Welcome to the North American Subaru Impreza Owners Club Sunday November 18, 2018
Old 10-31-2016, 01:35 PM   #19801
DMBrown
Member#: 382708
MBP
Originally Posted by OpFox View Post
Tell that's bone stock and/ or high mileage lol.
Anyways, got tints and my roof wrapped. Hope my style is still within tasteful boundaries. Dat OEM+ look.
Here's it is when I got it and now.
About to do an oil change within the week. Still not sure to go with synthetic since I have no idea what this car came with.
Also threw on an HKS panel filter, made a bit more noise and perceived power. Then took off the intake milk jug and got ALOT more noise lol. This is supposed to be a bad thing on MAF N/As but so far I've only had better response besides the noise. I haven't hit A CEL or noticed any negative effects yet.
-Will look into a decent exhaust yet. Maybe OEM rep resonated mid pipe and a decent axle back.
-Deciding on spacers... 53mm offset on the Prodrive P1s I think. I was gonna go 3mm but I'm not sure that's noticeable. Any more and I'd have to get longer wheel studs.
What lip is that?
DMBrown is offline   Reply With Quote
Old 11-02-2016, 11:47 AM   #19802
fakewrx
Member#: 457502
2010 Impreza
what are some good first mods for a stock '10 impreza?
fakewrx is offline   Reply With Quote
Old 11-02-2016, 04:42 PM   #19803
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Fill up the gas tank...
Seriously...
good set of tires... not talking about A/S tires here. :/
Then upgrade the proper suspension... add RSB & upgrade springs & shocks/struts... not talking about slamming it w/ cheap coilover here. :/
If you're asking about power mods, then sell the car & get something else... like WRX.
Fendyman is offline   Reply With Quote
Old 11-02-2016, 10:22 PM   #19804
fakewrx
Member#: 457502
2010 Impreza
Seriously...
Didn't have the money for a wrx, and besides, I'm not looking for much power as its a daily driver. Just want some nice visual mods to stand out from the rest of the cars on the road.
Old 11-03-2016, 11:05 PM   #19805
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
I hear ya.. but you're also trying to mod one of the most modded tuner cars on the road.
Keep it clean, avoid mud flaps, get real wheeels, and lower it correctly.
fancyfootwork15 is offline   Reply With Quote
Old 11-03-2016, 11:28 PM   #19806
OpFox
Member#: 447104
2011 Impreza 2.5i
Spark Silver Metallic
Originally Posted by DMBrown View Post
What lip is that?
It's the STi V-Limited Lip for this bumper.
Depends how much money you are willing to put into it. You can mod lips for WRX/STi to fit (it's a cheaper option), or you can get any 08-10 wrx body parts, aftermarket or otherwise.
Of course, also get some wheels and suspension. If you want some power/ sound, get a nice panel filter (and if you want, pop out the milk just like I did on mine). Exhausts for 08-10 WRX's fit as well but will sound ricey if not resonated.
It's really up to you on how you want it to look, so not many advice other than what I just gave you. Drive the car to its potential, learn the characteristics of awd (understeer/ stability). It also doesn't make its stock, bland looks better.
Also does anyone know if all 2011 base models came with the Fuel Consumption Info in the clock/ temp cluster? I could have sworn I had seen it when I bought it but after resetting the ECU by battery as well as the turn key on pos1 and hold the "=" button, I still dont have it. Maybe I was just crazy for thinking it had one in the first place.
OpFox is offline   Reply With Quote
Old 11-04-2016, 11:29 AM   #19807
fakewrx
Member#: 457502
2010 Impreza
Would a stock 11 wrx sedan front bumper fit or would i have to make modifications?
Old 11-04-2016, 04:33 PM   #19808
fallrisk
Member#: 453660
2008 Impreza 2.5i
Default 08 2.5i
Nope, just 08-10 were the slim bodies and have interchangeable pieces. 11 switched to the STi widebody style.
Anyway, '08 2.5i checking in here.
Current mods are:
Hybrid intake
Wrx midpipe
Borla muffler delete
Wrx suspension
Mishimoto rad hoses
Hella supertones
Blacked headlight housings
Rear lights smoke tinted (hate this, previous owner's idea)
Hitch (motocross)
Sti front/rear seats
Edit: 132k on the odo. Since hitting 100k I've only done oil, oil filter, cabin filter, cleaned air filter, iridium plugs, seafoam thru intake/gas tank/oil and installed the exhaust/hybrid..
Thinking of refreshing tranny/diff fluid, definitely need to do bushings, and it seems like I've still got the original radiator on. Never had any shifting problems though, running max life 5w30 and since i began running that (seems like previous owner used **** for oil) the care feels much better.
Never had a single issue except corrosion on a plug where it plugs into the ignition coil.. Should probably fix that first.
fallrisk is offline   Reply With Quote
Old 11-04-2016, 07:52 PM   #19809
Markuz93
Member#: 313137
2009 2.5i
Charcoal
"Also does anyone know if all 2011 base models came with the Fuel Consumption Info in the clock/ temp cluster? I could have sworn I had seen it when I bought it but after resetting the ECU by battery as well as the turn key on pos1 and hold the "=" button, I still dont have it. Maybe I was just crazy for thinking it had one in the first place."
