Welcome to the North American Subaru Impreza Owners Club Tuesday February 25, 2020
Old 08-09-2018, 10:41 PM   #551
remski
Member#: 151895
Alright then...
Been keeping busy... believe it or not..
Started flocking the dash.. but 5th attempt and its still not perfect ...
Finally I've completed the steering wheel.
Had it going with DTM connectors but for some reason it didnt want to work.
I think the car likes those AS connectors...
In-and-out and managed to put 70+ miles on the car already.
Fixing loose ends in between.
Moar stickers on the PDM keypad !!!
Steering wheel buttons configured to operate the blinkers, horn, low/high beam and hazards as well.
Managed to find a fancy config for the blinkers.
short-press --> 3 blinks
long-press --> 10 blinks
Also fixed the self canceling where turning on the blinker turns off the opposite one if on.
ECU now controls the engine fan via CAN bus !!!!
Door cards are installed as well. Still need to find and install the lever.
Gotta look nice.. edge tape applied as well.
Last but not least.. rear divider is in.
Had to back it up with some tape as this s**t was really noisy.
Old 08-09-2018, 11:45 PM   #552
barongan
Member#: 488876
awesome,great work man
barongan is offline   Reply With Quote
Old 08-12-2018, 01:46 AM   #553
batesd1994
Member#: 461268
Default 25DB Widebody Rsti
Where was the best place to find the wir my diagrams to build the harness off of. I have an ej20x that I want to look over the wiring of. Also beautiful car. Love the color. You mind if I steal the paint code from you?
batesd1994 is offline   Reply With Quote
Old 08-12-2018, 12:41 PM   #554
remski
Member#: 151895
hehe.. sorry .. paint code is off limits.
Gotta be unique in some way...
As for the diagrams.. well.. I did my layout in my head. :P
But depends which one you want to build.
Engine harness or the whole car.
Map out what you'll need and the count the wires you'll need to run.
Amps and length play a role as well. Add wire type to that.
Figuring out the connector part is a bit harder but it's doable.
For lots of things I used the stock wiring diagram.
Old 08-12-2018, 01:04 PM   #555
RJSMITH
Member#: 347474
0219 Bug,bug,coup,va
mbp,sr,wrb
Been following for a while and this never ceases to impress wanna build me a engine harness for my bugeye
RJSMITH is offline   Reply With Quote
Old 08-12-2018, 05:15 PM   #556
Smurftastic
Member#: 243697
17.4 PSI ECUtuned 02
BLOD Cofounder|TopScoob31
Holy crap dude, holy crap.
Holy. Crap.
The level of attention to detail in this build is off the charts, and this is coming from a guy who tries to focus on attention to detail in my own build.
Encore, encore let's see more!
Smurftastic is offline   Reply With Quote
Old 08-12-2018, 07:19 PM   #557
remski
Member#: 151895
Thank you guys for the kind words.
As for building the harness its not that hard. I'd say building it from scratch for a standalone seems easier than messing with current harness.
Standalone uses so much less wiring.
Old 08-13-2018, 02:18 PM   #558
batesd1994
Member#: 461268
My problem is finding the stock diagram for the ej20x
Old 08-13-2018, 09:26 PM   #559
De36
Member#: 475437
2018 WRX
Follow.
De36 is offline   Reply With Quote
Old 08-14-2018, 04:34 PM   #560
remski
Member#: 151895
Attended my first car show over the weekend...
Other than that... Went for a pre-tune inspection...
Small oil leak was found from the turbo drain pipe,
as well as the axle boot is damaged..
Axles are making a noise .. so new set is already on order.
Old 08-15-2018, 12:38 AM   #561
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Axle boot was damaged? How did you miss that? This is the most meticulous thread on here other than the old FF. LOL
Just messing with you, thats just how it goes, happy you made it out to a show. Thats a big step!
Scuby04STi is online now   Reply With Quote
Old 08-15-2018, 09:22 AM   #562
Zombie Panda
Member#: 425346
2003 WRX
Caucasian
http://techinfo.subaru.com/index.html
This is where I got mine. Big thanks to Mr. Gilbert.
Zombie Panda is offline   Reply With Quote
Old 08-15-2018, 09:48 AM   #563
remski
Member#: 151895
Yeah.. there was one that had a small hole.. which I siliconed up.
If it was throwing grease it would be all over and its not.
But I get his point .. he doesnt want any on his dyno.
Old 08-25-2018, 12:09 PM   #564
remski
Member#: 151895
Lots of little here&there things getting fixed.
From the bigger things..
Rear axles were replaced with DSS ones.. but for some strange reason both are throwing grease out at the wheel clamp.
Finally propper mirrors arrived.
Had to disassemble drvers' side as this might have been a RHD spec.
