Welcome to the North American Subaru Impreza Owners Club Tuesday October 23, 2018
Old 06-20-2018, 02:20 AM   #1
Nettalp
Member#: 93812
2004 Wrx wagon
Platinum Silver Metallic
Default Boost and Fuel Questions
Hi everyone,
Looking for feedback and overall consensus here:
1) What is a normal tolerance for Boost levels to drop in hot weather vs cold weather? Looking for sea level comparison. Cold weather / target boost = 17lbs. Warmer hot weather consistent 16.2lbs and sometimes 15.8lbs.
2) What are normal STFT numbers for stage 2 tunes? Ive been seeing STFT -20's all the way to + 15 or 18. My LTFT are -1 to +3% and within the acceptable +/- 4-5% ranges.
Car: 2004 USDM wax wagon MT
Fuel: CA 91 Octane (Socal)
Elevation: 39 ft (Sealevel)
Cold Weather: Currently 55-65 degrees
Hot Weather: Currently 70-85 degrees
Mods:
TD04 Turbo (Stock)
Gutted STI Downpipe
Sti Catless Uppipe
Oem Header (Port and Polished)
Greddy 3 inch exhaust
Grimmspeed EBCS
Walbro 255 Fuel Pump
Stock Intake
Stock Injectors
Stock Intercooler
Nettalp is offline   Reply With Quote
Old 06-20-2018, 11:30 AM   #2
86Dreams
Member#: 385256
V7 S204
Neither are straight forward questions and depend on weather, tuning, and operating state.
86Dreams is offline   Reply With Quote
Old 07-09-2018, 05:49 PM   #3
TickerPyro
Member#: 488141
You can set adjustments for weather so your boost stays the same, or at least very close.
And as far as STFT you might refer to the COBB Stage 2 Setup. I am guessing that is what you mean by "normal". Lots of people are on complete stock fuel setups still running Stg 2, so what is normal for them really wouldn't be normal for a FP upgrade and injectors.
TickerPyro is offline   Reply With Quote
