Welcome to the North American Subaru Impreza Owners Club Monday January 20, 2020
Old 09-05-2019, 12:25 PM   #1726
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
no694terry is offline   Reply With Quote
Old 09-15-2019, 05:18 AM   #1727
Skubisnacks
Member#: 442028
2015 WRx
Ice Silver
2015 WRX stage 3+ kit, catted j-pipe, charge pipe, CBE, TGV/EGR deletes, D300C FP.
3rd gear pull from 2500ish rpm on 93oct.
Tuned by Dank Tuning.
https://datazap.me/u/rubyblack/wot?log=0&data=5-19
Skubisnacks is offline   Reply With Quote
Old 09-18-2019, 05:39 PM   #1728
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
Looks like a pretty safe tune. what octane fuel? Everything looks clean though.
ShinjiML is offline   Reply With Quote
Old 09-18-2019, 06:47 PM   #1729
ryoji
Member#: 506512
Pretty sure something going on. should be hitting 15-16 psi on my cobb stage 1 + SF tune... boost leak?
https://docs.google.com/spreadsheets...it?usp=sharing
ryoji is offline   Reply With Quote
Old 09-25-2019, 09:38 PM   #1730
Delphi
Member#: 239335
Well here is one for you guys. Dyno Tuned by Airboy Tuning. Car is awesome, I love it.
S257-SXE with a T3 0.63 Single Scroll Hotside with a Rotated Turbo Pedestal
Built Motor
Stock Heads
IAG Fuel Rails
AEM 340 Pump
Aeromotive FPR
Tomei ELH
40mm Turbosmart EWG
Fast Motor Sports FMIC
6 Speed Swapped
Fuel 94oct + Meth
Here is the Log, pull was slightly up hill
https://datazap.me/u/d-e-l-p-h-i/4th...og=0&data=6-19
Here is the VD
https://i.imgur.com/fqCxEcA.jpg
Here is a 2,3,4 Log
https://datazap.me/u/d-e-l-p-h-i/234...og=0&data=6-19
Gotta say Airboy is the man, maybe I will bug Airboy to turn up the wick slightly next year since it hasn't rolled over yet.
Delphi is offline   Reply With Quote
Old 09-26-2019, 09:26 AM   #1731
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
Built Motor
Stock Heads
IAG Fuel Rails
AEM 340 Pump
Aeromotive FPR
Tomei ELH
40mm Turbosmart EWG
6 Speed Swapped
Fuel 94oct + Meth
Here is the VD
Here is a 2,3,4 Log
2.5 engine?
Fuel? The log shows an ethanol parameter, but your post says 94+ meth?
Great numbers for 26psi! I have the same turbo and pedestal, but only running 20 psi on a stock ej205. Canít wait to see what it does with my built engine soon.
RavensFan7 is offline   Reply With Quote
Old 09-26-2019, 09:55 AM   #1732
Delphi
Member#: 239335
Yeah 2.5L
Fuel is 94 Octane + Meth. The reason why it shows ethanol is because I am using the flex fuel tables to change between pump gas and Pump + Meth maps seamlessly and as use that as part of the failsafe functionality. So when I turn on meth the ECU sees 5v on one of the unused TGV plugs telling the ECU I have "100%" Ethanol so there is no Map Blending done just straight to the methanol boost, fuel, and timing tables. When off the meth is off and the ecu sees 0v so it just runs on pump gas.
Turbo has a bit more to give I think, on the dyno my tires held me back on the dyno dynamics, side wall was deflecting more and more under the torque and not giving accurate power numbers.
Old 09-26-2019, 12:40 PM   #1733
RavensFan7
Member#: 346388
SRP
Yeah 2.5L
Ahh interesting. Iíve wanted to do something similar for a while with 93+meth or 93 and 100+.....but until I switch to Carberry no flex fuel/map switching for me.
So you donít think the 0.63 hotside is choking it up top? I was worried about how far I could push mine, but almost 500whp on a 2.5 makes me feel a lot better. Iím shooting for 400-450 on 93 with a 2.0, so I should be good.
Old 09-26-2019, 01:25 PM   #1734
Delphi
Member#: 239335
Originally Posted by RavensFan7 View Post
Ahh interesting. I’ve wanted to do something similar for a while with 93+meth or 93 and 100+.....but until I switch to Carberry no flex fuel/map switching for me.
So you don’t think the 0.63 hotside is choking it up top? I was worried about how far I could push mine, but almost 500whp on a 2.5 makes me feel a lot better. I’m shooting for 400-450 on 93 with a 2.0, so I should be good.
