Welcome to the North American Subaru Impreza Owners Club Sunday November 17, 2019
Old 01-18-2012, 08:55 PM   #1
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
OMGHi2U How to wrap your turbo
First off, the pros and cons of this mod.
Pros:
Easy
Cheap
Will stop 98.6% of heatsoak of your TMIC
Will stop you from visiting the burn ward while tinkering with your car
Cons:
None
Myth:
It will decrease reliability of your turbo
1. Purchase the Thermo Tec Turbo Wrap Kit #15003 which should cost around $37.
2. You can do this on or off the car as I've done probably 10 turbos over the years on or off the car. For a how-to, this is just easier to show and doing one on the car is only like 9% harder if that.
3. Assemble tools needed
I'm using the PROPER tool for the job, a safety wire twister. Harbor Freight sells these for a whopping $9. You can use pliers and twist it manually like the proletariat if you wish. I used the MIL-spec of 7 twists per inch though.
4. Make a paper template. This is two standard sheets of copier paper I stole from work taped together as the template that end up being like ~15" long or so. Notice how it is thicker on one end? This mimics the thickness of the compressor shape as it tapers.
5. Using a Sharpie, trace the template onto the thicker underwrap.
6. I cut two of these though the instructions only call for one layer. More is better right?
7. Cut 1/4" relief cuts every inch or so down both long sides of the wrap (and on both copies if doing two layers). These relief cuts will allow the thicker underwrap to lay flatter on the turbo body when it is tightened down. This step is optional and only for the most anal retentive.
8. If you do use two layers, it is best to secure them together so they don't shift around during wrapping. Since they will be on a curved surface, one will be slightly shorter than the other. Curve them into a circle so the slight shifting occurs and staple the ends with one staple on each end. Ghetto....yes....effective as crap....yes.
How it appears after stapling. The "loosey-goosey" appearance when not on the turbo is normal as that slack will go away when it is wrapped around the turbo.
9. This is where you mark and cut the silver overwrap. Flip it over and mark and cut the under white side. Lay down your template and mark using the Sharpie a perfect rectangle about 1/4" bigger than the thick tan underwrap.
Last edited by Unabomber; 03-15-2018 at 08:50 PM. Reason: fixed pics because nice guy
Old 01-18-2012, 08:55 PM   #2
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Look how much extra material you have left when you are done! This is enough to wrap SEVERAL turbos depending on the size and how clumsy you are. The only item that you will need to buy more of is the safety wire which can be found at Harbor Freight. In a pinch, they sell solid strand wire at Michael's in the picture frame department you could use as well.
10. Cut two pieces of the safety wire that comes in the kit about ~8 inches or so longer than your silver overwrap.
11. Stitch the wire through the silver overwrap about 1/4" from the top and bottom edges. I did it every inch or so and wasn't terribly perfect as this isn't critical. The pic below shows the white underside to better show the stitching.
12. This part can be tricky with one person, so a helper might be useful at this point. You want to lay your thick tan underwrap in its proper position. Then put the silver overwrap over it. As you mess with the overwrap, the underwrap shifts on you, so you need to take your time as you don't want either the under or overwrap walleyed.
13. Then loosely twist the ends to hold it all in place.
14. You can now undo one side, then the other and cinch them down better. Once they are moderately tight, do a twist or three and cut off the excess. Then twist them fully making the wrap tight across the turbo body. If the whole wrap package is not tight....keep removing slack and twisting the wire until it is as in order for it to be 100% effective, it needs to be tight and secure.
15. Finished bottom
Finished top
NOTES
1. Both the under and overwrap are woven fibers. Be careful during handling as fraying can occur and you don't want to unravel the fabric to China....CUT any loose ends.
2. Trim and tuck your twisted wire ends and warn your installer about the safety wire. It may be advisable to wear safety glasses during the overwrap step as the extra wire will be smacking you in the face during the entire process.
