Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 08-20-2009, 05:38 AM   #201
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Crawford used Subaru's JDM twin-scroll manifold for Ken Block's car. Anybody know the inner diameter of the primaries on that header?
Old 08-20-2009, 10:57 AM   #202
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Originally Posted by jagstyle View Post
Is the tiny runner diameter used on the perrins any good for high power rotated turbo setups (rotated gt3076r .82 on E85) or should I get something with larger diameter runners instead?
From what I have read and understood, the Perrins are better slightly lower HP setups, while something with a little bigger runners like the Gruppe-S EL headers work a little better on bigger HP setups. I would love to find some other good alternatives around this price range for bigger HP setups, just for the sake of having some options.
offset
offset is offline   Reply With Quote
Old 08-20-2009, 12:33 PM   #203
jagstyle
R.I.P.
Member#: 155186
2007 STI
offset
Has this been tested or is this just speculation?
jagstyle is offline   Reply With Quote
Old 08-20-2009, 01:30 PM   #204
LittleBlueGT
Member#: 96204
2013 STI GR
I have done personally testing and tuning on the Perrin ELH, WBR ELH, and iON UELH (very similar to GT-spec UELH). I have owned them all.
WBR spooled the slowest, and made the least power. I could run 20 psi at red-line with it, but would only flow about 305 g/s
iON spooled next fastest, made the most power. I could only run 18 psi at red-line, but flowed 310 g/s (less psi, more flow)
Perrin spooled the best, and lost a small amount of airflow to the iON.
My conclusion about headers (and TGV, and inlet pipe). The turbo can only flow so much air. Making things more efficient is always good, but many times on our cars does not result in much more power. Contrary to what all the vendors want you to believe, there is very little power to be had in any of them (300-330 whp set-ups).
Sure you may make 10 more whp at the same psi, but the turbo is now just at a slightly different spot on the comp map. If you tune both turbos to the same degree, you will end up with about the same whp (+/- 5), one set-up may just require a touch more boost then another.
If you go all out (flow as much as the turbo will do) on an alky or race gas tune, you will find the overall airflow will be the same.
That said, I like my Perrin headers, car is quieter, spools better, and supposedly results in more controllable EGTs, especially if you like road courses.
LittleBlueGT is offline   Reply With Quote
Old 08-21-2009, 01:04 AM   #205
unclemat
Member#: 114530
2005 LGT 6MT wagon
38 mm in case of STI header. JDM LGT is notably smaller (32 mm IIRC).
unclemat is offline   Reply With Quote
Old 02-12-2018, 12:12 PM   #206
N-Bomb
Member#: 309465
1999 GC + ver 9 swap
Silverish
Another bump for re-host of the images.
The thread is of far less utility w/o them!
N-Bomb is offline   Reply With Quote
Old 02-14-2018, 12:48 AM   #207
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Congrats to you for doing research and finding a 12 year old thread. I'm not even mad, I'm impressed.
Old 01-19-2019, 07:05 PM   #208
13Stoploss
Member#: 262494
2005 WRX Wagon
It's in the sticky. I, too, found it before other "research" based on its sticky status.
13Stoploss is offline   Reply With Quote
Manifold and Header Dyno Comparo results RainMaker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-01-2009 09:32 PM
Interested in a stock manifold/ported/ported + crosspipe/equal length header comparo? RainMaker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 212 05-03-2006 02:09 PM
Interested in a stock manifold/ported/ported + crosspipe/equal length header comparo? RainMaker North West Impreza Club Forum -- NWIC 10 04-04-2006 10:14 PM
FS: TurboXS TMIC, intake manifold, and header TypeR North West Impreza Club Forum -- NWIC 2 05-20-2005 03:06 AM
Header comparo soon? overdose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-05-2004 06:10 PM
