Welcome to the North American Subaru Impreza Owners Club Friday November 27, 2020
Old 08-11-2020, 02:42 PM   #26
Justanotherhonda
Member#: 199190
Originally Posted by alexmartynyuk View Post
Nice, that***8217;s the one with the gtx3584rs right? What part number for the callies rod? What size copper wire and protrusion height? Stepped deck?
That's the one! Thanks. I'm not sure on the part number of the rod or the protrusion height, I guess I could probably contact AR Fab to get that but I didn't receive any of that information with the car
It's been solid so far but with a rising amount of potassium and sodium in the oil sample. I'm hoping it was contamination from the CSF radiator w/ built in oil cooler I was running, as the levels haven't reached critical yet and the engine shows no other signs of issues. I just installed an external oil cooler to eliminate the radiator as the source. Fingers crossed
Justanotherhonda is offline   Reply With Quote
Old 08-11-2020, 03:33 PM   #27
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
Oh I see, I was under the impression you put it together yourself. Yeah hopefully not the bearings.
alexmartynyuk is offline   Reply With Quote
Old 10-24-2020, 02:51 AM   #28
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
Gonna bump this one. Anyone care to share what head gaskets you guys are using for your high hp sleeved builds? Care to share protrusion height of your orings and what kinda wire for the orings?
Old 11-13-2020, 12:21 PM   #29
boostaroo
Member#: 507615
Darton Sleeves @99.75 Bore
OEM EJ257 HG
Dead-Soft Pure Copper Wire O'Rings @0.028" > .012"x.024" deck groove.
Car made a little under 500whp
Just tore it down to rebuild after a dropped sleeve. I'm changing up the HG/O'Ring setup a bit this time though.
Darton Sleeves @99.75mm Bore
Tomei 1.2mm EJ25 Head Gasket
Soft-Annealed SS Wire O'Rings @0.041" > .030"x.038" deck groove.
Target of 650+whp
boostaroo is offline   Reply With Quote
Old 11-13-2020, 03:38 PM   #30
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
Tomei 1.2mm HG
.028" Copper Wire O'Rings in a .012"x.024" groove.
Sincerely appreciate your input. How long has it held up? How much power? Also what head studs?
Old 11-14-2020, 01:26 AM   #31
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
OEM EJ257 HG
Target of 650+whp
Y u no closed deck
user1029 is online now   Reply With Quote
Old 11-16-2020, 08:10 PM   #32
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
We've ran LA sleeves. We sent the blocks to LA Sleeves for the machining and sleeve installation.
The setups we ran where 600whp+ setups on E85 and 30psi+ boost levels.
Three of the blocks we took apart I've notice the main bores going out of round. They oval out and clearances go up to twice the oil clearance. The blocks have to be decked at the centers, and line honed back to round. This in turn you have to install the rear main seal before the halves come together. We have also had to oval out the oil pump dowel holes to fit the because the dowel pins are closer to the center. None have dropped sleeves. One is currently running 52psi of boost on a 76mm Xona turbo on E85 from the barrel.
Old 11-17-2020, 12:56 AM   #33
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
Thanks for your input as well. 52psi is very very impressive. I wonder why your main bores are ovaling. I was gonna get the block line honed after being sleeved and pinned to correct the distortion from all the work. What headstuds and head gaskets are you using? What kinda o ring wire and what protrusion height(Iím assuming you have an oringed deck)
