Welcome to the North American Subaru Impreza Owners Club Thursday November 21, 2019
Old 02-10-2011, 07:27 PM   #176
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
With a little luck I am going to take a ton of picts tonight. I currently have the motor sitting in the car for test fitting reasons. There's no clutch in there and lots of other stuff missing so its coming back out soon. In the meantime I can at least see how things fit together.
dexterous is offline   Reply With Quote
Old 02-10-2011, 11:21 PM   #177
dexterous
Member#: 23553
2014 WRX - Daily
Ok, so first up is my new Beatrush Bulkhead Division Plate. I just set it in place for this picture but you should be able to get the point. The idea here is that it will add a layer of fire protection between the passengers and the trunk. The plate isn't exactly designed as a fire barrier but it is metal were the seat is just foam. This should give me and any passengers in the back a few extra seconds in the event of a catastrophic fuel system failure.
As I said in post 176, I decided to set the motor in the engine bay to test fit a few things. I didn't put the clutch on so it took all of five seconds to do this.
I actually pulled the bracket that I made for the fuel block apart before I took the pict (stupid) but trust me, it fits perfectly. As you can see, the -10 line enters from the passenger side of the trans and hits that nice 45 degree hose adapter at the perfect angle. I am very pleased with how this turned out.
Everybody is so curious about how the turbo will sit in the engine bay. Here it is!
This header fits so amazingly well I cant believe it. I have a Mishimoto X-Line racing rad which is super thick and the Moore header fits with the STOCK fans!
There were also lots of questions regarding the header sticking down below the front subframe. Basically its at the exact same spot that my GT-Spec header was in terms of height. I also did a quick test fit of the under tray and it bolts right on without any issues.
The Killer B oilpan is exactly that, "kill". It just looks so nice in there:
Old 02-11-2011, 11:46 AM   #178
V8Slayer
Member#: 111565
2007 Legacy Spec.B
324hp/313tq EVOIII 16G
Look great! Can't wait to see it completed!!
V8Slayer is offline   Reply With Quote
Old 02-11-2011, 11:08 PM   #179
dexterous
Member#: 23553
2014 WRX - Daily
Well, I am unfortunately heading to Denver for the next 12 days for work. I look forward to lots of progress when I get back. Talk to you guys in a little under two weeks.
Old 02-14-2011, 10:55 PM   #180
dexterous
Member#: 23553
2014 WRX - Daily
I just got word form Moore Performance that my revised intercooler pipes are just about finished (I had them start working on them about five days ago). I am not sure I mentioned it before but the Moore solution to plump up an Evo turbo using an APS FMIC is to reverse the flow of the FMIC pipes (counter clockwise) by totally replacing the drivers side pipe and modifying the passenger side. From what I understand, the pipes should be finished around the time I am back from Colorado so hopefully I will have some picts pretty soon.
Old 02-15-2011, 11:00 AM   #181
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Looking good DEX! Cant wait to see this done, turned the key on mine saturday and all seems well..... now the tuning begins! Cant wait to see what yours will put down whp wise!
binjoau is offline   Reply With Quote
Old 02-16-2011, 12:11 AM   #182
dexterous
Member#: 23553
2014 WRX - Daily
Thanks! I cant wait to get back home so I can work on the car some more (right after I play with my little girl).
Old 02-17-2011, 05:05 PM   #183
DSM_Outback
Member#: 56345
1997 OBS
Primer Grey
+1 on your priorities.
DSM_Outback is offline   Reply With Quote
Old 02-17-2011, 09:48 PM   #184
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Hm, do you know how much shorter your intercooler pipes are going to be with the reverse fitment? Or if they even are shorter?
I guess we'll know when when you get them...
OrbitalEllipses is offline   Reply With Quote
Old 02-17-2011, 09:52 PM   #185
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Originally Posted by Homemade WRX View Post
The idea has been done before (intake through the hoodscoop) and charge pipe under the manifold. So those are nothing new. Guess I'd better hurry and get to doing it.
There was a Cobb car that had something like that. Turbo rotated behind the intake manifold, above the tranny bellhousing. Filter ponted towards the drivers side shock tower. Looked efficient/cool/expensive.
Here it is:
Old 02-17-2011, 10:02 PM   #186
THE_SMURF
Member#: 260624
2007 Z06/ZX10R
not really^ ^ ^ ^
just rotate it a little more . . .
THE_SMURF is offline   Reply With Quote
Old 02-18-2011, 02:29 PM   #187
Ultra85
Member#: 160392
2005 STi
The only way you would ever need an oil cooler is if you did track days and had oil temp issues. I was running North of 250F on my old setup after about 15 minutes worth of hot laps and with my 24 row Setrab I rarely get beyond 215F. My new setup will generate even more heat which will make it even more important to keep the on track temps down. The issue that I run into now is that the oil cooler works to well on the street and the car cant maintain the correct temps (to cold). Trust me, you dont want to bother unless you actually need an oil cooler.
