Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 02-12-2015, 05:12 PM   #51
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by LittleBlueGT View Post
Link to said claim?
Do you mean better then stock VF on a stock car, or stock VF tuned with al the bolt-ons?
You wouldn't call making more peak torque at the same RPM better spool? Or making the same torque at a lower RPM better spool?
Or would you feel better with a statement more along the lines of "makes much more power and spools the same as the VF"?
Would a couple plots tuned before on the VF, and after on the GTX3067, be enough to convince you?
KillerBMotorsport is online now   Reply With Quote
Old 02-12-2015, 05:15 PM   #52
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by gsrcrxsi View Post
what do you guys do with this setup on a 08-14 WRX?
i dont believe Perrin makes a 3" inlet for this model. Correct me if I'm wrong.
We've got a couple guys tackling this. I believe there is a smaller inlet out there (not sure if its Perrin) and then a 3" adapter to the turbo that can be used.
Old 02-12-2015, 06:01 PM   #53
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
Maybe a 3" Perrin and just cap or extend the lines that don't fit this specific model would be a better option. (I think the only difference is the location of the vac line bungs
Perrin does make a stock size inlet for 08-14 WRX, but it's ~3" to 2.4" and 3"->2.4"->3" seems a bit silly.
gsrcrxsi is offline   Reply With Quote
Old 02-12-2015, 08:46 PM   #54
LittleBlueGT
Member#: 96204
2013 STI GR
I don't define it via max boost at X rpm (as that isn't fair if peak boost isn't the same). If I see two plots overlaid that show the 3067 making more power between 2500-3500 rpm then yes I would believe it.
But it is always nice to see a few plots that show such.
I have a turbo that spools about 150 rpm slower then a VF all things being equal. But I can easily show you a plot like this:
Now when you see that you would think it is one of the greatest turbos around. Not even at sea level, and on pump gas! Until I tell you the log was done at -8 temps. (although it was only 3rd gear, 4th would have spooled better).
I would like to see an apples to apples VF to 3067 (with Tial housing) in the same temps, same dyno, same tuner etc....
LittleBlueGT is offline   Reply With Quote
Old 02-12-2015, 10:33 PM   #55
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Same car on pump fuel on an OEM block with the same target boost. Any sane tuner will keep boost ~21 or so, especially when I point to the baby seat in the back and request a safe conservative tune. lol
I don't dare dip into it much blow freezing at low RPMs for fear of spinning a bearing or compressor surge, it's certainly very responsive when the temps are super low, and I'd never want to post any data under those conditions as it's a fairly rare condition and skews results. I'd personally rather skew them in the other direction and have customers that have had their expectations exceeded.
Old 02-12-2015, 10:34 PM   #56
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'll post some plots in the morning
Old 02-12-2015, 10:55 PM   #57
LittleBlueGT
Member#: 96204
2013 STI GR
Looking forward to it!
Old 02-13-2015, 10:18 AM   #58
MazNJ
Member#: 388661
2013 WRX STI 5Dr
Sidenote: In the next few upcoming weeks, I'll provide a hopefully unbiased before and after going from the stocker to the GTX3067 spoolinator... though that obviously would also include TGV deletes and the larger turbo inlet as well so not perfectly apples to apples.
MazNJ is offline   Reply With Quote
Old 02-13-2015, 10:20 AM   #59
Leafy
Member#: 330625
2006 WRX
Install the TGV deletes and larger inlet before the dyno for the stock turbo. You shouldnt have to pull the intake manifold to install the spoolinator.
Leafy is offline   Reply With Quote
Old 04-09-2015, 12:15 PM   #60
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Holy thread neglect!! Spaced this, but I hope to get back to it soon.
You happen to get a VD plot?
Old 04-09-2015, 12:16 PM   #61
MazNJ
Member#: 388661
2013 WRX STI 5Dr
No, I sent a request earlier this week but I'll nudge Prime again.
Old 04-16-2015, 04:14 PM   #62
MazNJ
Member#: 388661
2013 WRX STI 5Dr
Ok, finally got my plot but thinking maybe Prime didn't send me the final one? The spoolinator plot was done on winter wheels while the earlier plot was on my summers, which would contribute to the final number.
Hardware changes (numerous):
Prime-Built shortblock to support kit (king bearings, cp pistons, carillo pro-sa, arp l19 head studs)
IAG fuel rails, aero motive fpr
Gtx3067 spoolinator with .82ar
IAG TGV deletes
IAG air pump delete
IAG AOS swapped in for Crawford AOS
3" turbo inlet swapped in for Perrin
one-step colder plugs
mishimoto radiator
tial mv-s 38mm
cobb xle bpv
supertrapp dump tube muffler
oil went from regular to 15w50
Before: 273/300
http://flic.kr/p/pcE2bN
After: 326/341
http://flic.kr/p/safGpT
Old 04-17-2015, 09:25 AM   #63
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Definitely be better without snows.
Some neat things... Spools sooner and harder, even though the pull was started a bit later. Looks like the plot stopped prematurely, but with the torque dropping slower and HP still climbing at a good rate at the end of the plot, I'd say there were still many more RPMs of power.
The most important thing is how's it feel before/after? Responsive or laggy? Wide power band, or quick and peaky?
Old 04-17-2015, 03:21 PM   #64
Specter86
Member#: 300359
2013 wrx sedan
satin white pearl
That is a sexy smooth transition from turbo to downpipe. Would bang/10
You guys are top notch.
Although I have been saving for your headers for like a year now lol.........sigh...
Specter86 is offline   Reply With Quote
Old 02-07-2020, 05:22 PM   #65
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Just an FYI for everyone. We are changing the Spooinator adapter to make the install MUCH easier, and offering the adapters are a stand-alone part for those that want to fab their own downpipe/exhaust.
