Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 04-13-2014, 01:26 PM   #1
ryz252003
Member#: 332086
Default Smoke on start up
Ok kind of a weird situation I've done a lot of research and I'm doubting its a ring land issue but its possible. It's an 06 sti stage 2 and occasionally after boosting i get blue smoke on the next start up. I also think I'm hearing some excess valve train noise but i might just be paranoid. I'm leaning towards valve seals or a Pcv issue because i did a compression test and all cylinders were between 139-141 psi but i noticed on both passenger side plugs the threads of the plug were wet with oil but the burning area looked fine just like the other side. Any ideas? Thanks
ryz252003 is offline   Reply With Quote
Old 04-13-2014, 01:49 PM   #2
Vinchenzo51
Member#: 372168
2006 STI
SGM
Been in the same boat, first time i got smoke from exhaust, my turbo was shot. How many miles on the turbo? when my vf39 went out i had smoke from the exhaust on cold starts especially following some pretty ugly sounds coming from the turbo when driving.
If its not the turbo it could be a bad Headgasket, or piston failure. I recently had symptoms of a bad HG and my shop told me it was a piston was shot. I would first scope out the turbo and if thats ok take it to your mechanic and get it checked out.
Vinchenzo51 is offline   Reply With Quote
Old 04-13-2014, 03:01 PM   #3
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Probably just pcv clogged or blowby if it was your ringland you would see alot more and it would smoke worse as it warmed up.
nate_fisher is offline   Reply With Quote
Old 04-13-2014, 03:06 PM   #4
ryz252003
Member#: 332086
The car has 70k original turbo it has been making an air noise under boost intermittently not a bearing noise but it sounds like i have an intake and i have a stock air box its not a bearing noise though
Old 04-13-2014, 07:24 PM   #5
ryz252003
Member#: 332086
After driving i just realized if i start my car up and drive normal it sounds perfectly fine, after i boost a good amount the air induction/recirc valve noise and valve train or exhaust leak noise comes and stays for the rest of the drive. If it was a turbo going would it smoke under boost as well as start up because i have no smoke under boost.
Old 04-13-2014, 07:34 PM   #6
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
It's a catch 22 with a turbo and with your situation only a visual inspection will verify.
trev762 is offline   Reply With Quote
Old 04-13-2014, 10:45 PM   #7
Vinchenzo51
Member#: 372168
2006 STI
SGM
Yes you will get smoke on startup if your turbo is worn. You can take off your turbo inlet and wiggle the shaft a little to check.
Old 02-03-2020, 05:24 PM   #8
Jack14hatch
Member#: 496727
What about just checking the hot side? Is checking both necessary?
Also was this fixed?
Jack14hatch is offline   Reply With Quote