3. Your wrap can and will smoke for the first 1-5 driving sessions. This is normal.
4. If you currently are using an OEM or aftermarket heat shield, keep using it. There is no such thing as too much heat protection.
5. The wrap on your turbo will last for thousands and thousands of miles. I've had two turbos go 50,000 miles wrapped with no real fraying, unraveling, or generally looking nasty. Turbo wrap pretty much stays day one pretty and effective after years....unlike coatings.
Last edited by Unabomber; 03-15-2018 at 08:54 PM. Reason: fixed pics because nice guy
Old 01-18-2012, 08:55 PM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
working2
Old 01-18-2012, 09:11 PM   #4
lando
Member#: 149637
Needs more entertaining cartoons to keep me interested.
Eagerly awaiting moar.
lando is offline   Reply With Quote
Old 01-18-2012, 09:20 PM   #5
chris the man
Member#: 287783
08 predator evo X
RR
if yo dont mind to correct these myths.
i have heard it constrains heat which in turn harms the eternals of the turbo. heats up piping, and increases rust. NOW i have no idea but that is what has kept me from doing this. My shop said that a blanket will keep heat, to the point that once it has heated up so much that you will always be activating and driving on a red hot turbo. regardless of heat soak. im asking you if this is true.
other then that, yes it looks ****ing bad ass and something that i have wanted to do for a while
chris the man is offline   Reply With Quote
Old 01-18-2012, 09:23 PM   #6
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i got a ptp turbo blanket off ebay. they are like 80 bucks if you want to spend twice as much. they work so good you can put your hand on it after hard driving around town in summer and its warm but nothing hot to burn your hand.
i feel that this is a much better option than wrapping a downpipe because the turbo is mostly under the tmic and is cast so it holds more heat. the stainless downpipes wont and thats were it can dissipate more heat then! good writeup though. i did this first and it worked great for me.
WhiteBgeye02 is offline   Reply With Quote
Old 01-18-2012, 09:31 PM   #7
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
All out.
I've heard those stories as well....there are ZERO bad sides to wrapping your turbo. ZERO. NONE. All lies parroted by ignorant people.
Those thick blankets are nice....the only problem is they are expensive as crap. Wrapping your turbo with the Thermotec product offers the same "turbo hand holding benefits" as I often touch it to prove my point to locals.
Old 01-18-2012, 09:44 PM   #8
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
98.6% Ha, Ha... That's tad higher than my reality on my '02 WRX...
58.4% Turbo blanket
72.2% Water
90.3% Turbo blanket with water
97.3% Turbo blanket with water + vents with fans + header-wrap on everything...
wrxdrvr is offline   Reply With Quote
Old 01-18-2012, 09:45 PM   #9
GDB FAN
Member#: 105814
Is that Blouch's new turbo you've been talking about?
GDB FAN is offline   Reply With Quote
Old 01-18-2012, 09:57 PM   #10
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
You win the sharp eye award today.
Old 01-18-2012, 10:03 PM   #11
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Ron, you know I love you buddy, but do we need to have a talk about why we feel wrapping exhaust parts is a bad thing?
Old 01-18-2012, 10:07 PM   #12
GDB FAN
Member#: 105814
Hopefully we'll see a writeup soon!
Old 01-18-2012, 10:07 PM   #13
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Turbo ain't exhaust buddy. Let's hear your reasoning, and it better be good as my old stock turbo is still wrapped to this day and still on the road with over 100,000 miles on it.
Old 01-18-2012, 10:08 PM   #14
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Hopefully sometime next month. I have to talk to some people in Lebanon, PA, Richmond, VA, and Gaithersburg, MD first.