Isn't that what the thermostat is for? I'm asking because I have an '05 DD with an FP green set up and a process west cooler however I don't have a thermostat so I'm not sure what to do at this point. I think it would be more beneficial to completely remove it after reading a few posts similar to the one I'm quoting. Obviously we have two completely different purposes in mind as you're building a track beast and I'm pushing 90k mi on a stock block DD.
Great build! Keep the pics coming please and thanks for sharing.
Ultra85 is offline   Reply With Quote
Old 02-18-2011, 04:07 PM   #188
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
You can sell it to me. My track whore is in need of one
Old 02-19-2011, 03:35 AM   #189
Joelo_00
Member#: 175095
Chapter/Region: PRSIC
2000 RS
GREAT stuff!! Lots of interest to detail, really looking forward to your progress. I do have a small doubt regarding the turbo, Is the downpipe portion of the turbine housing right now looking upwards? I'm thinking about the downpipe for this setup.
Congratulations on the progress that's been already made and wish u the best of luck meeting and exceeding your own expectations!
Joelo_00 is offline   Reply With Quote
Old 02-20-2011, 11:01 AM   #190
nadeaa0a
Member#: 274519
it looks like a monster sleeping in there
nadeaa0a is offline   Reply With Quote
Old 02-20-2011, 11:09 AM   #191
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Nice, very nice. Except for that coolant hose in front of the oil pan. If you would have ordered a different water pump (the one without the line to the oil cooler, the 21111AA065) you could have replaced the coolant plug in the block. Cleaner and more reliable. But still, that is a nice setup
Marnix is offline   Reply With Quote
Old 02-20-2011, 11:30 AM   #192
MartinSTi05
Member#: 145145
2006 wrx STi
I pulled the hose nipple from the pump in my build and tapped it for 1/4"NPT and plugged it. I then drilled out the block plug and 1/8" NPT tapped/plugged it. It all worked out nicely and was clean. Hope this helps Dex.
MartinSTi05 is offline   Reply With Quote
Old 02-21-2011, 01:16 AM   #193
dexterous
Member#: 23553
2014 WRX - Daily
Guys, when I said that the filter thing would be new I was speaking about a new product offering not a new concept.
Martin,
I understand what you're saying about the coolant line but I am a little beyond that point now. I opted to keep it as it was because didn't think it need changed. If I had to do it all over again I would do it like you're suggesting.
Old 02-21-2011, 01:18 AM   #194
dexterous
Member#: 23553
2014 WRX - Daily
The turbo setup is part of a kit which fits just fine. Check out the Moore website for picts.
Old 02-21-2011, 09:46 PM   #195
Joelo_00
Member#: 175095
2000 RS
Yup, saw the pic!
Can't wait to hear it start up! Good Luck!
Old 02-21-2011, 11:58 PM   #196
methaddict
Member#: 159738
2004 WRB STi 620awhp
OFCD V3, FR TS, BW8374EFR
Another option would have been the Litchfield twin scroll turbos.
methaddict is offline   Reply With Quote
Old 02-22-2011, 12:35 AM   #197
dexterous
Member#: 23553
2014 WRX - Daily
Those are cool but based on that link you posted the turbos cost MORE than large framed FP turbos and they are rated at lower power levels.
Old 03-01-2011, 01:02 PM   #198
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
You get that thing running yet?
slowgenius is offline   Reply With Quote
Old 03-01-2011, 02:17 PM   #199
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
would one of these possibly be the mystery secret sauce turbo in the type 25?
timeXlost is offline   Reply With Quote
Old 03-01-2011, 10:54 PM   #200
dexterous
Member#: 23553
2014 WRX - Daily
I wish. I have not even stuck my head in the garage since I got home from my trip. I am in the middle of an IT security audit at work (I am the engineer conducting the audit) and everybody at my house including me has the flu. My daughter (pict on the first page) had to be taken to the ER the other day due to a 105.6 fever! She's fine now and we are all on the road to recovery but it's going to take a few days.
I am actually supposed to meet up with Ryan Moore from Moore performance tomorrow to pick up my second to final load of parts. With a little luck it will only be a bit more.
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 02:09 AM
Picture of my new Ultimate Racing twin scroll kit blowbyu24 Member's Car Gallery 682 08-24-2010 09:12 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 02:04 PM
FS VA: JDM manifold, Twin Scroll kit, JDM Genome and more quadzilla Engine/Power/Exhaust 38 09-18-2008 11:22 PM
Pros and cons of twin-scroll turbo! Carisma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 07-04-2005 06:06 PM
