Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 11-29-2003, 09:30 PM   #1
crk4
Member#: 43617
1976 Ford Bronco
R.I.P. Mark Vos, 96 ob
Default do WRX headers bolt on the 2.2L NA 96 block
From all the research I've done I believe that the WRX headers have dual ports and my 1996 2.2L has single ports. This will NOT work from what I've read.
Can somebody who has actually physically seen the ports on both of these engines answer with a straight answer. Or somebody who has contemplated or even done something like this.
WILL IT WORK??
chris
crk4 is offline   Reply With Quote
Old 11-29-2003, 09:35 PM   #2
Unsung Boxer
Member#: 37196
you are correct... they will NOT bolt up.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 11-29-2003, 09:46 PM   #3
Bussman61
Member#: 32612
1996 SVX
Laguna Blue
Will the WRX header bolt up to a n/a 2.2l with dual ports? Or is there no compatability at all between the 2.0l and 2.2l?
- Charlie
Bussman61 is offline   Reply With Quote
Old 11-29-2003, 10:35 PM   #4
Kostamojen
Member#: 2272
2019 Macan 4cyl
1993 Impreza FWD WRX swap
The WRX header WILL bolt up to any EJ engine with dual ports.
And im not 100% sure, but I believe the 96 2.2l is a dual port head. It was mostly the later heads, like 98-01 2.2's that had single ports.
Old 11-29-2003, 11:55 PM   #5
Bussman61
Member#: 32612
1996 SVX
Laguna Blue
That is exactly what I wanted to hear
Old 11-30-2003, 03:06 AM   #6
Unsung Boxer
Member#: 37196
Dont forget the fact that the Header will run into the crossmember on an NA car...
The crossmember is designed for the type of header.
on a WRX it will use the "turbo crossmember"
on an RS, or whatnot, it will be the "NA crossmember"
you will have to swap this if you intend on using a WRX header.
I agree that a Dual Port head will bolt up to the WRX... i also agree that 98+L's are single port... I just saw where you said
"my car has single ports, will a wrx header bolt up"
-Jake
Old 12-01-2003, 01:49 AM   #7
Kostamojen
Member#: 2272
2019 Macan 4cyl
-Jake
I presumed that was known.
Old 12-03-2003, 12:13 AM   #8
crk4
Member#: 43617
1976 Ford Bronco
So where can I get TURBO headers that will fit my single exhaust port heads w/o swapping in diff. heads, if that's even possible?
Has ANYONE ever turboed a 2.2 using single ports???
Old 12-03-2003, 01:33 AM   #9
Unsung Boxer
Member#: 37196
you cannot get turbo headers for single ports...
the only turbocharged subarus that are semi compatible are the WRX and the Turbo Legacy, which are both Double port...
Your talking to one!
Old 12-03-2003, 01:34 AM   #10
Charge
Member#: 3313
Kevin Thomas turbo'd his Outback 2.2liter, but I can't remember what year his was, or what exhaust ports he had. I don't believe he had an aftermarket header on the car though(I could be wrong on this).
Try PM'ing him. His username is Kevin Thomas. He'll be able to at least shed some light on if he had a similar setup. He may even be able to point you to some available options if he had the same thing.
I don't think the headers would be necessary though. If you were building up enough to require new headers, you'd probably want to go ahead and replace the heads as well.
Charge is offline   Reply With Quote
Old 12-03-2003, 06:57 PM   #11
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Corolla GT-S Hachi Broku
The closest to "turbo" headers for our motors, are Borlas. $280-300... Much smoother than stockers.
-Ben
Soon2BturbodRS is offline   Reply With Quote
Old 12-04-2003, 01:12 AM   #12
Unsung Boxer
Member#: 37196
-Ben
Your refering to the headers for the 2.5RS, which again is Dual Port... WHICH AGAIN, will NOT fit your Single Port 2.2.
Yeesh
-Jake
Old 12-04-2003, 02:04 AM   #13
Kostamojen
Member#: 2272
2019 Macan 4cyl
Borlas also come in a single port design.
But piping isnt really an issue for a turbo, just use the stock headers and have a custom uppipe made. People do that all the time.
Old 12-04-2003, 08:39 PM   #14
crk4
Member#: 43617
1976 Ford Bronco
wouldnt that mess up the exhaust flow, not a good flow setup?
how exactly would this custom uppipe work, details? would it go up from a cut hole at the y pipe?
Old 12-05-2003, 04:56 AM   #15
Kostamojen
Member#: 2272
2019 Macan 4cyl
Heres a good example of a custom uppipe/downpipe that you can actually purchase:
http://www.uniquemotorsports.com/products/products.htm
Uses the stock header location just as I stated. Flow is fine, just look at the stock WRX/legacy turbo headers, they arent that great.
How To: Install WRX Turbo/IC on a 2.2L Pepo Normally Aspirated with bolt-on Forced Induction Powertrain 12 10-08-2004 11:18 AM
Anyone know if a WRX catback would fit on a 2.2L 96? jsavage Normally Aspirated Powertrain 6 01-21-2004 08:09 PM
Are the cats on the 2.2L/Outback and 2.5L/RS the same? Mirage Normally Aspirated Powertrain 1 12-04-2003 09:09 AM
00 2.2L vs. 96 2.2L, where'd the power come from? 96Lconversion Normally Aspirated Powertrain 15 01-19-2001 12:32 AM
