Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 05-20-2014, 05:49 AM   #51
AZRally
Member#: 103491
2016 Now: 16 WRX Ltd
Was: 06 STI x 2; 15 WRX
How does the beam patten cut-off look with the aftermarket bulbs on your low-beams? Is it sharp like the stock LED headlights? Could you post some pics. Also, does it seem like the light is being focused in the correct area (IE did changing your bulbs from factory sized to HID sized mess with the way the projectors pick up and send the light.)
AZRally is offline   Reply With Quote
Old 05-20-2014, 08:58 AM   #52
vdxgzhen
Member#: 391345
extra space for goodies
vdxgzhen is offline   Reply With Quote
Old 05-21-2014, 01:11 PM   #53
Bellipotens
Member#: 380646
2015 WRX Premium CVT
Went to AMR Mastertuner yesterday. I have my car in the Ecutek system. Will do the tune the following weekend. Put in the HKS funnel and changed oil while I was there. Will post once I get the tune
Bellipotens is offline   Reply With Quote
Old 05-21-2014, 01:59 PM   #54
AWsleeperWRX
Member#: 298969
2018 WRX
Only Blue that Matters
dayyymmnnnn
AWsleeperWRX is offline   Reply With Quote
Old 05-21-2014, 02:02 PM   #55
jonfaiella
Member#: 389749
2015 WRX
Are you worried at all about your warranty, tuning this early after buying your car?
jonfaiella is offline   Reply With Quote
Old 05-21-2014, 02:31 PM   #56
uspopo
Member#: 317014
2017 Crosstrek
ISM
Was the HKS Intake funnel a straight bolt onto the airbox or did you have to do some cutting/fabrication?
uspopo is offline   Reply With Quote
Old 05-21-2014, 03:22 PM   #57
Perscitus
Member#: 378214
Bolted right up - PnP.
Careful with the flange that clips into the same clip that helps hold the stock milkjug (intake resonator chamber).
The reason for this is the HKS funnel mold for this piece is much thicker and fit is so snug it can easily snap (ask us how we know).
Even without it - once inserted and rotated into plate, the funnel isn't going anywhere - even under full boost. But just to be safe, we used a self-tapping screw and washers to secure the flange to the front section of the airbox.
Perscitus is offline   Reply With Quote
Old 05-21-2014, 03:28 PM   #58
Perscitus
Member#: 378214
Not really. We're not going for an engine re-build, Stage 2+, race gas or E85 tune. Just a vanilla Stage 1 tune with no mechanical modification other than stock/port-installed CBE on the exhaust side, drop-in filter and funnel on the intake side. Probably won't even raise peak PSI - no need on a turbo as small as the one on this FA20DIT. Its already strained as-is.
If anything, the tune will be a whole lot safer than the factory settings (even with learning), re-scaled MAF (to account for the intake changes), leaner (read: NOT lean) AFR (its rich in way too many places right now bone stock), improved ignition and timing, boost maps, adjustments to account for IDCs (even more important here on a boosted DI engine).
If the car ends up making more low-/mid-range torque - great.
Couldn't care less for peak HP gains or any aggressive settings that call for AKI100 gas or E85.
Does it potentially* void warranty - sure. But will it keep the engine 'happy' to a point we doubt we'll ever need warranty engine work - yes.
*I doubt anyone doing warranty work on a suspension component or something in the cabin will check or need to check the ECU. If they do, oh well... next dealership.
Old 05-21-2014, 04:27 PM   #59
uspopo
Member#: 317014
2017 Crosstrek
ISM
Thanks!
Old 05-22-2014, 09:55 AM   #60
-vanguard-
Member#: 379708
2015 WRX Limited Nav
Which wipers did you get and what size?
24x16 or 26x16?
-vanguard- is offline   Reply With Quote
Old 05-23-2014, 08:49 AM   #61
Bellipotens
Member#: 380646
24x16 or 26x16?
24 and 16.
