Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 07-10-2009, 03:49 AM   #1
cssee
Member#: 178350
Default ECT sensor temp vs voltage table
Doesn't anybody happened to have the conversion table for the coolant temperature sensor, temperature vs. votage? Thanks.
cssee is offline   Reply With Quote
Old 07-10-2009, 11:25 AM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Not sure if they're different for other cars, but on my 05 STi (voltage and coolant temp in F)
Code:
[Table2D]
0.45	0.61	0.76	0.92	1.07	1.23	1.39	1.54	1.70	1.86	2.01	2.17	2.32	2.48	2.64	2.79	2.95	3.11	3.26	3.42	3.57	3.73	3.89	4.04	4.20	4.36	4.51	4.67
248.0	229.8	210.9	195.6	183.0	171.7	161.8	152.8	144.5	136.7	129.4	122.2	115.5	108.8	102.2	95.6	89.1	82.3	75.4	68.5	60.7	52.9	44.0	34.5	22.9	9.4	-9.4	-40.0
Download RomRaider or ECUFlash, download the stock ROM for your car, and open the coolant temp sensor scaling table if you want to see if yours is different.
Old 02-08-2020, 12:11 PM   #3
fusionartist
Member#: 63717
0204 02sedan,04wagon
Midnight-Blk; Plat-Silver
Default ECT Scaling vs. Temp-Guage Reading
Code:
[Table2D]
* 1.> Are we able to manipulate the readings of the dashboard temperature gauge with this table?
* 2.> And / Or, Does this effect fuel enrichment as well?
fusionartist is offline   Reply With Quote
00RS -> 05 WRX, Fuel temp/level voltages too high? silentt Subaru Conversions 2 06-12-2019 07:11 PM
check engine light code P0137 o2 sensor circuit low voltage bank 1 sensor 2 duque Engine Management & Tuning 1 05-09-2010 02:43 AM
FS-Defi HUDs - Digital Kph/Rpm or Temp/Compass/Voltage wrxer12 Canada Region Private Classifieds 15 02-03-2007 05:51 PM
ect sensor replacement questions speedymatt Service & Maintenance 0 05-04-2004 12:08 PM
MAP sensor specs... boost vs. voltage? Equilibrium Tuning Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-17-2004 03:18 PM
