Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 06-07-2018, 04:28 PM   #1
snow_bound26
Member#: 395793
2005 92x Aero
Default Need help understanding this software
So Iím trying to be able to flash an e tune. This is my first experience away from Cobb products and itís not as easy thatís for sure. I keep getting a ďcannot connect to ecu interfaceĒ message. Iíve tried connecting with the green connector and flash block connected and without. I have deleted everything and reinstalled my operating software (which finally allowed me to open the ecu and logger definitions, though logger still asks to download them even though they show up when itís opened) and reinstalled RomRaider and Ecuflash. I have a JDM 205 ecu with dbc single avcs that I am trying to connect to. I have emailed tactrix as well and have not received a response.
I am using Windows 10 32bit. Tactrix 1.3 cable. Already made sure it has pin 9. I need to save The ecu image, flash a manual rom onto it then flash the first e tune I was sent so I can start logging. What other info do I need to provide? Thank you in advance.
Any help is going to be greatly appreciated.
snow_bound26 is offline   Reply With Quote
Old 06-07-2018, 05:14 PM   #2
fenix-silver
Member#: 231700
2004 WRX Wagon
Are you able to connect with Romraider just to do logging and do you definitely see the tactrix cable connecting as a COM port?
fenix-silver is offline   Reply With Quote
Old 06-07-2018, 05:25 PM   #3
kopele
Member#: 363007
Do you see the Tactrix cable listed in the Windows device manager when it's connected to the laptop?
When you open EcuFlash does it display any errors?
Can you select your vehicle in EcuFlash and attempt to read the image?
Do you see your stock image here: http://www.romraider.com/forum/viewtopic.php?t=7591
If you find your image, open it with EcuFlash while connected and attempt to compare the image to the ecu or read from the ecu.
If RomRaider logger is asking for definitions make sure you have only one entry in the settings and it's in the correct location.
Have a look at this page:
http://www.romraider.com/Documentation/GettingStarted
kopele is online now   Reply With Quote
Old 06-07-2018, 06:08 PM   #4
snow_bound26
Member#: 395793
2005 92x Aero
I havenít tried to just log because I was under the impression that you had to get the ecu image first.
When I plug into the cable into the USB port it immediately sees the cable and reads which version it is.
Old 06-07-2018, 06:26 PM   #5
snow_bound26
Member#: 395793
2005 92x Aero
I have no idea what my stock image is or how to find it. Have been all over different forums trying to figure that out. Found the link you posted in one of my early searches and have no idea how to read it. When I was buying the engine I was using a link to ecu codes which pertains to the sticker and I have a 5Z 22611AH740 code on the ecu sticker. I have not been able to find anything on the ecu that correlates to the numbers on the above link.
??? When downloading the definitions it says put them where youíll find them and wonít move them. What is the correct location? I put them on my desktop to find them easily. I had deleted everything this morning, completely reset the tablet back to when it was purchased and started over making sure there was no trace of anything left. Originally when trying to start logger it would ask for definitions twice. Now it is asking for them once.
Read it a few times, twice today even. Nothing I have found has any mention of the proper sequence to do things. I feel like this is my problem, I have no idea what order to do things which means I have no idea what I should start with. When I was using my AP, where to start and what to do next were very clear. I understand this software is not easy for novices and that itís developed by people in their spare time but in my searching I havenít been able to find a tutorial that lists the steps in how to set up the interface. Itís mostly about how to download the programs, where to find the definitions and how to actually tune. Seems like thereís a whole lot in the middle to understand.
Old 06-07-2018, 09:31 PM   #6
kopele
Member#: 363007
I'm not sure about this, but the best thing I found was a Russian subaru forum referencing ECU ID 2E04404005 here. You can try to download its image from the RomRaider forum link above, open it in EcuFlash an try to compare to your ECU. Have you had any success with EcuFlash?
There is no wrong place to put the definitions, you just need to tell RomRaider and Logger where the definitions are. In RomRaider go to ECU Definitions > ECU Definitions Manager and if it's blank add an entry pointing to the location of the definitions. In Logger go to Settings > Logger Definition Location or hit CTRL+D. You can find these steps in the pages where you got each of the definitions files, they are linked in the Getting Started page above. There's a lot of helpful information in the RomRaider FAQ as well.
