Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 01-18-2017, 11:45 PM   #276
martin028
Member#: 401669
2002 WRX Wagon
Just to report in, I posted probably a year ago at this point about trying to make this work with Accesstuner race and an ap map. Haven't given up yet but also haven't tested. If I get the time and balls to test, I'll let everyone know what I did
martin028 is offline   Reply With Quote
Old 01-19-2017, 03:44 AM   #277
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Originally Posted by AudioRuso View Post
I would like to add another bit of knowledge:
Even higher boost levels can be achieved by adding a 3 port solenoid that will either bleed off the boost source from the waste gate back to intake when Anti-Lag is active OR to the top port on an EWG setup to keep the Wastegate shut while Spooling with Anti-Lag engaged.
Bear with me on this, I'm making this up as I go along...
My ROM has a compensation table that modifies initial and max WGDC based on IAT. If your does too, can you set the coldest-IAT cells to a very high value, and thus hold the wastegate closed? I'm not sure this would work with the stock boost control solenoid, but I think it should work with an aftermarket BCS.
Old 01-19-2017, 04:22 AM   #278
AudioRuso
Member#: 440196
2008 WRX
^^ killer thinking! Much cleaner solution! If these do exist for my year, this would absolutely work on both stock and aftermarket boost control and wastegate setups including external wastegates. I say this because if you simply unplug the vac line from any wastegate, you will overboost.
*opens up RomRaider*
Yes, on my year (this will apply 08-14, and likely 06-07 too) the table exists and by the looks of it will work just as expected.
Thanks for the tip! Will try and report soon!
Although I gotta admit I'm a little bummed to not get to insert a solenoid and move air around :-P
AudioRuso is offline   Reply With Quote
Old 01-24-2017, 04:24 PM   #279
AudioRuso
Member#: 440196
2008 WRX
I'm reporting back on this idea. Although it was amazing in concept, it doesn't work in practice. I think I will go back to the solenoid idea (if I do at all).
The reason is that the WGDC IAT Compensation is a percentage value, however it targets cells in the WGDC map which have almost zero WGDC values so even adding a 99% compensation (max) has pretty much zero effect on holding the wastegate shut.
I thought about slightly raising the WGDC there since it might not have much effect on the car anyway since without anti-lag on the car would not be able build boost in those cells anyway, but it is being more of a hack than I would like it to be so I think I'll let it be. Also I think it's possible to trigger those cells during rapid changes in driving where perhaps it could contribute to strange boost fluctuations as the wastegate momentarily opens and closes during those weird cells. Any thoughts?
Old 01-25-2017, 01:35 AM   #280
NSFW
Member#: 140444
05 Stage Free LGT
What's the RPM and throttle percentage in the cells where you use the anti-lag?
I'm guessing that if you're in an area where WGDC is near zero, then adding WGDC won't change anything when anti-lag is not on, since target boost in that area is probably way below what the wastegate spring provides on its own, and the airflow + EGT is probably too low to build more than wastegate boost. But I'm not real confident in either of those assumptions.
Old 04-07-2017, 12:16 PM   #281
martin028
Member#: 401669
2002 WRX Wagon
I have the wiring set up in my car. Trying to figure out the timing situation right now. By my math, I would need like -60* of timing.. That doesnt sound right. I am working with AccessTuner, but the values between that and romraider really shouldnt be different, should they? Does Cobb measure timing from a different spot? I am going to just try putting in the -27 value from the OP and see what happens. If this works, people with Accessports can have antilag on their cars!
Old 04-07-2017, 12:34 PM   #282
AudioRuso
Member#: 440196
2008 WRX
There is no timing difference between so and tactrix. To calculate mathematically you would have to take into account all other timing adjustments that the ecu applies, not just base timing. It is Probably easiest to do what you're doing now: try the -27 and monitor what the timing is with anti lag engaged. Then adjust accordingly.
Perepare for a lot of face grin. 😉👍
Old 04-07-2017, 01:04 PM   #283
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
I use approximately 20 deg of ignition retard on a standalone between 2000-5500 RPM quickly tapering off above and below my target RPM range. This is something that must be tuned (mine is not optimized) as you are affecting the flame front position in the exhaust manifold. Ideally, you want it further down the manifold so the expansion happens near the turbine wheel.
There are a lot of variables that go into anti-lag, including bypassed air, cylinder cutting, ignition retard, RPM, and throttle position. Passive (safety) variables include ECT and TIT (measured as EGT near turbine).
Good luck with that face grin... hope the turbo survives.
mrsaturn7085 is offline   Reply With Quote
Old 04-07-2017, 01:27 PM   #284
martin028
Member#: 401669
2002 WRX Wagon
Just curious to see if it will work really. I don't have any need of launching my car like that. Also, if the turbo does pop that means I have an excuse to tell my fiance that I need a weekend to swap in all the go fast parts from the car I wrecked
Old 04-07-2017, 02:16 PM   #285
Nemesis_STI
Member#: 325545
2006 STI
Martin028,
I have had this working on my 06 Sti Via AP for a few years now. Funny i wanted to check out this thread years later and im happy to see its still going!
