Welcome to the North American Subaru Impreza Owners Club Thursday November 21, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine Management
Closed Thread
Old 10-23-2008, 06:35 PM   #1
PERRIN
Vendor Sales Rating: (10)
Member#: 6776
Default ** Accessport With Free PERRIN Map **
FREE PERRIN MAP WITH THE PURCHASE OF AN ACCESSPORT
We here at PERRIN are happy to announce the following:
We are able to offer our customers not only the AP but also CUSTOM PERRIN MAPs
(for most applications), and these applications will be tuned depending on the octane of fuel you have and types of parts installed. This means more power than the base maps normally provided with the AP. So not only will you get all the free COBB MAPs you'll also get the PERRIN MAP too :whoa:
Part Rundown:
The AccessPORT is a reflash tool that allows us to create custom tuned calibrations (using the OEM ECU’s existing internal maps), then allows you to flash them onto your car. This is done using the OBD diagnostic port under your dash, and the AccessPORT handheld device. With our custom maps loaded onto the AccessPORT, simply plug-in, push a few buttons, and your car is remapped for more power.
Besides the AccessPORT being a great tool to reflash your ECU with, it also can do things like:
* Allow for On-the-fly map switching, with provided maps
* Read/Clear engine trouble codes, so you don’t have to go buy another $100 tool.
* Estimates horsepower and torque, so you can see the increase in power from the PERRIN maps.
* Measure 0-60 and 1⁄4 mile times, drag race simulation with reaction time and “time slip” data.
* And much much more
What does all this mean in the end?? More power of course. With staged PERRIN part/map packages the AccessPORT can unlock even more power beyond just bolting on parts. In some instances, this can add 20WHP beyond what just parts added. In other cases, this allows for more than 300WHP more power!
Plus we have LOTS in stock and ready to ship! Only $695 PLUS you get the PERRIN MAP for FREE (normally $875).
Simply CLICK on a link below and place your order
WRX Drive By Cable 2002-2005
WRX & STI Drive By Wire 2004-2007
2008 and Newer WRX and STI
[color=Black]Please if you have any questions or would like to place an order over the phone feel free to call the number below.
Thanks
UPDATED 12/5/08 NOW $625.50 WITH THE MAP AND FREE OVERNIGHT SHIPPING! (A $925.00 value!!!!!!!)
Adam Taft
CEO /RETAIL SALES MANAGER
PERRIN Performance™
503.693.1702 Ex. 110
WWW.PERRINPERFORMANCE.COM
WebsiteBlogMyspaceE-mailAIM
PERRIN is offline
Old 10-28-2008, 02:39 PM   #2
PERRIN_Ken
Member#: 165212
Blaze Yellow
Just wanted to post a little more info.
The lower HP graphs are what we got from our STOCK 2008 WRX, on the stock ECU. After an ECU reset to ensure things were ok and running smoothy, the base HP runs were estabolished. Unlike the STI the WRX runs very well in stock form. Like most of the newer Subaru engines, the ECU runs 14.5 AFR while on boost, up to about 3300RPM. This seems very dangerous, but obviously it works fine for low boost levels, and is done for emissions reasons. ZERO knock was heard, ZERO timing retard was seen, it ran very very well. Smooth, maybe not, but that is where we can come into play.
Graph showing Stock 08 WRX, Cobb Stage 1 mapping, and PERRIN Stage 1 mapping.
We first flashed the ECU with Cobb's Stage 1 map. Boost went up to 15psi, and tapered back down to 8-9-is at redline. The increase in boost at peak torque (3500RPM) made for an extra 20ft-lbs of torque, and 25WHP at 3500. As you can see, power at redline didn't change, because the boost was the same.
Now it was time to play! With some AVCS tweaking, adding a little more boost, changing boost response, you see what kind of results we got! At 3000 RPM, 65ft-lbs of torque over stock mapping, and at the same point we made 35 extra HP. The biggest gain we got was at lower RPM where the tiny WRX turbo is happy. At upper RPM, the turbo shows its small nature. The boost drops off after 4000 RPM and there is nothing you can do about it.
Hope this helps
PERRIN_Ken is offline
Old 11-13-2008, 08:30 PM   #3
PERRIN_Chris
Member#: 186665
Bump!
PERRIN_Chris is offline
Old 11-27-2008, 02:05 AM   #4
Airrider
Member#: 150097
Have you guys done any Perrin tuned dyno runs on a 2007 Sti Stage 2 tuned w/factory airbox? Also, another concern is the fact that I live close to sea level compared to where you guys work on these maps. $180.00 custom tune is a great deal I have to admit that I would jump on that right away. First I have to make sure my car's engine isn't at risk.
Airrider is offline
Old 11-29-2008, 03:35 AM   #5
PERRIN
Member#: 6776
Thanks for asking. Yes we do have those maps as well. I don't have the dyno plots here at the house to post, but yes we have done it.
We are VERY close to sea level (portland, Oregon) so you should be JUST fine.
We would never risk a clients engine for a sale. These maps are powerful but SAFE!
Hope that helps! PLEASE let me know how I can help in anyway! Chat then!
Adam Taft
CEO
PERRIN Performance™
PERRIN is offline
Old 11-29-2008, 03:26 PM   #6
424wrx
Member Sales Rating: (6)
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
my perrin stage 1 91 is awesome compared to the cobb 91.i highly recomend it!!great product.
424wrx is offline
Old 11-30-2008, 09:55 PM   #7
PERRIN
Member#: 6776
THANK YOU for the business and the comment! Let me know if I can help further.