Removing few "high tech crazy glued nuts" re-adjusted it properly.
Center console is almost complete. Epoxy, paint, glue, sand and some Dinoc covered the imperfections quite nicely.
Old 08-31-2018, 02:52 PM   #565
remski
Member#: 151895
So.... I've been chasing rear clunk noise for the last few days.
Re-torqued the whole rear end section. Some bolts weren't torqued.
I think it helped a bit but the clunk is still there.
Mostly when taking off and turning.
1st gear decel as well.
This points me to top spring perch. I cant think of anything else that could make the sound.
Also I've been going back and forth with Turn In Concepts about the ride height.
Seems like the spring I got is too short and I cant lower the car enough.
Since pretty much everything is now in the car I went ahead and weighted the car again.
As 2550 was an awesome weight now with full tank of gas and passenger seat car has gained about 100lb.
80lb --> fuel
20lb --> passenger seat and harness.
Steering wheel and PS reservoir with fluid.
Final wet weight:
And with me in it.
Old 09-01-2018, 04:24 AM   #566
batesd1994
Member#: 461268
I need a more in depth knowledge of all this wiring stuff. It amazes me so much
Old 09-11-2018, 02:58 PM   #567
remski
Member#: 151895
Excited like a baby it was finally time to put the car on the dyno.
Here we are observing Junior doing his pre-run tests.
Sucks they dont let you do shotgun runs...
And... thats pretty much where this story ends.
Loud cam tapping nose has developed before the 1st pull.
After reading one long ass cam thread (1000+) posts .. I've narrowed it down to GSC cams issue where the lobe or the bucked gets eaten away.
I do have the original 6 series cams. New 7 series are billet..
Covers are coming off today or tomorrow for inspection but I have a feeling that engine is coming out for cam replacement.
Question is .. which cam to get as the new GSC billet had failures too.
Seems like intake cam as the AFRs got way rich .. pointing to not enough air.
Old 09-11-2018, 03:06 PM   #568
BBY_Hero
Member#: 234236
06 STI
AW
Such a bummer! Uh have you looked at the brian crower 272s? I'm not sure what cams you are looking for but if my memory serves me right people seemed to like them? It's been 5 years since I looked though
BBY_Hero is offline   Reply With Quote
Old 09-11-2018, 10:10 PM   #569
racemugen
Member#: 33692
19 STI
remarkable! well done!
subscribed to this fantastic thread.
racemugen is offline   Reply With Quote
Old 09-12-2018, 12:25 AM   #570
remski
Member#: 151895
So.. I took off the drivers's cam covers today..
Cams look somewhat OK to my eyes.. I run my fingers multiple times i couldnt feel any irregularities or scoring. Buckets are hard to see so i cant really tell.. but if cams are not scored buckets should be ok.
Put all back together and decided to start the car just to see if the sound is still there.
Started logging, reving.. making vids, comparing the sound.. all was good .. no AFR changes, no tapping.
Then I remembered that all this time I was running without the AVCS solenoids connected. We just plugged it in at the dyno session.
So.. they were now unplugged since I took the cam cover off..
I plugged it in .. reved to 2k and bam !!! AFR at 10 and car runs like ****.
F-ing avcs solenoids...
I run map compare with a base map and both AVCS solenoid were set to LH (left hand side intake)
Changed it to RH ... I went ahead and traced all the wiring just to make sure .. all good...
I go start the car with the proper setting and no issues !!!!
Switch back to LH solenoid and AFRs at 10..
So.. all this, the tuner and me didnt notice that the AVCS settings were incorrect..
Now I wonder it that warrants for a "free" tune as I had to pay regardless..
Old 09-12-2018, 01:29 AM   #571
elanfam
Member#: 491111
2015 WRX Limited
Bbeautifullllll
elanfam is offline   Reply With Quote
Old 09-12-2018, 06:12 PM   #572
BBY_Hero
Member#: 234236
06 STI
AW
I'd hope atleast a discount and maybe a box of donuts. haha good thing you found it now before pulling the motor! I'm excited to see some numbers!
Old 09-12-2018, 10:43 PM   #573
remski
Member#: 151895
Still going to pull the passeger's side for s**ts and giggles..
It did sound louder when I used my "stethoscope".
Old 09-13-2018, 12:19 AM   #574
Kochi_STi
Member#: 369411
2002 WRX STi Limited
Can never be too careful. Especially near the end of such a meticulous build as this.
Kochi_STi is offline   Reply With Quote
Old 09-26-2018, 01:18 AM   #575
remski
Member#: 151895
Tonight.. we begin with few studs.
As you can see 2 are already in action.
After some shaving... and 2 screws...
First one is in !!!
We had to use the back door.
And all are in. Now dont be getting any dirty ideas.
These are for the spacers.
