Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 03-17-2018, 11:53 PM   #1
10secdream
Member#: 430251
2015 WRX
Crystal White Pearl
Default 2015 WRX Wont Start after Accessport/Modification Uninstall
Just uninstalled all my modifications to return my vehicle back to stock and I went to fire it up and it starts for about 1/2 a second and then dies.
Any advice on what I should check first? To my knowledge I plugged everything back in and I uninstalled the accessport correctly. I checked for codes and there aren't any. My guess is that something isn't connected properly and is preventing the vehicle from running.
Here is my list of modifications I had removed:
- TGV Delete
- EGR Delete
- Intake
- EBCS
- Jpipe
- Accessport
10secdream is offline   Reply With Quote
Old 03-17-2018, 11:59 PM   #2
shvne
Member#: 482410
- TGV Delete
- EGR Delete
- Intake
- EBCS
- Jpipe
- Accessport
Throwing any codes when it dies?
shvne is offline   Reply With Quote
Old 03-18-2018, 12:05 AM   #3
shvne
Member#: 482410
- TGV Delete
- EGR Delete
- Intake
- EBCS
- Jpipe
- Accessport
Woops my bad didn't see it isn't throwing codes. Id check the connections on the tgvs
Old 03-18-2018, 12:33 AM   #4
10secdream
Member#: 430251
2015 WRX
Crystal White Pearl
Thanks for the tip. I will double check those again and report back.
Old 03-18-2018, 12:34 AM   #5
shvne
Member#: 482410
If that doesn't work give it a shot installing the accessport and running just the stage 1 ots map and see what happens.
Old 03-18-2018, 12:36 AM   #6
10secdream
Member#: 430251
2015 WRX
Crystal White Pearl
I should also mention I tried reinstalling a stage 0 map to see what happens and it doesn't start.
Old 03-18-2018, 07:11 AM   #7
simpleJ
Member#: 391748
2015 WRX
CWP
Vacuum leak
simpleJ is offline   Reply With Quote
Old 03-18-2018, 01:17 PM   #8
10secdream
Member#: 430251
2015 WRX
Crystal White Pearl
I am hoping it is something that simple. Any areas in particular I should look into?
Old 03-18-2018, 02:23 PM   #9
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
As others have said could be a pinched gasket or something with the stock TGV
gn4rwhals is offline   Reply With Quote
Old 03-18-2018, 05:11 PM   #10
10secdream
Member#: 430251
2015 WRX
Crystal White Pearl
I double checked the EGR install and everything is hooked up properly. I also looked at the intake and chargepipe and everything appears to be hooked up correctly as well.
I am going to try and redo the TGV's again this evening. I also loaded up the Cobb OTS Stage 1 tune and still doesn't start. From a sensor point of view is there anything I should look at via access port that would narrow down the issue?
Old 03-18-2018, 05:13 PM   #11
GlarryHoodDIT
Member#: 460907
2016 WRX
Phatroned
You can monitor TGV voltage on the AccessPort I'm pretty sure. Make sure both L and R are showing readings. Monitor MAF Voltage too, could be a MAF issue.
GlarryHoodDIT is online now   Reply With Quote
Old 03-18-2018, 05:22 PM   #12
10secdream
Member#: 430251
2015 WRX
Crystal White Pearl
I pretty much narrowed it down to the MAF. The car starts and runs with the MAF unplugged. Does anyone know what the MAF voltage should be when the car is not running?
Old 03-18-2018, 06:05 PM   #13
10secdream
Member#: 430251
2015 WRX
Crystal White Pearl
Pretty sure its a MAF. Only 4 pins are actually visible on the MAF and there are 5 wires going into it.
I also looked at the Grimmspeed extension harness and it is also missing some pins. There is some discoloration in there as well so I am guessing water got in the extension somehow and corroded the pins and when I pulled the extension off the pins came out.
Looks like I need to purchase a new MAF and a new MAF extension harness.
