Welcome to the North American Subaru Impreza Owners Club Monday September 24, 2018
Old 08-12-2009, 10:59 PM   #1
pipchick
Member#: 220274
2005 WRX Wagon
Platinum Silver
Default What do I need to hit 350-375 HP?
Stock 2005 WRX Wagon
1. HP at the [COLOR=#F82C70 ! important][COLOR=#F82C70 ! important]WHEELS[/color][/color] (whp) or hp at the CRANK (chp)?
whp
2. What type of dyno are you going to be shooting for this number on? Dynojet
3. If possible, tell us what shop it is. Someone may know how high or low that particular dyno reads. not sure
4. Where do you live? If not a well known city, what is the elevation? Near Newark, NJ
5. What kind of gas will you be using? (octane level) 91-93
6. Are you opposed to a FMIC? No
Thanks for your help, I'm new here
pipchick is offline   Reply With Quote
Old 08-12-2009, 11:04 PM   #2
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
One other thing to include might be budget!
SedonaScooby is offline   Reply With Quote
Old 08-12-2009, 11:16 PM   #3
GDB FAN
Member#: 105814
Textbook.....
Try stage 2 or a vf/16g swap and go from there.
GDB FAN is offline   Reply With Quote
Old 08-12-2009, 11:05 PM   #4
pipchick
Member#: 220274
2005 WRX Wagon
Platinum Silver
Open to budget, but I guess I should go step by step
Old 08-12-2009, 11:15 PM   #5
SedonaScooby
Member#: 143522
98 Forester L (RIP)
well the budget is just key because you could do a decent amount of turbo applications, injectors, intake manifolds and the like and achieve the same WHP with a agressive tune or a mild tune. I hope that makes sense
Old 08-12-2009, 11:12 PM   #6
pipchick
Member#: 220274
2005 WRX Wagon
Platinum Silver
I guess I should restate that. I would eventually like to get to 350-375, so I would like to know what steps I should take to get there over time.
Old 08-12-2009, 11:18 PM   #7
SedonaScooby
Member#: 143522
98 Forester L (RIP)
honestly just look around the forums...learn what most people do to go "stage 2"
best starting performance mods are all bolt ons ie:TMIC or FMIC, full TBE, exhaust, header, pulleys, tuning, exhaust manifold, TGV deletes....
eventually you will move on to bigger injectors, better fuel pump and a bigger turbo.....among other parts (i'd go forged pistons for 350+)
Head work rocks too....cams and a mildly built head does help
Old 08-12-2009, 11:26 PM   #8
GDB FAN
Member#: 105814
I wouldn't classify TGV deletes and a front mount as bolt-ons. A bit of custom work is involved. (cutting, grinding, etc.)
Old 08-12-2009, 11:37 PM   #9
luvless2620
Member#: 190566
Default It won't be street legal with those numbers.
Lots of NOS.
luvless2620 is offline   Reply With Quote
Old 08-12-2009, 11:46 PM   #10
02boxer
Member#: 139853
2002 wrx....its tsxy
open budget??? I'd find a shop and let them do the legwork
chris
02boxer is offline   Reply With Quote
Old 08-12-2009, 11:23 PM   #11
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
might wanna consider meth injection, FMIC, downpipe, injectors, fuel pump, upgraded tranny, oil cooler, forged internals, cams, turbos
topguneagle1 is offline   Reply With Quote
Old 08-13-2009, 12:26 AM   #12
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
You're not going to be making that amount of power without building both the engine and transmission. I'd lower your goal to 300 whp unless you've got deeper pockets.
Byzantium is offline   Reply With Quote
Old 08-13-2009, 12:49 AM   #13
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
10k and plenty of lube
AWDWRXLOVER is offline   Reply With Quote
Old 08-13-2009, 12:55 AM   #14
reddoak
Member#: 147628
2014 Fiat Abarth 500
Rosso
On pump gas, you should be able to see 350 Whp with a 20G, and larger injectors, say 750's to be on the safe side, and either a larger top mount or a front mount.
Now, the next question is what do you want to do with it? On a 2.0, with this turbo, you will have substantial lag until you can get that turbo spooled up all the way. If you want to horse around on the street, you'll be miserable. If you want to crush cars on a drag strip, maybe that's acceptable.
I'd worry about the tranny at that level. Seems like the WRX 5 speed reaches it's capacity around the 300 Whp mark. Some people run more with no trouble, some run less and blow a gear. It's risky.
reddoak is offline   Reply With Quote
Old 08-13-2009, 01:01 AM   #15
cmiller219
Member#: 187179
14 STi
Cocain
have u ever rode in a 300awhp sti or wrx? wow thats all i need to say. u should go in steps of course as u have stated for i feel 300whp would feel amazing to u. and safe .
cmiller219 is offline   Reply With Quote
Old 08-13-2009, 03:35 AM   #16
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Listen to this guy. ^^^
I recently went from ~210 whp to 373 whp on a mustang dyno and quite honestly, the car is a bit much to handle. I'm sure I'll get used to it, but it is purely insane.
375awhp =/= 375rwhp It feels much, much faster.
