Welcome to the North American Subaru Impreza Owners Club Wednesday November 13, 2019
Mid Atlantic Impreza Club
Old 05-22-2019, 01:41 PM   #4301
Lagunagreen
Member#: 410537
2002 Wrx Sedan
Wrb
Brand new car or older used car? Give us 2 hints (Year and if hp is stock).
Lagunagreen is offline   Reply With Quote
Old 05-22-2019, 02:41 PM   #4302
Harry
Member#: 23390
2010 WRX STI SE
Default New ride
New (2019), red, stock Tesla Model 3 Long Range Dual Motor
Specs: 0-60 in 4.4 sec, 350+ WHP, AWD, 310 mi max range
Autopilot's traffic following (down to stop and then restart) was nice for the 105 minute commute I had tonight.
Keeping the STI, which I still love but the clutch was getting old in rush-hour and 18,000 mi/year at 18 - 19 MPG was a lot gas money.
May autocross the Tesla too - it's in the same class as the STI; at the last WDCR event, there were two AWD Model 3 that beat me by 1.5 seconds
Harry is offline   Reply With Quote
Old 05-26-2019, 07:43 PM   #4303
Harry
Member#: 23390
2010 WRX STI SE
Pulling radiator
STI decided it was time to crack the upper hose outlet on the radiator, so I order a new OEM rad (SCCA street tire class rules) and started pulling the dead one out.
Hope new one arrives in time to install and burp before Sundayís AX.
- Harry
Old 05-28-2019, 12:38 PM   #4304
96accord
Member#: 145105
2007 Impreza WRX STi
'15 Accord (Daily)
Originally Posted by Harry View Post
Pulling radiator
At least you had the Tesla as the daily!
96accord is offline   Reply With Quote
Old 05-31-2019, 07:57 PM   #4305
96accord
Member#: 145105
'15 Accord (Daily)
Washed the STi.. by hand (Something I don't typically do myself )
Old 05-31-2019, 10:32 PM   #4306
Harry
Member#: 23390
2010 WRX STI SE
Yep, having a daily driver came in pretty handy, drove to Pax River and back yesterday without range panic; recharged from the dryer plug last night and did 110 more miles today.
Radiator is done and cooling system burped. So far, so good - no leaks, temps are normal, and heat works.
Now, on to the rear diff leak, hopefully without cracking the temp sensor.
- Harry
Old 05-31-2019, 11:40 PM   #4307
UnstableReagent
Member#: 383028
01 2.5RS Sedan
BRP
I changed the front and rear shifter bushings.
Cobb 6MT Shifter Bushing pack, no short shifter though.
It made no difference, still get locked out of 4th gear when pushing the car.
Here are the old ones, they don't look so bad even for an 07 STI
UnstableReagent is offline   Reply With Quote
Old 06-01-2019, 12:51 AM   #4308
RynoATX
Member#: 485320
Took my subie to the shop for spark plug replacement & leak down and compression test. Found out my 2nd cylinder is failing......
RynoATX is offline   Reply With Quote
Old 06-10-2019, 06:36 PM   #4309
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- Rolled 226,000mi on the beater Impreza on the way to work this morning.
- Hit the Mt. Airy Crazy Ray's this weekend and grabbed some odds 'n' ends for my Legacy. An extra set of manual folding power sideview mirrors off a '95 (those are really to sell), a 140mph speedo off the same '95, and a leather parking brake handle off an '02 Forester (but it will fit the BD/BG Legacys). Also grabbed some screw-in cargo net hooks out of an Outback wagon so I can install a cargo net (which I already have) in the trunk of the beater Impreza.
Old 07-02-2019, 12:30 PM   #4310
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Ordered new tires for the beater Impreza. Current tires are Firestone Indy 500s, which I've been very impressed with, and figured I would get again. But as I was searching around online I decided to roll the dice on some Federals. Specifically, the Evoluzion ST-1, which is their new (I think) ultra-high performance summer tire. There are folks who rave about the bang-for-the-buck of their 595 RS-R, so I figured I'd give these a shot. They were about $60 cheaper (for all 4 in 205/55-16) than the Indy 500s.
Old 07-02-2019, 05:47 PM   #4311
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
EG33 05 Forester
the Only shifter bushings anyone ever purchases for these cars should be the TiC Holy Shift kit, makes a huge difference and actualy changes all the bushings, not just the ones on the shifter stabilizer link like shown above
carnz-pj-410 is offline   Reply With Quote
Old 07-06-2019, 11:00 AM   #4312
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
During the week, one of the nights when it was thunderstorming outside I popped into the garage and did a little work on my languishing EZ30 swap. Way back when, I wasn't sure what I was going to do about a coolant overflow/reservoir, so I had made a "custom" setup with a small Gatorade bottle. Very trick!