ALSO FOLKS: Don't forget the GOBBLE coupon code is good through tomorrow for an ADDITIONAL 10%! This a great time to get the power you deserve!
Questions? Just ask! I am always happy to help!
Adam Taft
CEO
PERRIN Performance™
PERRIN is offline
Old 12-01-2008, 11:41 PM   #8
PERRIN
Member#: 6776
GOBBLE GOBBLE (COUPON CODE) expires in jsut 4 hours!
Act fast folks!
Adam Taft
CEO
PERRIN Performance™
PERRIN is offline
Old 12-05-2008, 12:29 AM   #9
kade.mads
Member#: 156454
2005 Saabaru
any chance on getting a gobble gobble extension?
kade.mads is offline
Old 12-05-2008, 02:22 AM   #10
PERRIN
Member#: 6776
Well since you asked SO nicely, use coupon code online to save an addl. 10%! Let me know if I can help further!
Adam Taft
CEO
PERRIN Performance™
PERRIN is offline
Old 12-05-2008, 06:59 AM   #11
kade.mads
Member#: 156454
2005 Saabaru
will do!!
Old 12-05-2008, 04:01 PM   #12
PERRIN
Member#: 6776
will do!!
Thank you!
Adam Taft
CEO
PERRIN Performance™
PERRIN is offline
Old 12-11-2008, 08:28 PM   #13
PERRIN
Member#: 6776
Can't thank you folks enough for the business this week on this offer! It has been really nice to actually speak to many of you about what maps you need, etc. The feedback has been great!
We are going to run this through the weekend as well! So get in on the deal ASAP!
As always if I can answer any questions, just let me know! Always happy to help!
Adam Taft
CEO
PERRIN Performance™
PERRIN is offline
Old 12-14-2008, 12:29 AM   #14
jaybert
Member Sales Rating: (4)
Member#: 63030
2008 xxxxx
how do we get free overnight on the AP? Seems ground is free but it says $70 for overnight.
jaybert is offline
Old 12-14-2008, 01:23 AM   #15
PERRIN
Member#: 6776
Good question. Don't choose anything other than Ground. We automatically ship next day air. Sorry for the confusion. Just can't adjust the shopping cart to toggle it to sho Next Day Air, but the item code that prints on our end, IS for Next Day Air.
Thanks for asking for the clarification. I am sure others have had similar questions.
If I can help further PLEASE let me know!
Adam Taft
CEO
PERRIN Performance™
PERRIN is offline
Old 12-14-2008, 01:30 AM   #16
jaybert
Member#: 63030
2008 xxxxx
thanks for responding. picking up the STi on Monday or Tuesday, will order shortly after that.
jaybert is offline
Old 12-14-2008, 01:49 AM   #17
kade.mads
Member#: 156454
2005 Saabaru
i dident get the free next day shipping... now im going out of town for a bit without accessport:-(
Old 12-14-2008, 01:54 AM   #18
PERRIN
Member#: 6776
Thanks for the order. We JUST changed to the free next day on 12/5/08. PLUS while we try to ship the same day, if the item isn't in stock, it will unfortunately ship as soon as it is available. If there is further concern, PLEASE let me know! I am happy to help!
Adam Taft
CEO
PERRIN Performance™
PERRIN is offline
Old 12-14-2008, 01:56 AM   #19
kade.mads
Member#: 156454
2005 Saabaru
i ordered on the 8th or 9th... its ok... it just would have been nice to get in a couple days... im anxious ya know! haha
Old 12-14-2008, 03:53 PM   #20
PERRIN
Member#: 6776
NO problem! I totally understand!
Adam Taft
CEO
PERRIN Performance™
PERRIN is offline
Old 12-16-2008, 02:59 PM   #21
AaronB
Worst Mod Ever
Member Sales Rating: (12)
Member#: 369
19 CTS-V, 18 XC90
17 GTI
Put in my order last night. Looking forward to getting it.
Also sent you a PM on an unrelated product Adam.
AaronB is offline
Old 12-17-2008, 07:14 PM   #22
PERRIN
Member#: 6776
Thank you. I didn't see your pm. Did I miss it?
Adam
PERRIN is offline
Old 12-17-2008, 09:09 PM   #23
AaronB
Worst Mod Ever
Member#: 369
19 CTS-V, 18 XC90
17 GTI
I will resend the PM.
FYI If you are still doing the next day air upgrade I didn't get that when I ordered.
AaronB is offline
Old 12-18-2008, 01:20 PM   #24
PERRIN
Member#: 6776
Thank you! When you order online, the next day air is "FREE" and we should process on our side as such. You don't have to choose Next Day Air.
Going further there was a day when a coupon code was applied to the $625.50 price, and those clients did NOT get next day air, but did get 3-day select. Those purchased at the $625.50 include next day air.
Hope that helps!
Adam
PERRIN is offline
Old 12-19-2008, 01:54 AM   #25
AaronB
Worst Mod Ever
Member#: 369
19 CTS-V, 18 XC90
17 GTI
I used the SANTA08 coupon code, picked ground shipping, and got 3 day shipping for my order instead of next-day.
In any case I will have it tomorrow so no big deal.
AaronB is offline
Closed Thread
Must Sell Asap Accessport $550 Inc. Shipping V2 08/09 Wrx Free Perrin Maps iancka83 Engine/Power/Exhaust 1 08-13-2009 04:16 PM
** Accessport With Free Perrin Map ** PERRIN Engine/Power/Exhaust 3 10-17-2008 10:31 PM
05 STi protuned accessport with RACE GAS MAPS! kettsupp Private 'For Sale' Classifieds 5 03-30-2006 04:13 PM