Since I don't have e85 and cams I feel the 0.63 hotside is working out quite well (I mean its basically a 3576 sized turbo hitting 20psi at 3800 rpm). WGDC is less than 50% and its holding 26-27lbs all the way out.
For what its worth it Dyno'd 415 whp on a dyno dynamics dyno (heart breaker) at 3500ft above sea level. That was with a lot of tire deflection (roller speed on dyno was a nice deflected line, not linear which means the car wasn't transmitting the work done). Off meth it did 365whp on the dyno, I ran a 12.2 on my first pass straight off the highway on the pump gas tune at 114.8mph (DA was 6300ft that day Ouch). Then it rained right after that and I haven't gone since.
https://i.imgur.com/mTp94O2l.jpg
Old 09-27-2019, 05:51 AM   #1735
Skubisnacks
Member#: 442028
2015 WRx
Ice Silver
Sorry, I just saw this. It has been done on 93. I talked with him a week ago and he said to drive on it for a while. I just had my clutch replaced so I'm on the break-in period with it now. Once I move past that we'll push the car further. thanks for the input.
Old 09-27-2019, 09:37 AM   #1736
RavensFan7
Member#: 346388
SRP
Having a 2.0 should help me a little, but it will have cams (272s). Iíll keep an eye on it. Should be easy to tell in logs if itís choking up top, but I think Iíll be fine.
I just want 400whp on 93 for now. It probably wonít be dynoíd, so Iíd be happy just seeing 400+ g/s in my logs. Probably start with 25psi and see how close that gets me.
Old 10-08-2019, 11:06 PM   #1737
WRX56
Member#: 507094
Anyone ever figure this out? Seems messed up.
Originally Posted by Waltm View Post
Hi guys. Replace a totaled Legacy GT with a WRX and just got an Accessport. Not sure about some numbers so thought I'd post the log.
2015 WRX 6MT Stock
3rd gear pull
Cobb OTS Stage 1 93 octane map
Mobil 93 octane fuel
Installed AP and flashed, some around town driving then logged pull. Getting -5.62 fine knock and -1.41 feedback knock, higher fbk at part throttle on a longer log.
There was a noticeable loss of power around 5000-5700rpm where the fine knock pulled timing. Loaded the 91 octane map for some piece of mind for now since I'm not sure what is going on.
If anyone has any input I'd love to hear it since I'm not sure what to make of this. This is just the WOT part of a longer log that I can upload if more data is needed.
https://datazap.me/u/waltm/log-15527...data=5-6-12-27
3rd gear pull
Cobb OTS Stage 1 91 octane map
Shell 93 octane fuel
https://datazap.me/u/waltm/log-1552915079
3rd gear pull
Cobb OTS Stage 0 map
https://datazap.me/u/waltm/log-1552915173
WRX56 is offline   Reply With Quote
Old 10-09-2019, 05:25 PM   #1738
kgharrin
Member#: 501826
2019 STI
WR Blue
Default Post up your WOT logs!
Deleted.
kgharrin is offline   Reply With Quote
Old 11-22-2019, 12:44 PM   #1739
JoeRice
Member#: 507520
Could use a bit of advice on smoothing this car out if anyone can point me to some references on tuning the DIT. She drives OK, but has a bit of fine knock and the boost isn't too smooth.
https://datazap.me/u/joerice/1122-4t...0&data=5-22-25
4th Gear
TGV Delete
3" Catless
JoeRice is offline   Reply With Quote
Old 01-14-2020, 02:03 PM   #1740
86Dreams
Member#: 385256
V7 S204
'19 Giulia Q4
does anyone ever encounter this situation?
You pull in one gear, change gears and HP seems to climb up slowly instead of going back to where it was?
There is not much difference in state between the two pulls. The boost graph is replaced with MAF so the motor is pumping the same amount of air. Boost in 4th was a little higher by <1 psi. road was flat in both pulls.
86Dreams is offline   Reply With Quote
Old 01-14-2020, 03:52 PM   #1741
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
HP is a side affect of torque, wheel torque will show up lower and slower as wheel speed increases. Heres an old graph of mine on a dyno, showing 3rd and 4th gear pulls
Old 01-14-2020, 04:49 PM   #1742
86Dreams
Member#: 385256
V7 S204
'19 Giulia Q4
Thanks for the graph and information. Im not sure thats whats happening in this instance tho. The difference in power is pretty dramatic in my case, and theres definitely a 'shape' to the way the power comes back.
heres another graph, you can see a similar shape. here the difference in peak between red and blue is probably grading of the road.
I have a vlsd open front sti trans, I am starting to wonder if maybe the center diff free wheels a little before transfering all of the torque to the wheels.