My setup was:
06 STi
AMRT60R
EWG and MBC
Cobb Speed Density
I was able to tune the IAT comp cells by lowering the adjacent cells Temp values enough to achieve my -40 target value.
Once this was accomplished i turned my AP on monitored Intake temp and held my button down and watched the "temperature" sure enough it read -40*
Then I started testing by logging my IAT & IGN timing to see where id end up by pulling timing out of the IAT comp table. started off slow but now it was building 20psi ~-16-17* iirc. I never launched it like this but i have done many rolling anti lag raced and its literatly INSANE. theres no chill. best way to describe it is, it feels like your launching from a dead stop-even tho your rolling.
Ive since changed my setup to my own CNC'd closed deck with manley turbo tuffs, big cams and a forward facing 69mm BW turbo and I am not worried about lighting off this turbo with the cobb 2-step and this hack.
Ill see if i can pull up my old tune and shed some light on it for you
hope you gets yours working soon!
-Cheers
Nemesis_STI is offline   Reply With Quote
Old 04-07-2017, 03:19 PM   #286
martin028
Member#: 401669
2002 WRX Wagon
Hmm so right now I can get to - 17* when I push the button while in launch control mode, but it doesn't stay there for more than a second before returning to about 8* which I find weird. The max boost I could build was 9lbs, which isn't much of an increase from the 7 I get with Cobb's 2step
Old 04-07-2017, 07:36 PM   #287
AudioRuso
Member#: 440196
2008 WRX
Did you change the timing activation table?
Old 04-07-2017, 07:44 PM   #288
martin028
Member#: 401669
2002 WRX Wagon
For Cobb the only two iat related tables are timing comp and min activation load, which I bumped down to 0.30 from the stock 0.60. I can't imagine during 2 step the load would drop below that and stay low enough for the timing to come back up and stay up.
Old 04-07-2017, 08:54 PM   #289
AudioRuso
Member#: 440196
2008 WRX
What kind of car? I looked up an accesstuner table description list and it has the table listed, but I'm sure different ones exist on different years/ecu types.
Ignition Timing Compensation (Intake Temp) Activation
Old 04-07-2017, 09:30 PM   #290
martin028
Member#: 401669
2002 WRX Wagon
02 wrx
Yeah it has intake air temp ignition timing compensation, and iat compensation minimum engine load activation
Old 04-07-2017, 10:01 PM   #291
Nemesis_STI
Member#: 325545
2006 STI
Iirc there is a ign retard max table
Old 04-07-2017, 10:29 PM   #292
martin028
Member#: 401669
2002 WRX Wagon
"Rev Limit (Fuel Cut) Ignition Timing Retard"? It was set at -4.somthin. Changed it to -24.96 (maximum allowed by ATR).
I'll give that a shot tomorrow.
Thanks for the heads up.
Old 04-08-2017, 10:54 AM   #293
Nemesis_STI
Member#: 325545
2006 STI
Good luck bud
Old 11-23-2017, 05:17 AM   #294
boosted_rn
Member#: 441666
2015+ WRX (FA20DIT) will this work? Any potential tuning issues?
boosted_rn is offline   Reply With Quote
Old 02-02-2018, 10:40 AM   #295
Steverobinsonfxt
Member#: 473470
Default Resurrection
Hey guys,
Martin did you ever figure the tuning out on Cobb AP? I went out yesterday after reading the first 3 pages of the thread bought a switch went home opened my accesstuner and mines like yours only 2 tables for iat. I've got a 04 fxt auto with a vf39 and I can't build any boost off the line it's a dog. Any and all help would be appreciated!
Steverobinsonfxt is offline   Reply With Quote
Old 04-10-2018, 12:27 AM   #296
cchrisrollins
Member#: 357589
2013 WRX BASE
Dark grey
I am attempting to get this working with accestuner race (13wrx). What values need to be put in to the activation table specifically? I have no idea what to put in this table or where to put it as it's a 3D table . Any help would be appreciated. The A and B comp tables I'm good with though.
cchrisrollins is offline   Reply With Quote
Old 05-01-2018, 02:08 AM   #297
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Man, this was a painful thread to read. Started with interest and some talk, bunch of BS came pouring in where people don't understand that anti-lag can have a range of pedal movement based upon strategy, and then go into the typical land of the lost and fuzzy memories.
Anyway, looking forward to finally digging in on my ancient 16-bit ECU.
Old 05-01-2018, 02:42 AM   #298
AudioRuso
Member#: 440196
2008 WRX
Old 05-01-2018, 03:48 PM   #299
mrsaturn7085
Member#: 375462
WR Blue
Roll eyes at what? He's right, you know...
Old 06-20-2018, 01:50 PM   #300
UPPCOS
Member#: 364680
Wow, I don't get on here much, but funny to see people still asking/using this 5yrs later.
UPPCOS is offline   Reply With Quote