A few months back I learned that JDM GC turbos had the coolant overflow bottle mounted in the left front fender. Hiding the overflow bottle in the fender means I can get rid of the Gatorade bottle on the passenger side of the engine bay, which frees up some space to put the PS reservoir over there where it's supposed to be. (As things are now, I have a Chase Bays universal PS reservoir over on the driver side, which means I have long supply and return hoses running over the top of the engine.) So, I bought a used fender overflow setup from someone here on NASIOC and installed that a few days ago.
This is a shot looking forward from the left front wheel, with the fender liner removed. The "new" overflow bottle is at the top.
Here's a view of the front driver side corner of the engine bay. The yellow cap is the top of the fill pipe for the coolant overflow bottle. There's a short rubber hose that connects the bottom of that fill pipe to the overflow bottle, which is hidden from view by the inner fender panel.
The red terminal on the inner fender panel is for the + voltage coming from the relocated battery. I had to unbolt that terminal, shorten the mounting lugs so that they didn't interfere with the new overflow bottle, then reinstall the terminal. Still need to hook the wiring back up.
Looking from the center of the car over towards the left front corner of the engine bay. In the bottom left of the photo is the radiator cap and the overflow hose connection. Unfortunately, it points the wrong way (since I thought the coolant overflow was going to be somewhere on the passenger side), so I'll have to reorient that to clean up the hose routing.
Next is to figure out the PS reservoir and hoses. I have a few options - an OEM Outback one, plus a couple junkyard finds - just need to determine which fits best and where exactly it fits.
Old 07-07-2019, 12:01 AM   #4313
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Adjusted the parking brake handle on the beater Brighton. Something I've been meaning to do for a while.
Old 07-08-2019, 12:00 AM   #4314
norcaltuna
Member#: 286686
2003 WRX EJ207 VF36
Installed this factory second radiator shroud on my daily beater for high performance daily driving.
norcaltuna is offline   Reply With Quote
Old 07-10-2019, 01:49 PM   #4315
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Pulled the driver's door panel off of the Impreza coupe to do a little window troubleshooting. Put things back together. Drove the car to work this morning and discovered the inside door handle doesn't work. *sigh* I think I've done this to myself once before. I guess I get to pull the door panel off again this evening!
Old 07-10-2019, 02:57 PM   #4316
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
EG33 05 Forester
Got billet shift forks for my 6MT today
Pulling it out this weekend and changing 2nd, 5th and 6th gears (did 07 ratio 3/4 a few years ago).
Going to have Spec.B gear ratios soon!
Old 07-10-2019, 08:50 PM   #4317
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Fixed the inner door handle so it's functional again. Also found 2 loose bolts on the window regulator crank assembly (1 had actually fallen out completely and was stuck in the adhesive at the bottom of the vapor barrier). Tightened those up with some Loctite, window operates much more smoothly now with less rattling.
Old 07-11-2019, 03:27 AM   #4318
Lagunagreen
Member#: 410537
2002 Wrx Sedan
Wrb
Reprogrammed new key fob that I just got in.
Old 07-13-2019, 12:25 PM   #4319
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
Default What did you really do to your car today? V3.1
Finally dropped off parts for a built motor for my coupe this morning!
Using a 22e or 22t block, just not sure about a few things yet. Either way itíll be a 2.0/2.2 hybrid with forged internals. Canít wait.
RavensFan7 is offline   Reply With Quote
Old 07-14-2019, 03:18 PM   #4320
clee510
Member#: 501920
Stage 1 Cobb AP and Revel coils...new subie owner
clee510 is offline   Reply With Quote
Old 07-21-2019, 12:03 AM   #4321
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
EG33 05 Forester
Collected all the parts today to add AC into my racecar 95 impreza.
Also figured out the wiring I need to add for it to all work properly
Old 07-21-2019, 12:13 AM   #4322
Pelco
Member#: 435599
2016 Impreza Sport
I went on a twisty canyon run in my CVT Impreza. It was really fun. My first time, and I think I'll be doing it a lot more. All I smelled was burnt rubber by the end of the run.
Pelco is offline   Reply With Quote
Old 07-21-2019, 05:39 PM   #4323
96accord
Member#: 145105
'15 Accord (Daily)
Real racecar's don't have AC....
Old 07-21-2019, 06:17 PM   #4324
Jy05
Member#: 499527
I finally got my retrofit finished. It took three days of trial and error to get everything right but the end result was well worth it.
Jy05 is offline   Reply With Quote
Old 07-24-2019, 03:55 PM   #4325
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- Cleaned up a number of grounds around the engine bay in an attempt to help clear up some intermittent hesitation I've been getting.
- Cleaned the top of the battery. Pulled off the battery hold-down bracket, cleaned it up (was getting some battery acid corrosion) and sprayed it with some Rustoleum primer and flat black. Hopefully that'll hold the corrosion at bay for a bit.
