Welcome to the North American Subaru Impreza Owners Club Friday December 4, 2020
Old 09-25-2011, 09:12 PM   #1
Tengoku
Member#: 293241
Default Can valve cover gasket leak cause boost/vacuum leak?
My valve cover gasket has been leaking a little bit of oil from the bottom. My question is, can a blown seal cause boost/vacuum leak? Because I know that PVC hose is connected to the top of it. I've been noticing loss of power and throttle response.
Tengoku is offline   Reply With Quote
Old 09-26-2011, 10:23 AM   #2
Tengoku
Member#: 293241
Does anyone have any idea?
Old 09-27-2011, 12:13 PM   #3
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Yes a bad enough gasket leak can cause a vacuum leak, but I would think you'd get a CEL to come on if it's making any substantial difference.
Old 09-27-2011, 02:15 PM   #4
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Think about what you just said. A valve cover leak is not a vacuum leak. There is no passage way into the combustion chamber through the cylinder head.
Op the pcv does not draw vaccum either. Pcv sends crankcase pressure out through the hose, and back into the intake post MAF sensor (regulated by the spring inside the valve itself).
2Fast4U1DAY is offline   Reply With Quote
Old 09-28-2011, 11:24 AM   #5
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
If the engine is old enough to leak at the valve cover gaskets, it's also old enough to have vacuum leaks after the MAF. I would start there.
bluescoobywagon is offline   Reply With Quote
Old 05-21-2015, 12:56 AM   #6
subi-T
Member#: 348082
2006 impreza
SGM
Do you know what will happen if the hose on the right comes loose or of it comes off will it cause a lose of power and what is it called and what it is used for?
subi-T is offline   Reply With Quote
Old 05-22-2015, 12:06 PM   #7
b1gbleu
Member#: 402402
Those are breather hoses. Anything loose on three motors will cause idling/power issues.
Check all the smaller ones, they usually are not secured well and either fall off or split due to age.
b1gbleu is offline   Reply With Quote
Old 09-19-2020, 01:06 AM   #8
DonnaMechanic_20
Member#: 518695
[quote=Tengoku;35205662]My valve cover gasket has been leaking a little bit of oil from the bottom. My question is, can a blown seal cause boost/vacuum leak? Because I know that PVC hose is connected to the top of it. I've been noticing loss of power and throttle response.”
So this is difficult for a lot of people to understand I see. Someone commented about the PCV being after the pistons therefore not being able to cause vacuum from that perspective. But think of the PCV as apart of a cycle. ( ~> <~)It takes air that seeped past the piston and returns it to the intake manifold to be reburned so the air doesn’t cause too much pressure. If the valve cover is leaking and oil can get outside then air can definitely get inside because the Pcv is a vacuum! So in simple yes the valve cover can cause a vacuum leak. Many mechanics notice this leak and replace gaskets which solves the problem. But sometimes the oil leak isn’t the issue but the vacuum...
DonnaMechanic_20 is offline   Reply With Quote
Does bad IACV gasket = boost/vacuum leak iron_grenadier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-23-2011 02:36 PM
brand new valve cover gaskets/valve cover bolt grommets ('92 legacy L) shoodoggy Legacy Specific Parts 1 01-19-2010 02:13 AM
Lean at idle, rich under boost? Vacuum leak? saab-on-the-cobb Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 02-15-2009 01:54 AM
FS: STI Rods, Valve Cover Gaskets, Up Pipe and Helix Catch Can slowmike Engine/Power/Exhaust 13 02-11-2009 01:02 PM
Boost vacuum leak test procedure help Ricowrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 05-30-2005 01:17 PM
