10-07-2012, 02:22 PM | #1 |
Member#: 313392
Vehicle:2006 STI Dark Gold |
Broke a Sensor and forgot wire placement. Please help!!!
Hello, I just finished putting my engine back in yesterday and I am almost done with everything but i broke this horribly placed sensor and have no idea what its called. It was bolted right under the intake manifold next to the turbo inlet hose.
Is it possible to run the car smoothly without that sensor using the bipass shown? I also have a yellow wire coming off the firewall and I forgot where it goes.
10-07-2012, 02:48 PM | #2 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
That's the purge control solenoid. You can run the car without it but it will probably throw a CEL. You can find used ones for pretty cheap. It's part of the fuel evap system you could bypass it or vent it to atmosphere. Not quite sure what bypassing it without a valve would do. A new one is about $100.
That yellow wire looks pretty beefy, it's probably the starter wire. Is your starter hooked up? I can't remember offhand and I'm too lazy to look. |
10-07-2012, 02:54 PM | #3 |
Member#: 313392
hmm I am not sure on how to bypass the solenoid correctly and i will check the start again.
10-07-2012, 03:02 PM | #4 |
Member#: 217563
South East
Vehicle:2006 Sti 12.68 @ 108 321WHP 422WTQ dynojet SAE |
To by pass the evap purge solenoid, plug off the vacuum hose going to gas tank and loop the ones on manifold.
I recommend replacing the sensor or your evap system wont purge the fumes. The yellow wire appears to be starter wire and it looks like you pulled the connector off. Car wont crank without it |
