Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 08-13-2018, 10:24 AM   #1
John Connor
Member#: 489892
2004 FXT 5 speed
Default Help a noob with his first datalog
2004 Forester XT 5MT 112K miles
Zero mods including base calibration
Fresh air filter, oil change and plugs
2500 elevation at about 65 degrees
3rd gear pull
https://docs.google.com/spreadsheets...it?usp=sharing
Is this some real knock pulling timing and boost? Fake knock? Boost leak? Help a noob out please!
John Connor is offline   Reply With Quote
Old 08-13-2018, 04:01 PM   #2
John Connor
Member#: 489892
2004 FXT 5 speed
I reflagged the factory tune found on RomRaider, filled up with 93 octane, added a real octane booster (putting it over 95) and my log still looks similar.
Old 08-17-2018, 01:09 AM   #3
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
You went back to the stock map and it still had that much knock ? I might think it was false, there is alot of knock. Look for anything loose on the exhaust like heat shields, missing bolts, broken hangers. Anything loose on the motor, even a bolt or rock bouncing around near the knock sensor. Also, on the next log, try to get grams/rev or mass air. So you can pinpoint it on the base timing map.
bobjr94 is offline   Reply With Quote
Old 09-19-2018, 04:29 AM   #4
John Connor
Member#: 489892
2004 FXT 5 speed
It ended up being a dirty crank position sensor. All is well now