Old 06-07-2018, 09:46 PM   #7
snow_bound26
Member#: 395793
2005 92x Aero
Thank you for the help. I am going to try again in the morning. Had to stop before I tried to put the tablet through my windshield.
I had read through most of the FAQs but reviewing them again there are some things I missed. I will sit down with them in the morning and be more thorough. That Russian reference isnít the first Iíve come across doing this project. Just wii cold translate it all. But Iím going to check the numbers with the ecu definitions and see what I can figure out. Thanks again. Iím sure Iíll have more questions.
Old 06-08-2018, 10:19 AM   #8
kopele
Member#: 363007
Here's the image based on ECU ID 2E04404005: A4TE000A. Only use it as a starting point and try to read your ECU after you open this image in EcuFlash. Do not flash it to your car without knowing what's in it.
Old 06-08-2018, 10:48 AM   #9
snow_bound26
Member#: 395793
2005 92x Aero
Thanks. I was going to pull that one up this morning and use it as a comparison. Only thing I'm planning on flashing is the initial e tune I got from IA.
Old 06-08-2018, 11:51 AM   #10
86Dreams
Member#: 385256
V7 S204
Before you flash anything pull your stock image to test that everything is working correctly. both sets of test blocks, Plug the tactrix into your car. open ecuflash and click the blue up icon to read image. it will give you a box that asks if youre ready then you need to turn the ignition to the on position and hit the button right after.
The read image will have your ecu id.
flashing will be almost the same.
Romraider.com has an entire section of stock images that you can download and look at.
86Dreams is offline   Reply With Quote
Old 06-08-2018, 02:56 PM   #11
snow_bound26
Member#: 395793
2005 92x Aero
Ok so ended starting from scratch again this morning and uninstalled all Ecuflash and RomRaider software and associated files. Restart computer. Reinstalled Ecuflash and RomRaider. Restart computer. Download Ecuflash ecu definitions and replaced what was in installation package. Now when I open Ecuflash and click on the vehicle it’s not giving me any choices. The task box is empty.
I tried to get a connection to log as well and nothing is working. Flashes no ecu at the bottom of the screen. When I open Ecuflash it immediately recognizes the cable. No f******* idea what is wrong with all this and can’t find anyone local to give a hand. Wish Cobb would support JDM.
Old 06-08-2018, 03:07 PM   #12
kopele
Member#: 363007
Ok so ended starting from scratch again this morning and uninstalled all Ecuflash and RomRaider software and associated files. Restart computer. Reinstalled Ecuflash and RomRaider. Restart computer. Download Ecuflash ecu definitions and replaced what was in installation package. Now when I open Ecuflash and click on the vehicle itís not giving me any choices. The task box is empty.
I tried to get a connection to log as well and nothing is working. Flashes no ecu at the bottom of the screen. When I open Ecuflash it immediately recognizes the cable. No f******* idea what is wrong with all this and canít find anyone local to give a hand. Wish Cobb would support JDM.
In Logger did you try to reset the connection? Are any ports listed in the COM dropdown?
Were you able to read your ecu image in EcuFlash?
Old 06-08-2018, 03:07 PM   #13
fenix-silver
Member#: 231700
2004 WRX Wagon
Try running both apps as an admin.
Old 06-08-2018, 03:19 PM   #14
snow_bound26
Member#: 395793
2005 92x Aero
Doing that and figured out why I wasn’t getting a vehicle selection. I have that back but still can’t connect to vehicle
Old 06-08-2018, 03:34 PM   #15
snow_bound26
Member#: 395793
2005 92x Aero
I tried to reset the connection, even went as far as shutting everything down, restarting the computer and trying again. Still nothing. If the cable is bad, would ecuflash still be able to recognize it? I bought it used, there's always the chance I got burned. But to me it seems like the program wouldn't see the cable if it were toasted.
Old 06-08-2018, 03:35 PM   #16
snow_bound26
Member#: 395793
2005 92x Aero
I've been running the software as admin. Is there an option to download it that way? Or is it just selectable when you open the program?