Old 08-13-2009, 03:48 AM   #17
down_for_the_scooby
Member#: 78314
04 PSM WRX
Audi mask the right way
Agreed, Stage 2 will bring your wrx from the approx 170hp to the wheel, (225hp to the crank) to around 225hp to the wheel. An additional 55hp is crazy quick. You don't really understand what 250hp is until you actually experience it. The STI is even worse. While having 300hp to the crank. A stock STI only puts out a "paltry" 225hp (approx). Make sure you really know what you want. Do you want to have the meanest track car out there or simply be able to hold your own with most things on the street while maintaining a daily driver status? Figure out what you want before you get yourself in deep with no end in sight.
down_for_the_scooby is offline   Reply With Quote
Old 08-13-2009, 12:59 AM   #18
subaru0276
Member#: 172940
06 LiftdFOZonsteel
ifudontknowicanthelpu
what about 350 bhp? sorry about the thread jack
subaru0276 is offline   Reply With Quote
Old 08-13-2009, 08:32 AM   #19
Jack
Add Lightness
Member#: 13699
not my president
(From General)
That's a lot of power. From a reliability standpoint, I'd want to start with at least a 2.5 and perhaps look into a different block to start (Cosworth?). Build from the inside out so the engine at least has a chance to survive. Perhaps PM nhsilversti. I'm pretty sure Ted's car is running at or near those levels. Check out his time trial run. Note how he's pretty much able to spin all 4 wheels at just about any point on the track. The dog box is music to listen to.
It's post 46 in this thread if the vid doesn't come up
http://forums.nasioc.com/forums/show...1804192&page=2
jack
Old 08-13-2009, 08:39 AM   #20
BlaxTrax
Member#: 139989
C6 05 Vette 11 WRX
00 Impreza, 03 WRX
You can do it on an 18G. You just need to know what you're doing. I'm on stock block and stock gears for 15 kmi now with no problems so far. (Knock on wood). But stuff will go wrong eventually. They are right tho. Do it in steps. Stage 2 first, and keep that for a lil, then step up.
BlaxTrax is offline   Reply With Quote
Old 08-13-2009, 08:46 AM   #21
penrod
Member#: 218495
2008 WRX Wagon 4EAT
Sweet run. I raced that track on a bicycle. pretty cool to see it in a car.
Looks like the front still pushes a bit.
penrod is offline   Reply With Quote
Old 08-13-2009, 09:35 AM   #22
pipchick
Member#: 220274
2005 WRX Wagon
Platinum Silver
Thanks for the info. If I go step by step, is there anything I need before the Stage 2 tune or can I just jump right on that? It's completely stock.
Old 08-13-2009, 09:45 AM   #23
Cards2323
Member#: 142868
2014 BRZ LIMITED
You need a DP, although a full ext. would be better
Cards2323 is online now   Reply With Quote
Old 08-13-2009, 12:48 PM   #24
schweezly
Member#: 187013
2013 ST
I think you need to do A LOT of research. I dont want to sound rude, but you have no idea what you are getting yourself into. I have no idea what I would do if I was trying to put down the numbers you are, and I consider myself to have a good knowledge of stage 2 stuff.
Spend a few weeks researching and reading a lot of threads, and then tell us if you still want 375 whp.
schweezly is offline   Reply With Quote
Old 08-13-2009, 01:09 PM   #25
kpluiten
Member#: 120273
06 WRBWRXWGN
Originally Posted by Defiant Autospeed View Post
You will most definitely, 100% need pistons. This isnt an if, its a sure thing. I would be suprised if it lasted more than a few weeks at that power level on stock pistons. May as well toss a set of mild cams in while you are at it.
Here is the mod list I would suggest.
TD05-20G 7cm
TurboXS 44mm EWG kit
TurboXS turboback high flow cat or catless. RFL axleback or magnaflow axlebakc depending what you want for sound.
TurboXS FMIC
Deatschwerks 750cc injectors
CP forged pistons
New water pump, timing belt, tensioner
TGV deletes
Port/polished stock exh manifolds -I can do it, or Grimmspeed, I wouldnt trust anyone other than either myself, themadscientist (who isnt doing porting for people right now) or Grimmspeed to do it.
Walbro pump
AEM alch injection kit
Stage 1 clutch
STI 6 speed tranny swap.
That will get you right about where you want to be, and compared to where you are now, the car will be terrifying.
Honestly, I dont recommend going to this setup right now. If you are stock, even going to an EVOIII-16G and a good TMIC will be a HUGE increase, and would likely pull harder than what you think 375whp would feel like. You are also looking at EASILY $10,000 to get to your 350-375whp level reliably.
This man speaks the truth. This is close to the route I've taken I guess and he is more than correct on the price. These things are not cheap and they will nickel and dime you into oblivion.
You know the old saying:
Fast, Cheap, Reliable - Pick any two.
Dyno Numbers and you- What do you need to hit XXX hp? Defiant Autospeed Newbies & FAQs 628 08-23-2018 04:41 PM
Iím flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-14-2010 11:49 PM
what do I need to hit 250whp? juvenescence Newbies & FAQs 27 10-07-2009 10:47 PM
WHat will i need to get 350 to 400hp out of a 2.2t TURBO KID Built Motor Discussion 3 03-02-2008 04:10 PM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 06:43 AM
