#1 |
Member#: 95027
![]() I know the 2008+ STi hubs are a direct swap in the rear but what about the front? What ca we do there? I'd love to run STi Brembo brakes and have a much better wheels selection without trying to redrill rotors, etc.
#2 |
Member#: 178811
Vehicle:2011 White Corolla Over 400hp |
![]() Front 2004+ Brembos bolt up with a 2004 rotor, just need to swap bleeders from top to bottom. Rear 2008+ Brembos bolt up with a redrilled rotor...which is cheaper than a hub conversion. Rear 2004-2007 Brembo bolts up with an adapter.
Want Brembo brakes? I sell you mine! |
#3 | |
Member#: 95027
![]() Quote:
I'm sure if I'm patient something will pop up for the STi Brmbos and I can get a hell of deal tho. I just don't like the idea of a re drilled rotor.. Sounds half assed. Whatever I do needs to fit under 17*9 +45 RFP1's |
#4 | |
Member#: 217201
Vehicle:2004 STi Silver |
![]() Quote:
#5 |
Member#: 178811
![]() KNS Brakes and Mach V sell a bracket that will properly locate gold Brembos on 08+ rear hubs; given that our bolt spacing is the same as the WRX, this bracket should work. Whether or not you need to modify it, I have no idea.
#6 |
Member#: 178811
![]() Not sure STI Brembos will clear 17x9 +45 RPF1. Not seeing it as an option on Tirerack or 5x100 or 5x114 nor in the old STI wheels/brakes thread. I think some of the people with 17x9 RPF1 were having issue with the AP Racing sprint BBK...so fatty STI calipers probably won't fit.
#7 | |
Member#: 95027
![]() Quote:
#8 |
Member#: 253998
Vehicle:13 BRZ SWP |
![]() Why put brembo's on a 2800 lbs car??? pads, rotors, lines, fluid, done. Drop weight maybe.
#9 |
Member#: 95027
#10 |
Member#: 44501
Vehicle:that 's, like, your alternate facts, man. |
#11 |
Member#: 95027
![]() Orbital, according to TireRack a 17x8+45 fits a 2007 STi, going to a 17x9+45 shouldn't change that, I'm sure a 9" wide wheel just doesn't fit on a STi.
http://www.tirerack.com/wheels/Wheel...&sort=Diameter |
#12 | |
Member#: 178811
![]() Quote:
I understand a BBK is overkill, but I ended up with an AP racing kit that's lighter than the stock setup so the rotational mass argument is a moot point. Would I put STI Brembos on the car? Not unless I got them cheap or had them on hand. My setup from the WRX is disassembled and unpainted...I really didn't want to mess with them or buy 2pc rotors for them. Which is funny considering the AP kit is 2pc rotors; though cheaper than the DBA 2pc rotors. |
#13 | |
Member#: 289693
Vehicle:2013 BRZ Sterling Silver Met. |
![]() Quote:
It's very important and so is chamber and diameter. Alot more goes into choosing a wheel then just size and weight. |
#14 | |
Member#: 253998
![]() Quote:
#15 | |
Member#: 253998
![]() Quote:
#16 | |
Member#: 95027
![]() Quote:
Yes, something like 1 lb. of rotational weight being worth 4 lbs. of static weight isn't it? |
#17 | |
Member#: 253998
![]() Quote:
I'm doing SS lines ATE super blue and stop tech pads... if it eats the rotor which I doubt since its a wrx brake then I get better material rotors but drilled and slotted lowers the life disproportionately to the gains in performance. |
#18 | |
Member#: 95027
![]() Quote:
I've decide, initially I will go with two piece slotted front rotors (stock size), hawk pads, slotted rear rotors, braided lines, and good fluid, about half the price of a bbk and should perform nicely for my uses. And I'll just paint the stock calipers, yellow of course. I'm going to do the paint immediately after delivery. Because race car. Should I later determined that that's not sufficient then I'll probably look back into a bbk or/also hub swap. |
#19 |
Member#: 253998
![]() Keep in mind this car is over 600 lbs less than an STI so unless you really up the weight or power or both brembos are overkill. Doesn't mean they won't work or look sweet but then you're using specific wheels again.
Not the direction I'm going. Which is lighter with exhaust intake and custom tune. Keep it fun and predictable. |
#20 |
Member#: 253998
![]() Yeah I was just offering up that my wrx with those additions made a large difference and it weighs over 400 more and worse balance than the brz.
I would assume the stock pads are just made for daily not anything aggressive. If you read the track reviews you'll notice that while they weren't great it wasn't nearly the issue the wrx has... |
#21 |
Member#: 253998
![]() Yes closer to stock is better... I honestly wouldn't go wider than 8.5 or push the offset out any wider than absolutely necessary... it handles great don't ruin it for overall grip.......
#22 |
Member#: 159474
Vehicle:2017 Impreza Sport Lithium Red - OLDKID |
![]() Found the source of the problem: RPF1's.
#23 |
Member#: 289693
![]() I agree and if you notice most professional shops are going 17x8, I am going to say there is a reason for that.
#24 | |
Member#: 253998
![]() Quote:
I traded for 17x7.5's. Slightly taller than stock since 225/40's don't really exist but I lost 4lbs of wheel weight. |
#25 |
Member#: 95027
![]() Guess what I'm doing tomorrow evening.....
