Welcome to the North American Subaru Impreza Owners Club Friday July 20, 2018
Old 08-30-2006, 12:01 PM   #1
GD6Noob
Member#: 119979
2006 Impreza 2.5i
Default injectors? lgith weight flywheel
will there be any benifits to upgrade these?
would the STi ones fit?
again, would this be a good upgrade? or its just waste money? or i need to change a lot of other parts to really feel the diff like upgrading the clutch aswell?
GD6Noob is offline   Reply With Quote
Old 08-30-2006, 12:04 PM   #2
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
Is yours a push or a pull style clutch? The WRX's use pull type, and the flywheel isn't interchangable with the push type found on older models.
t3hWIT is offline   Reply With Quote
Old 08-30-2006, 12:11 PM   #3
kaisersouse
Member#: 85900
2001 Forester S
im not sure...but i think w/ injectors you would need a beefier fuel pump and some type of engine management to tell the injectors to flow more gas. I dont think they will push more gas simply because they are installed. I could just be stupid tho.
kaisersouse is offline   Reply With Quote
Old 08-30-2006, 02:08 PM   #4
GD6Noob
Member#: 119979
2006 Impreza 2.5i
i have the '06 2.5i so i have no idea what push or pull is...
Old 08-30-2006, 07:02 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Don't bother with injectors unless yours are bad or you need them. If you don't have any other engine mods then you don't need them.
The lightened flywheel on the other hand is an any time mod. You don't need to have any other modifications to do it.
Tim Sanderson is offline   Reply With Quote
light weight crank pully + light weight flywheel = problems? ~Touge/Wangan- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-10-2010 08:51 PM
Sugestions Please - light weight flywheel & clutch pkg rsr911 Transmission (AT/MT) & Driveline 22 08-22-2002 11:48 AM
Light weight flywheel question Dolphin Overton Normally Aspirated Powertrain 7 10-03-2001 04:22 PM
Light weight Flywheel goobie Transmission (AT/MT) & Driveline 14 09-02-2001 12:42 PM
Questions: Engine ticking/warranty, and light weight flywheel Ru fan New England Impreza Club Forum -- NESIC 4 08-08-2001 06:09 PM
