Welcome to the North American Subaru Impreza Owners Club Friday November 22, 2019
Old 05-30-2007, 11:03 AM   #1
spyda23
Member#: 83758
04 sti
black
Default injectors install on a 2005 wrx
i just bought a pair of sti pink injectors and i want to install them myself. are they hard to install? also where are they located at?
spyda23 is offline   Reply With Quote
Old 05-30-2007, 11:46 AM   #2
r0n
Member#: 91839
r0n is offline   Reply With Quote
Old 05-30-2007, 12:59 PM   #3
TurbojonLS
Member#: 38772
2 Cars, No Bling
Umm, you do know that you need 2 pairs of injectors, right?
TurbojonLS is offline   Reply With Quote
Old 05-30-2007, 10:57 PM   #4
spyda23
Member#: 83758
04 sti
black
yeah i know i ment 4
Old 05-30-2007, 11:12 PM   #5
Cation
Member#: 88779
00 E55 AMG
You are planning on adding other mods to go with the injectors right? Like a bigger turbo, EM, and perhaps a fuel pump? Injectors alone will net you a crappy running car due to the injector trims being WAAAAY off...
Cation is offline   Reply With Quote
Old 05-31-2007, 12:46 AM   #6
jdbewl01
Member#: 80541
2004 WRX
install is NOT fun the first time.....but doable, if you have the time, the tools, and the link giving you the step by step directions.
jdbewl01 is offline   Reply With Quote
Old 05-31-2007, 01:12 AM   #7
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
some more advice.....keep the green brackets of death off after you take them off. you'll know when after you get done.
Justin
www.grimmspeed.com
GrimmSpeed is offline   Reply With Quote
Old 05-31-2007, 10:13 AM   #8
reconracer
Member#: 86279
04 WRX
wrb
i prefer using gear wrenches with extensions and the wobbly head attachment(helps with getting one or 2 of those bolts out of the gbod) ive done injectors on a wrx about 5 times and theres always 1 or 2 stubborn bolts
reconracer is offline   Reply With Quote
Old 05-31-2007, 11:47 AM   #9
r0n
Member#: 91839
theres 1 stubborn bolt on the passenger side in the back.. it was a bitch. but injectors arnt that hard IMO.
like grimmspeed said... leave your GBOD's off... when you have a fuel leak, like i did they're a lot easier to get to without having to take the GBOD's back off.
I had my injector out and new o-ring on and back in, in about 7 minutes.
Instruction: Pink injector install on 02-03 WRX txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 351 09-11-2019 11:21 AM
Injectors Installation on WRX emsfd125 Newbies & FAQs 7 01-03-2010 08:10 PM
Injector install on a wrx "HELP" dgriff992002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-25-2009 08:03 PM
S203 Hazard Button install on a 2005 WRX DUC748 Car Care & Detailing 6 01-13-2006 09:02 AM
Blitz Turbo Timer Install on a 2005 WRX y0gfx Electrical & Lighting 20 12-17-2004 03:38 PM
