Welcome to the North American Subaru Impreza Owners Club Friday October 19, 2018
Old 12-07-2004, 07:15 PM   #1
forsaken
Member#: 50310
Default Detonation/Pinging after 30k Maintenance on 2002 WRX?
I just got my 30k maintenance done today. The problem is they finished it about 5 mins b4 the dealership closed. Now, when i drive my car, everything performs normal, boost is normal, no CELs, but when i put the car under light-medium throttle in any gear, i get a rattling noise, until i am WOT. It does seem to speed up as the throttle increases. But, it doesnt make the noise hwen the car is in neutral and i rev the engine up, nor during depressing the gas pedal.
Its not wastegate flutter because i already have that noise. This is completely different and being under boost doesnt seem to make a difference when this noise occurs. As soon as my car is under load and starts to go the noise starts, then it disappears when im high throttle or WOT. I almost want to say it sounds like how pinging is described, but not so clear cut as the descriptions ive read. IF anyone has any ideas as to what i can check before i take it back to the dealer tomorrow i would appreciate it. I Do have a stromung twin dump DP and a gutted stock uppipe, but i dont think anything they do under the 30k would/should be touched.
forsaken is offline   Reply With Quote
Old 12-07-2004, 07:33 PM   #2
ZapZilla
Member#: 51190
2002 WRX Wagon
My tranny fluid dipstick was hitting on something once and it made a rattling noise, i couldn't figure it out for the longest time, till i changed my tranny fluid. This probably is not it but check it out
ZapZilla is offline   Reply With Quote
Old 12-07-2004, 07:47 PM   #3
forsaken
Member#: 50310
I normally panic to quick because i know just enough about my car to wonder if anything i do to it will break it. But it appears while they were working on the car that they bent the horn down a bit so it was against my Speedmonkee turbo heat shield and it was vibrating like mad. Took it for a spin after i bent it back and the sound was gone, hopefully thats all it was. Thanks!
Timing belt maintenance for 2002 WRX erikkellison Service & Maintenance 6 01-21-2010 05:30 PM
Rear-Diff Grinding after 30K Maintenance grambo Transmission (AT/MT) & Driveline 39 06-01-2009 01:17 AM
30K maintenance on '03 RS jonnysubby North West Impreza Club Forum -- NWIC 3 11-19-2004 01:00 PM
cost of maintenance on 2002 wrx daxin Canada Region Forum 1 03-24-2002 12:53 PM
Maintenance on new WRX gwlunceford Newbies & FAQs 2 12-21-2001 05:05 PM
