Welcome to the North American Subaru Impreza Owners Club Sunday November 17, 2019
Old 08-17-2017, 04:28 PM   #726
Caveit77777
Member#: 346966
Originally Posted by Charlie-III View Post
That "silicone stuff" is likely dielectric grease, it's fine to have on there (actually, it's GOOD to have on there!).
Thanks I figured that during the install of the new coils. Oddly enough with the correct plugs and replacement of 3 dry rotted vacuum lines, the car runs worse and won't even hold an idle anymore. It seems to idle with the intake filter off for some reason but the filter is the same filter that's been on when the car ran fine and is clean and new in appearance. I'm lost at this point
Caveit77777 is offline   Reply With Quote
Old 10-11-2017, 09:58 AM   #727
Brock31
Member#: 128115
2008 STi Hatch OBP
enginuity is cool
I feel like this is something I should know....but I'm bumping this anyway because I've only had this car for about 5 months.
Anyway....
2008 STi
Its only got a stage 2 setup (Intake, exhaust and Pro-tune)...but its dyno'd at a bit over 330 whp. General rule seems that 1 step colder is:
a)Totally bogus
b)A good idea for 75-100 whp over stock
Being that I fall into the 75-100 hp over stock area and the fact that I ran colder plugs in my last WRX with no problems, I'd like to run them again.
Stock NGK P/N is #7913 Laser Iridium SILFR6A Heat Range 6
I think I found my answer:
NGK 2309 LFR7AIX IX Iridium Plug....also (derp..I forgot increasing Heat range number meant colder)
Brock31 is offline   Reply With Quote
Old 04-30-2019, 05:08 PM   #728
Flytrap
Member#: 501016
This is exactly what I was looking for! Thanks a lot!!!
Flytrap is offline   Reply With Quote
Old 06-05-2019, 08:44 PM   #729
Steodes
Member#: 436720
I would like to run one step colder Copper Plugs on my JDM 2002 STi (EJ207)
Am I correct in saying the right plug I wan to run is a BKR7E?
Steodes is offline   Reply With Quote
Old 09-07-2019, 06:47 PM   #730
Evoballer
Member#: 436019
2018 STi RA #406-500
Peral White
So wile doing my research I discovered that the 2018 STI Type-RA comes from the factory with one step colder plugs "this info was provided to me by the Heuberger Subaru Parts Department". So I would like to confirm with you all that the correct part number for the Performance NGK Racing Plugs would be:
( NGK R7437 RACING SPARK PLUGS LONG REACH in HEAT RANGE 9 "PN#R7437-9" ) Is this correct?
https://www.rhdjapan.com/ngk-r7437-r...t-range-9.html
Ive searched and searched and have not found a definitive answer.
Evoballer is offline   Reply With Quote
Old 09-10-2019, 10:18 AM   #731
JarHarms
Member#: 138994
06 WRX Ltd
SGM
2018 TypeRA and 2019 STIs are built with factory 22401aa910 plugs which are NGK ILFR7H Laser Iridium plugs.
copper center core
iridium center tip
single standard ground
nickle core ground
5/8" hex
50.5mm insulator
max heat range 7
pre-gapped 0.024"
26.5mm reach
5000 ohm resistance
flat seat type
M14 thread diameter
NGK Laser Iridium
Prior to these models the typical turbocharged Subaru was built with heat range 6 plugs, with a few dimension variants depending on which cylinder heads you had. Personally I would stick to NGK Laser Iridium and not go into Iridium-IX (shorter life) or any fancy NGK race plugs (expensive, unnecessary, and short life) unless specifically told to go that way buy your tuner. Have you changed a set of plugs in a Subaru yet? Also I would also not go any colder than the range 7 plugs you already have. Those are plenty cold enough for any street driven car even with heavy modifications.
JarHarms is offline   Reply With Quote
Old 09-29-2019, 01:54 PM   #732
jclarkwlsc
Member#: 171791
2014 WRX
I'm due to change the plugs on my 14 WRX. I was on NGKs site and seen where they have Ruthenium HX plugs. The claim is that they are the best thing out now but since they are so new it's hard to find any reviews on them. Anybody have any thoughts on these?
jclarkwlsc is offline   Reply With Quote
Old 10-24-2019, 11:01 PM   #733
wrxTR2007
Member#: 507717
I have a 2007 wrx
Mod list-
Uel tomei header
Blouch 16G turbo
ID1000 injectors
Perrin fmic
Cobb ebcs
Cat less downpipe to a full exhaust
Car was dyno tuned running 22psi at 346hp
Thereís probably a couple other things Iím forgetting.
But Iím having an issue when I go to accelerate around 3000rpm to 3500rpm it starts cutting out then clears up at higher rpms it didnít really start till i changed the plugs ( NGK ILFR7H ) I gapped them to .23 as they were before so i took them back out and tryíd .26 still no better so my question is what should I gap them to and should I try new coil packs too??
wrxTR2007 is offline   Reply With Quote
Old 10-25-2019, 02:14 PM   #734
motorbykemike
Member#: 273868
hmmm
what should I change next ?
motorbykemike is offline   Reply With Quote
Old 10-26-2019, 02:18 AM   #735
wrxTR2007
Member#: 507717
Originally Posted by motorbykemike View Post
hmmm
I didnít ask what I should change next I asked what I should gap them to? And maybe it could be coil related from them being taken out and jostled around so just looking for input
Cooling System FAQ: Read if you want coolant information! Unabomber Service & Maintenance 667 10-07-2019 01:20 AM
Oil FAQ: Read if you want more information on oil, oil filters, and oil changes! Unabomber Service & Maintenance 1076 10-06-2019 09:35 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 391 08-16-2019 11:49 PM
Tool FAQ: Read if you want information on Subaru specific tools and sundries Unabomber Service & Maintenance 41 08-16-2014 05:59 PM
