09-25-2017, 06:32 PM | #1 |
Member#: 468393
Vehicle:2017 STI |
20G / FMIC Dyno Graphs
Engine Mods
Cobb 20g turbo Cobb Intake Perrin cold air intake Perrin Turbo intake Perrin FMIC Modified OEM turbo heat shield -- Perrin turbo heat shield Perrin Turbo Blanket Perrin lightweight crank pulley Perrin Front and Rear Shifter Bushings (that was a PITA install - worth it though) Perrin Weighted Shift Knob Perrin Dress Up Covers/Caps/ETC Cobb Access Port High load PCV delete, VTA. Low load PCV is in OEM working condition. AEM WBO2 tied into AP for logging Innovate oil pressure/oil temp MTX gauge SMY instrument cluster gauge pod IA Performance FPR/Stumble Fix (same as Cobb's but at a much better price) Grimspeed catted downpipe - wrapped Grimspeed EBCS Grimspeed sandwich plate adapter Deatschwerks 750cc injectors Deatschwerks DW65c fuel pump Tomei ELH w/ up pipe - wrapped Invidia Q300 catback w/ Titanium Tips I run a base tune on 94.5 octane. This will be S mode. S# will be a 92 octane tune via a boost reduction in the map, and a global timing reduction of the Cobb Access Port. I mode will be gas saver/snow mode/waste gate. Here's the dyno graphs - 1st is the last after a long series of pulls. It was heat soaked. 2nd is after a 20 min cool down. I think the later spool and torque on the 2nd graph is due to the SS headers and turbo being cold. It certainly spools faster on the street. 383/390- 385/377 - 25 PSI tapering to 21 at redline Tuned by Jarrad at PDXTUNING in Portland OR.
01-18-2019, 11:50 PM | #2 |
Member#: 78751
SCIC
Vehicle:2017 Sti ISM |
Wow, I'm confused on why peak torque is so high in rpm range.
01-19-2019, 03:10 PM | #3 |
Member#: 140444
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
My car's dyno sheet showed it spooling about 1000 RPM later than it really does on the street, so in cases like this I just assume it's more about the dyno than about the car.
01-19-2019, 07:51 PM | #4 |
Member#: 180861
Vehicle:2005 IAG Closed Deck Larry's Power built heads |
Do you have any more info on your pcv delete set up?
01-20-2019, 08:44 AM | #5 | |
Member#: 328635
Vehicle:2004 STi GTX3076R Rally Blue |
OP, so how many project subarus do you have? Lol |
01-21-2019, 03:43 AM | #6 |
Member#: 468393
Vehicle:2017 STI |
I just pulled the few VD runs I had, and , spool/PT wasn't that much better. Maybe 250 rpms or so.
I wasn't nearly as knowledgeable about tuning and turbo cars in general back then so, I wasn't out tuning all night seeing what I could get the setup to do. I didn't keep this turbo long before I had Jarrad pop some forged pistons in the motor and at that time I upgraded a bunch of other items too, including and FP Green. Same car, it's just been transformed now a few times. This is the latest version https://forums.nasioc.com/forums/sho....php?t=2890091 Edited to add - that dyno has never loaded my car the same as the street. I always boost more the second I'm off that thing and on the street. I was recently on that dyno and had to turn up the boost from my road tuned settings. It was off (low) by several PSI. In the end it's just a tool. I enjoy doing most of the tuning on the road, and hitting the dyno to fine tune the timing. |
01-21-2019, 03:52 AM | #7 |
Member#: 468393
Vehicle:2017 STI |
What would you like to know?
I think at this time I was running everything T'd into a single little K/N filter under the car. Big mistake as Ting all those lines into one improperly sized line the exits out of a tiny little filter is a disaster when you take a long sweeping turn at 100+ mph and so much oil comes out the line can't handle it so it blows the lines off your head port. Ask me how I know. If you're going to do a DIY setup - just upsize the dump line accordingly, and don't restrict it with a tiny cotton filter. |