Old 06-08-2018, 06:03 PM   #17
kopele
Member#: 363007
Is there anything in the EcuFlash log window? Does it try to connect or everything is grayed out? Can you post any screenshots?
I would think if your computer sees the cable and has it listed in Device Manager that EcuFlash should see it also. I have a 2.0, not a 1.3 so I'm not exactly sure.
Old 06-08-2018, 07:45 PM   #18
snow_bound26
Member#: 395793
2005 92x Aero
The box with the blue arrow lights up and has make/model/etc that I selected based on my ecu. When I click on that it says cannot interface. It’s the same message I’ve been getting since day 1 of trying this. I’m done. I’m going to have to eat the cost of the e tune and find a tuner locally.
Old 06-08-2018, 10:00 PM   #19
kopele
Member#: 363007
The box with the blue arrow lights up and has make/model/etc that I selected based on my ecu. When I click on that it says cannot interface. Itís the same message Iíve been getting since day 1 of trying this. Iím done. Iím going to have to eat the cost of the e tune and find a tuner locally.
Sometimes I get this message and I'll turn the car key off for a few seconds, then back on and try again. But I feel if your problem was this simple it would've worked at least one of the times you tried. There's really no good way to troubleshoot this remotely.
Old 06-08-2018, 10:12 PM   #20
snow_bound26
Member#: 395793
2005 92x Aero
Unfortunately thatís the way it seems. At this point I just donít think itís something simple. Iím not good with computers but I can usually figure it out. Iíve never spent so many hours repeating the same process without having the results change. I know my OBD port is fine I had no problem with my AP before doing the engine swap. I know the JDM ecu works because the car starts and runs. From everything Iíve read windows 10 works with this software. Only thing left is a bad cable it seems.
Old 06-09-2018, 08:40 AM   #21
snow_bound26
Member#: 395793
2005 92x Aero
When I purchased the device with Windows 10 I asked the guy if it was Windows 10 RT since I had read that open source doesn’t support RT stuff. He told me that Windows doesn’t make an RT version of 10. Considering this is Bestbuy I started thinking, and even though I haven’t been able find anything definitive, in my searching I found EcuTek doesn’t support Windows 10 RT. Is it possible this is the version of Windows I have? If so, how do I find out? I’ve tried searching and haven’t found any clear cut information.
Old 06-09-2018, 11:53 AM   #22
kopele
Member#: 363007
When I purchased the device with Windows 10 I asked the guy if it was Windows 10 RT since I had read that open source doesnít support RT stuff. He told me that Windows doesnít make an RT version of 10. Considering this is Bestbuy I started thinking, and even though I havenít been able find anything definitive, in my searching I found EcuTek doesnít support Windows 10 RT. Is it possible this is the version of Windows I have? If so, how do I find out? Iíve tried searching and havenít found any clear cut information.
Windows RT was a version of Windows 8, apparently Windows 10 S is equivalent to it, because it's a limited feature version aimed at low-end devices. Maybe that's a version you'd want to avoid. Here's how to find your version: https://www.howtogeek.com/236195/how...s-10-you-have/
What device do you have? You mentioned a tablet?
Old 06-09-2018, 12:57 PM   #23
jon7009
Member#: 394646
2003 WRX Flex Fuel
EJ205 TD04L FMIC SD
I've had three HP windows 10 netbooks and a Toshiba Windows 10 tablet all work perfectly fine with ecuflash, romraider, and my tactrix
I don't know what your problem is, sorry.
jon7009 is offline   Reply With Quote
Old 06-09-2018, 01:11 PM   #24
snow_bound26
Member#: 395793
2005 92x Aero
Itís an Insignia tablet running Windows Home 32bit with an x64 processor. It looks like I donít have Windows 10 S since I am able to download apps directly from websites. Apparently 10 S limits available apps to the Microsoft store specifically and you canít go directly to Spotify and get the app for instance. Microsoft says you can switch out of S but when I do the search it says ďunable to find. Report error?Ē So it seems I donít have it.
Old 06-09-2018, 01:24 PM   #25
kopele
Member#: 363007
Have you tried disabling antivirus if it has one? If you go to device manager and click properties on the cable does it say "device is working normally" or something link that?