Bosch Icon 24A and 16A is what I have
Old 05-23-2014, 02:31 PM   #62
intence01
Member#: 389409
2017 STI
WRB, '15 DGM WRX RIP.
Bellipotens, what kind of paint did they use for the headlights? Matte, Satin, or Gloss? I like how yours aren't completely blacked out (especially the projectors), did they paint behind the c-lights, or did you leave that silver?
intence01 is offline   Reply With Quote
Old 05-23-2014, 02:36 PM   #63
Redeemed77
Member#: 378138
2022 WRX
He can correct me if Im wrong, but as far as the C Light he told them not to paint that part to reflect more. Great thinking!
Redeemed77 is offline   Reply With Quote
Old 05-23-2014, 03:57 PM   #64
Bellipotens
Member#: 380646
They used semi-gloss black paint. What Redeemed77 said is exactly correct - I asked them not to paint the chrome part under the c-light in order to help better reflect the light - in my opinion it definitely helped. The c-light fills better with light now compared to before.
Old 05-23-2014, 04:43 PM   #65
intence01
Member#: 389409
2017 STI
You also didn't paint the round area around the H11 projectors right? Yours look good, don't completely dark.
Old 05-24-2014, 09:44 AM   #66
Bellipotens
Member#: 380646
That is what I wanted. All depends on the look you are going for. I wanted to keep it a bit JDM style. Painting the entire light, especially on a dark color like DGM, just hides the highlights the car has to offer.
Old 05-26-2014, 01:43 PM   #67
gizmo0034
Member#: 386893
2. Custom Volume Control Knob for Kicker Sub-woofer - Amazon.com: PAC LC-1 Remote Amplifier Level Controller: Car Electronics
Great thread man, I have a question about your kicker sub volume control. I think this is a great idea but is it a direct plug and play? I didnt think the oem kicker subs used RCA cables. If it's not, do you think you could give a quick explanation on how you spliced it in?
gizmo0034 is offline   Reply With Quote
Old 05-26-2014, 03:57 PM   #68
Nocturnal84
Member#: 294596
2011 Sedan
WR Blue
I am still undecided on how I feel about the 2015 models.
Nocturnal84 is offline   Reply With Quote
Old 05-26-2014, 04:01 PM   #69
Redeemed77
Member#: 378138
2022 WRX
^Go see one in person, drive it, check out the interior, remember it's more fuel efficient and out handles the previous generation, more rear seat space, etc....but if you are not convinced then enjoy your 2011...nothing wrong with that.
BTW, if you serve...THANK YOU!
Old 05-26-2014, 06:33 PM   #70
Bellipotens
Member#: 380646
I had a guy do it in a shop near me. It was not plug and play. Routed the wires under the plastic door sill pieces to the trunk. Link to the items I used can be found on first post of this build thread - This was what he used: http://www.amazon.com/PAC-LC-1-Remote-Amplifier-Controller/dp/B0002J226O?tag=53361059562-20
Old 05-26-2014, 07:10 PM   #71
userduo
Member#: 385733
Can I get a link to where you purchased those clear turn signals?
userduo is offline   Reply With Quote
Old 05-28-2014, 01:52 AM   #72
diet
Member#: 295900
2015 WRX
World Rally Blue
Damn those wheels are pure sex on your WRX.
diet is offline   Reply With Quote
Old 05-28-2014, 01:57 AM   #73
diet
Member#: 295900
2015 WRX
World Rally Blue
By the way...what did you use to plug in the license plate holes in the front?
Old 06-03-2014, 03:16 PM   #74
Bellipotens
Member#: 380646
Plastic push in rivets (My friend owns a car shop and has a ton of them - Looked around and picked the best one that fit).
Old 06-04-2014, 12:30 AM   #75
jonfaiella
Member#: 389749
2015 WRX
Go to Home Depot or Lowe's, and look in the nylon fastener drawers in the hardware department. I found mine there - I believe they were 3/8" (but I'm drunk right now so I might be wrong lol).