Old 01-18-2012, 10:12 PM   #15
marcmtb35
Member#: 171151
2012 JK COD MW3
Can we sticky this thread please? Like McDonald's, I'm lovin it.
marcmtb35 is offline   Reply With Quote
Old 01-18-2012, 10:16 PM   #16
chris the man
Member#: 287783
08 predator evo X
RR
im loving this ****! think that it is a bad idea to wrap your turbo and DP? wont cause harsh heating up? i do agree with the science that the turbo will stay warmer longer with a blanket. and cool faster without one because heat disipates faster. but everyone i see loves turbo blankets. i think im getting one of these ****ers right now!
Old 01-18-2012, 10:52 PM   #17
RossLH
Member#: 147839
'03 SRP WRX
'17 NGM SS
I'm no TiC, but my guess would be oil wicking for uppipes (oil saturated exhaust wrap doesn't like to be put out if it lights up). Getting more technical, they might discuss the phase change in the material resulting in heating it up to 1200F+ temperatures and significantly increasing the amount of time it takes to cool down. The resulting state of the material may be more susceptible to cracking due to engine vibration.
RossLH is offline   Reply With Quote
Old 01-18-2012, 11:02 PM   #18
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
- Is this worth doing on a stock turbo? (08 STi here)
- How can you tell if you have 'heat soak', and is it harmful other than losing a bit of power?
Neat thread, always good info.
Napalm3nema is offline   Reply With Quote
Old 01-18-2012, 11:36 PM   #19
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
It's always worth while on any turbo.
Heat soak is when your intercooler gets hot due to engine heat. Ideally, you want your turbo air to go through your intercooler and get cooled to near air temperature. When your intercooler is hot (usually occurs when stationary due to radiant, convection (hottest thing in the car is the turbo and it is directly BELOW the intercooler), and conductive heating) the air from the turbo can only get as cool as the temperature of your intercooler. So on hot days, your car is sluggish below say 30MPH and is a super bear for those that drag race and overheat their intercoolers while staging. Anything you can do to prevent this makes your car peppier in lower speeds until the hood scoop starts doing it's job.
Old 01-18-2012, 11:40 PM   #20
RossLH
Member#: 147839
'03 SRP WRX
'17 NGM SS
Sit at a stoplight for 5 minutes on a hot day, then see what happens when you floor it. The car will magically feel 1000lbs heavier.
Old 01-19-2012, 12:06 AM   #21
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Only if you spray water onto the IC... Dry, the IC is usually only about 60% efficient, thus you would never really get as cold IAT as the IC core temperature...
Old 01-19-2012, 12:26 AM   #22
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
You are an intercooler badass though. I was over simplifying it for ease of understanding!
Old 01-19-2012, 12:49 AM   #23
damonchoy
Member#: 279935
Well, I've finally made it on to the first page of a soon-to-be stickied thread. I have an odd sense of accomplishment, now.
Great write up, I'll definitely be doing this (if/when I get a turbocharged car ).
damonchoy is offline   Reply With Quote
Old 01-19-2012, 03:39 AM   #24
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
I'm very happy with doing a wrap. Of course that initial break in was rather smelly but once it goes away, the slight performance difference and capability of putting my hand on the hot side when "hot" amused me haha.
Nice write up and I recommend this to anyone who has some spare change and spare time.
GhostSenshi is offline   Reply With Quote
Old 01-19-2012, 03:58 AM   #25
spongerrich
Member#: 214736
2005 WRX wagon WRB
Cobb Stage 2 OTS
That's all the wrap that is needed? unless there are more pics to come...
BTW which magical turbo is this?
spongerrich is offline   Reply With Quote
How to protect your turbo??? scoobiekid86 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 01-25-2009 07:26 PM
Why its a good idea to wrap your headers PolarisSnT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-30-2007 09:38 AM
How to wrap header? AWD>FWD Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 05-22-2007 02:06 PM
How hard is it to tune your turbo setup with UTEC? disque71 Newbies & FAQs 7 09-17-2004 12:19 PM
How to make your car handle to your liking Eric SS General Community 4 11-10-2001 06:34 PM