Just reset your trip A or trip B and it will auto populate up there.
Markuz93 is offline   Reply With Quote
Old 11-05-2016, 01:21 AM   #19810
OpFox
Member#: 447104
2011 Impreza 2.5i
wow holy crap, did not know that. Got to see the fuel consumption for the first time since the first test drive! much appreciated!
Also, does anyone have any experience with Accessport and the 2.5i? I heard they stopped making them, but is it possible to use any accessport for 08-14 WRX and download the N/A maps elsewhere?
Old 11-06-2016, 11:19 AM   #19811
NaiSai
Member#: 457717
2008 Impreza 2.5i
Another 2008 2.5i owner here. It's the color blue that Subaru puts onto their base models. So far, I swapped out the OEM headers out with a 2004 WRX header. So far, I'm stressed about buying and wondering if 2004 WRX catalytic converters can fit because I don't have a front catalytic converter at the moment with a CEL.
NaiSai is offline   Reply With Quote
Old 11-06-2016, 11:25 AM   #19812
NaiSai
Member#: 457717
2008 Impreza 2.5i
My plans for my 2.5i is offroading. I want to try to lift it with F-XT suspensions, or just go with spacers, or even do both! I want to get 15in rims, preferably Method Race Wheels with Grabber tires. I want to upgrade the connecting rods and crank for more torque. As for the exhaust, I am struggling with a 2004 WRX header on an N/A 2008 2.5i haha. Send help.
Old 11-07-2016, 09:51 PM   #19813
OpFox
Member#: 447104
2011 Impreza 2.5i
Typically they will need custom welding to get them collectors to fit the rest.
Old 11-09-2016, 03:42 PM   #19814
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Clutch rubber pedal started falling apart...
Always wanted those aluminum pedal in WRX & STI...
Front signal/parking light bulb was out...
Replaced w/ switchback dual color LED...
Old 11-10-2016, 10:31 AM   #19815
fallrisk
Member#: 453660
2008 Impreza 2.5i
[IMG]http://i253.photobucket.com/
Where'd you grab those pedals from?! I'm dying to get a set and haven't bothered to figure our id they can be changed to the WRX/STi style.
Old 11-10-2016, 12:18 PM   #19816
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Clutch & brake pedals (part no. 36024FA010) are just cover... Accelerator (part no. 36010AG150) is the whole DBW unit but still very easy... 2 bolts & unplug. Bought them off eBay. Clutch & brake pedal covers were new $35 for the pair and accelerator was used $30 (off 08-14 WRX/STI).
Old 11-10-2016, 01:04 PM   #19817
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
You didn't get the dead pedal? Tisk tisk.
JourdanWithaU is offline   Reply With Quote
Old 11-10-2016, 03:42 PM   #19818
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
^I tried to search for OEM part no. but can't find it... I don't want aftermarket one... :/
Old 11-10-2016, 04:43 PM   #19819
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Yeah... I can't find a part number for it. That's weird. Now I'm starting to question if I have an aluminum dead pedal... I gotta go look.
Old 11-13-2016, 11:54 PM   #19820
subaaawooo
Member#: 458077
Any front lips for 2011 2.5i Impreza hatch?
subaaawooo is offline   Reply With Quote
Old 11-14-2016, 12:21 AM   #19821
OpFox
Member#: 447104
2011 Impreza 2.5i
Has anyone run spacers on these cars? what is the max before you have to get longer studs? 3-5mm?
Old 11-14-2016, 08:17 PM   #19822
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Yes. Subaru made 2 front lips for 2.5i... both aren't cheap:
Front underspoiler (part no. E2410FG000) MSRP $275
This one is painted matched as bumper
STI front lip spoiler (part no. E2410FG100) MSRP $369.55
This one is just black plastic unpainted w/ a little shiny 'STI' plate
Other cheaper options? Of course...
DIY garage door lip
Modified BaysonR 08-10 STI front lip
There's also aftermarket version of front underspoiler from eBay, but still have to paint it to match your bumper. Here's one belongs to KartRacer3
3mm is the max on stock studs. Any good reason to run spacers? If not, get the wheels w/ proper offset.
Old 11-14-2016, 08:23 PM   #19823
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
I've been driving without DRL... Wanted DRL back but not with the high beams.
Old 11-15-2016, 08:21 AM   #19824
fallrisk
Member#: 453660
2008 Impreza 2.5i
I'm thinking of trying the fog light DRL mod in these upcoming weeks, hate using the high beams as DRL.. Awful design FTL.
Old 11-15-2016, 09:33 AM   #19825
dirkwitty
Member#: 439907
'09 OBS 5MT
I dig those lights a lot, Fendy. They look like they belong there unlike the full LED bar that is taking over the world right now.
dirkwitty is offline   Reply With Quote
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 10 08-22-2017 01:30 AM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 12:57 PM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 10:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 03:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 03:35 PM
