anyone have a part number for these "9B" bolts or know a source for Japanese bolts?
Shik is offline   Reply With Quote
Old 10-21-2020, 01:30 AM   #206
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Hi Shik,
My guess is that's a metric grade 9.8 flange bolt (because it has a flange under the hex head - the flange distributes load).
Metric grade 9.8 is a real thing, but they are pretty hard to source in the US from what I can tell with 8.8 and 10.9 being far easier to get.
If you're looking for excruciating exactness, finding those EXACT 9.8 ones will be tricky. You should be able to easily find 8.8 ones and for the purpose they serve even 8.8 is overkill. An 8.8 grade is roughly equivalent to an SAE Grade 5 which has a yield/break rating of 640psi.
jblaine is offline   Reply With Quote
Old 10-21-2020, 07:59 AM   #207
Shik
Member#: 132
05 WRX, 15 WRX 6mt
Originally Posted by jblaine View Post
Hi Shik,
Thanks jblaine for the info!
I was figuring it was a 9.8 grade, but I never saw one that didn't have the decimal, which led me to think maybe it's 9B or some other marking. I thought for sure before I started looking for them that it would be able to be had easily, as it's just a bolt. Definitely not the case.
Thanks again.
Old 10-22-2020, 06:05 PM   #208
subienoobie75
Member#: 513758
2004 impreza wrx
black
Originally Posted by tdxflex View Post
02 WRX
m6 x 1.0 ECU cover plate
m8 x 1.25 for the sway bar bolts (bushings and endlinks), strut tops, ram intake duct, the spare tire hold-down, plastic splash shield, and jacking plate
m10 x 1.25 for the exhaust bolts and a bunch of other stuff under the hood (green brackets for fuel rail, intake manifold, radiator mount)
m12 x 1.25 for EGT bung, lug nuts, and shift knob
m18 x 1.5 for o2 bung, the gallery threading on the block for oil pressure/temp sensors
m20 x 1.5 oil drain bolt
unsure of:
bov, intercooler mounts - I think are m8 x 1.25, either that or m10 x 1.25
brake caliper bleeder and clutch bleeder - not sure if it's m7 x 1.0, but they're both the same threading
rear seat mounting bolts look like they're m10 x 1.0
04 wrx front caliper bleeder screws m10 x 1.25"
bov bolts m12 x 1.25
I/C mounting bolts m12 x 1.25
these are what ive encountered.
subienoobie75 is offline   Reply With Quote
Old Yesterday, 06:28 AM   #209
2016
Member#: 442591
2016 WRX Limited
Default Air intake duct bolt size?
Anyone know the size of the 2 flange bolts that hold the bottom part of the air box on? The part number for the bolts is 901000149.
Site for reference:
https://www.subaruparts.com/oem-parts/subaru-center-shield-bolt-901000149
Thanks in advance!
2016 is offline   Reply With Quote
PCV line -> Intercooler bolts - Bolt Size? andrewt461 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-14-2011 05:40 PM
Bolt size for bolt on exh mani heat shields? djoye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-08-2007 02:24 PM
Oil Cooler Bolt Bolt Size??? Drink Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-11-2006 01:23 PM
Bolt size/thread pitch for seat bolts? anti.team Interior & Exterior Modification 1 09-30-2004 11:42 AM
Bolt size for airbox? blaster88 General Forum Archive 3 02-13-2001 04:49 PM
