Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 04-25-2014, 09:40 AM   #26
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by KillerBMotorsport View Post
^ Maybe with the Tial housing the outputs will be better matched to the hype behind them... or maybe in time better results will be posted by someone besides a reseller.
Hotside wise it would likely fit and it would have decent flow path coming out too, but nothing else would fit. Not even close.
Smaller WGs always have better control until they reach capacity, which is why we are a big proponent (and only use) the 38mm WGs. IWG are very often the cause of 'issues' in stock form when these things are pushed, in any platform. Another reason to avoid them.
For comparison sake regarding the OAL's Garrett vs EFR. Using a Garrett R cartridge turbo with either a Subaru SL turbine housing or with a Tial housing dimensions at 7.5" and EFR 7163 w/ EWG turbine housing (I got the specs from FR) at 9.5", it's just not gonna fit on this kit. The 2" has to come from somewhere and that means moving the down pipe back towards the firewall 2" which greatly affects the bends and shape of the down pipe as Chris mentions earlier. I'm sure part of the gains here on this kit besides the Tial housing is the better down pipe shape without the turbulence of the bellmouth and the smoother more consistant shaped bend down towards the ground.
Old 04-25-2014, 09:45 AM   #27
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ true and the one thing that always irked me with rotated setups, the DP. Specifically at the turbine exit. Straight as possible will always yield better results.
KillerBMotorsport is online now   Reply With Quote
Old 04-29-2014, 11:47 AM   #28
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
very interesting kit. i'm watching closely!
Old 05-05-2014, 04:11 PM   #29
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Not that we didn't kinda know already, but bolted up a 3076 and it looks good.
Something to consider is running this kit does require the bell housing to be 'clearanced' some. Nothing too exciting though.
Old 05-05-2014, 11:11 PM   #30
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
Not that we didn't kinda know already, but bolted up a 3076 and it looks good. Something to consider is running this kit does require the bell housing to be 'clearanced' some. Nothing too exciting though.
I'm a happy man :-). GTX3076R is what I want. Now I just hope it'll fit with the uppipe and dump tube you made for me :-).
WolfPlayer is offline   Reply With Quote
Old 06-21-2014, 05:04 PM   #31
cpz1987
Member#: 307403
2012 WRX HATCH
WHITE
mmmmm got my attention! already own your header w/ewg, oil pan, baffle,pickup... you just know how to take my money! Be in the market soon for turbo
cpz1987 is offline   Reply With Quote
Old 06-22-2014, 12:21 PM   #32
lingling1337
Member#: 312120
Consider me interested. A quick spooling gt30 setup is exactly what I've been looking for.
lingling1337 is offline   Reply With Quote
Old 07-21-2014, 11:45 PM   #33
giantbrandon
Member#: 329666
2008 Liberty sti
any updates?
giantbrandon is offline   Reply With Quote
Old 09-10-2014, 10:37 AM   #34
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Updates?
Tyrial is offline   Reply With Quote
Old 09-10-2014, 11:22 AM   #35
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
can you run this with the compressor outlet pointed straight up?
gsrcrxsi is offline   Reply With Quote
Old 09-10-2014, 12:50 PM   #36
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Sorry for the delay guys. This setup is now available
Old 09-10-2014, 12:52 PM   #37
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No idea, we've never tried. I can't think of a reason why not, but there's only one way to find out.
Old 09-12-2014, 09:35 AM   #38
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Are you going to make an option of putting a V-band on top of your up-pipe instead of the adapter? Or is that something you could do if requested?
Old 09-12-2014, 10:13 AM   #39
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It's not quite as simple as that. The flange location changes so we'd need new fixturing. Even if it didn't change, we'd need new fixturing to make it happen. The adapter is ideal because it doesn't require a 'custom' up-pipe and puts (raises) the turbo centerline where it needs to be.
Old 09-15-2014, 08:17 AM   #40
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Here ya go... LINK
Old 09-30-2014, 11:58 AM   #41
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
PMs answered
Old 01-09-2015, 04:15 PM   #42
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Few clips put together. Sorry about the sun, but it should give you the jist...
Old 01-09-2015, 04:28 PM   #43
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Forgot to mention the revised plot with V3 header and ETS TMIC...
Old 01-09-2015, 04:28 PM   #44
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
is that with the 3076?
looks very responsive
Old 01-09-2015, 04:32 PM   #45
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
What fuel used?
Old 01-09-2015, 04:44 PM   #46
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
This is the GTX3067-R (not 3076) on pump 93
Old 02-12-2015, 01:40 AM   #47
IWD
Member#: 335804
2013 WRX
plasma blue pearl
Killer b, why not build a specific up pipe for your holy header. You already have the ewg option, why no v band?
can a dom 1.5 or 2.5 accept the tial housing? That way people can keep the tgv intact and not require so much? I think that would be great for people looking for stock spool and 350whp
IWD is offline   Reply With Quote
Old 02-12-2015, 07:16 AM   #48
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It would just put it in the same location as the Spoolinator. The "kit" allows the use of any header/up, with the point being you don't need to buy a header/up if you've already got one with an EWG.
No. The Blouch housings would need to be specially machined for the Tial. Even at that, the wheel clearances requirements are very specific and if not held will effect performance of the turbocharger.
Make no mistake the GTX3067-R turbo we've been using spools better than the stock VF and makes ~400whp. Wouldn't that be greater?
Old 02-12-2015, 10:17 AM   #49
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
what do you guys do with this setup on a 08-14 WRX?
i dont believe Perrin makes a 3" inlet for this model. Correct me if I'm wrong.
Old 02-12-2015, 02:28 PM   #50
LittleBlueGT
Member#: 96204
2013 STI GR
Link to said claim?
Do you mean better then stock VF on a stock car, or stock VF tuned with al the bolt-ons?
LittleBlueGT is offline   Reply With Quote
