Welcome to the North American Subaru Impreza Owners Club Tuesday November 24, 2020
Old 10-20-2020, 07:46 PM   #1
kayceeee
Member#: 421615
2014 impreza 5dr
white
Default Winter wheel fitment
Hi All,
Just looking for some insight on sizing winter steelies.
Currently got a 2014 impreza hatch running stock 205/50R17 on 17x7+55 wheels. Lowered on tein coilovers.
Looking on dropping size for some steelies for this winter. I've looked at the specs of OEM wheels for the different trims and it looks like the base came with 15x6+48 on 195/65R15 and the mid trim came with 16x6.5+55 on 205/55R16.
The two steelies options I was able to locate is 15x6+55 and 16x6.5+48. Will both work with my car and if they do, would i be better off dropping one size or two?
the 15's with General arctic 12s comes to around 550$ CAD and the 16's with same tires are around $700 CAD.
Thanks!!
kayceeee is offline   Reply With Quote
Old 10-22-2020, 04:58 PM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
16 x 6.5 +48 will work fine but whether or not you use 15s or 16s is ultimately up to you.
Either will work
Old 10-22-2020, 05:00 PM   #3
kayceeee
Member#: 421615
2014 impreza 5dr
white
Either will work
Thank you! i'm looking at getting 15's, do you happen to know if 15x6+55 will work? stock is 15x6+48
it shows up in a few tire sites but i just wanted to make sure before i order them online.
TIA!
Old 10-23-2020, 11:45 AM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Since 205 / 55 - 17 is your OEM tire size, the closest 15" tire you should use is
195 / 65 - 15
You are not get anything closer to your OEM sized tire. This will keep your odometer accurate so you won't be able to tel the difference.
You can put this on a 5.5" to 7.5" wide wheel, but picking a wheel width in the middle is usually best.
You could have found this out yourself by using the Tire Rack website to find tire sizes and wheel widths.
https://www.tirerack.com/tires/tires...omCompare1=yes
Old 10-23-2020, 07:31 PM   #5
kayceeee
Member#: 421615
2014 impreza 5dr
white
thank you!
