Welcome to the North American Subaru Impreza Owners Club Monday February 24, 2020
Old 08-15-2006, 11:41 AM   #1
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Default Possible to change 04 STI from 5x100 to 5x114
I did a search and did not see it being covered so sorry if I missed it.
Is it possible to change from 5x100 to 5x114? If so what parts would need to be swapped out.
The reason for doing it is wheel selection, which I agree is not the best reason. I am looking for 17-18" 8.5" wheels which seem to be slim picking for 5x100. I am sure I will get some rolls eyes for this, and I will be honest that it will probably be cost prohibative but have been thinking about it and just thought that I would ask.
roybfr is offline   Reply With Quote
Old 08-15-2006, 11:54 AM   #2
kingsti
Member#: 37698
2006 BB8BB8B CT9A
Default reverse didn't work
for similar reason i explored changing from 113.5 to 100 on a 05 STI and a no- go as major, incompatible differences with rear hub assemblies.
kingsti is offline   Reply With Quote
Old 08-15-2006, 12:01 PM   #3
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
That is what I kind of figured. Yeah when you got your car 5x114 wheels seemed to be few an far between, now it seems to be the opposite in some types.
Old 08-15-2006, 12:47 PM   #4
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
wrong, wrong, wrong, wrong, wrong!!
http://forums.nasioc.com/forums/showthread.php?t=777998
you will need the following:
-6gunracing hub swap kit
-2005 STI suspension
-5x114 wheels of your choice
-5x114 rotors front and rear (I redrilled my rears and bought a used set of 05 STI fronts)
done!
The rear hub assembly is exactly the same from 2004 to 2005. The front hub assembly is different and is why you need a 2005 fitting suspension.
SloRice is offline   Reply With Quote
Old 10-23-2006, 04:33 PM   #5
javid
Member#: 54304
04 STi
TopSpeed-dAng!
done!
Right. Just to clairify, for the front a different upright is used so you need 05+ struts or 05+ coilover or 05+lower collars for your existing 04- coilovers.
It is also possible to swap a WRX but you need an r180 rear end. The front will swap the same way a STi will.
javid is offline   Reply With Quote
Old 10-24-2006, 10:36 PM   #6
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Sweet. Should be ordering my wide body kit soon so this will open up my wheel choices. Thanks for the info.
Old 11-01-2006, 12:44 PM   #7
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
One clarifiing question. With the coilovers could I just order a set of the 05's? Or are the rears on the 05's diffent from the 04's?
Old 11-01-2006, 05:15 PM   #8
javid
Member#: 54304
04 STi
TopSpeed-dAng!
You need 05 front suspension. The front uprights (what the bottom of the strut bolts to) has a different thickness and bolt spacing. The rear struts are the same for 04 and 05.
If you have coilovers now with removable upright sleaves (coilovers that have independant hieght and spring preload will likley all have collars that are completely removeable), then you could just source 05 upright sleaves for your coilovers and not buy a whole new set.
Old 11-01-2006, 05:23 PM   #9
javid
Member#: 54304
04 STi
TopSpeed-dAng!
I missed this...
The rear 04 and 05 are the exact same with the exception of the hub. An 04 hub could be pressed into an 05 bearing and knuckle as easily as an 05 hub could be... standard bearing job but you use a different hub.
I am guessing you or who ever helped you in this quest looked at using the wrx 5x100 rear hubs rather than the 5x100 STi rear hubs. The two are not compatible due to the inner and outer diameter of the hub/knuckle/outer axle.
We have had a few WRX guys convert to an r180 rear end and then run 5x114 hubs. But I doubt you want to get rid of your R180... Someone is looking into custom rear axles that will plug into r160s and STi knuckle / hubs.
Old 11-01-2006, 07:29 PM   #10
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Cool, then since I have no coilovers at this time I would just buy 05's. Thanks again for the info.
Old 11-01-2006, 08:53 PM   #11
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
if you're interested, I am selling the 114.5 conversion bits
linky
Hyper is offline   Reply With Quote
FS: 20mm adpter/spacer convertor from 5x100 to 5x114 ( set of 4 ) PRICED LOWRED!!! thesunnyboi SCIC Private Classifieds 33 02-23-2010 10:46 PM
Who has gone from 5x100 to 5x114? Blackmojo Transmission (AT/MT) & Driveline 20 01-02-2010 07:37 PM
adapters from 5x100 to 5x114? 02MidnightPearlRS Interior & Exterior Modification 1 03-14-2008 08:52 PM
Conversion from 5x100 to 5x114.3 lowell787 Tire & Wheel 2 07-15-2007 05:04 PM
is there H&R spacer to convert from 5x100 to 5x114? etam Tire & Wheel 0 06-29-2004 12:18 PM
