Welcome to the North American Subaru Impreza Owners Club Tuesday February 18, 2020
Old 06-05-2018, 01:34 AM   #26
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
Update 6/4/18
Good news and bad news with this one.
Se the paint is finally done and 3R did a great job with it! I was also able to get a few pics of the new wheels on along with the brakes and a few other goodies. I still kinda miss the green though.
https://i.imgur.com/1l2wsiz.jpg
https://i.imgur.com/qAqk9ok.jpg
https://i.imgur.com/dpJsAfD.jpg
https://i.imgur.com/A3ciE6G.jpg
https://i.imgur.com/GFYb55W.jpg
https://i.imgur.com/zV1bdLn.jpg
https://i.imgur.com/cQyCVpY.jpg
The Fender and hood louvers also came back from powdercoating and just need to be riveted on now.
https://i.imgur.com/FJCFkrs.jpg
https://i.imgur.com/p1zBjgW.jpg
https://i.imgur.com/4z0UkJl.jpg
jellenberg is offline   Reply With Quote
Old 06-05-2018, 01:45 AM   #27
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
We also started getting the new dual master cylinder kit mounted and its almost ready for brake lines. we decided to keep ABS just in case and we're planning on relocating the unit underneath the master cylinders like in the second pic.
https://i.imgur.com/QHizkJE.jpg
https://i.imgur.com/xKG7SCX.jpg
The Kognition wing finally showed up as well so that's pretty cool. this thing is a monster and looks great!
https://i.imgur.com/wXvoMy6.jpg
https://i.imgur.com/D8BEPr3.jpg
Unfortunately that's where the good news and and the bad news begins. Today when the intake manifold came off to put the gaskets in, we noticed rust down in each of the head ports. So the spark plugs came in and we checked the engine with a borescope and found rust in each of the cylinders on the walls and the pistons. So I guess it's time to tear the engine apart and start replacing a rebuilding as necessary. I'm thinking i'll send my case halves to either IAG or Outfront to do a closed deck conversion and maybe some PNP work on the heads to remove the rust.
https://i.imgur.com/cePudZv.jpg
https://i.imgur.com/wcXubvk.jpg
https://i.imgur.com/o88qa75.jpg
https://i.imgur.com/dcvL74q.jpg
Old 06-06-2018, 12:22 AM   #28
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
So am I understanding correctly?
The engine was built about 14 ish months ago, sat around as you did all the fab and such. Now it's full of rust to the point it needs to be torn down?
Scuby04STi is offline   Reply With Quote
Old 06-06-2018, 12:50 AM   #29
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
It's actually been since July 22nd of 2015 if I remember correctly but yes. There's rust everywhere in the cylinders too so we're gonna pop off the heads to check everything out.
Old 06-08-2018, 01:50 AM   #30
dev6565
Member#: 424131
2006 WRX Limited
How'd the rust happen? That doesn't seem right at all.
dev6565 is offline   Reply With Quote
Old 06-08-2018, 03:18 PM   #31
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
I'm not really sure. The only thing I can think of was the brake cleaner I used when I was removing the tape residue before i installed the tgv`s
Old 07-31-2018, 01:05 PM   #32
96accord
Member#: 145105
2007 Impreza WRX STi
'15 Accord (Daily)
Any updates jellenberg?
96accord is offline   Reply With Quote
Old 08-16-2018, 10:55 PM   #33
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
Yes sir! working on it now.
Old 08-16-2018, 11:07 PM   #34
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
Update 8/16/18
Not a ton of progress this time but we finally broke my engine apart to see the carnage from whatever got inside of there. It definitely looks like something was poured into my engine. I feel like if it was environmental, all cylinders would look the same. the bad cylinder even has mold in it.
https://i.imgur.com/pBez9Ys.jpg
https://i.imgur.com/2yKZnvB.jpg
https://i.imgur.com/tRM0Sh4.jpg
https://i.imgur.com/fOY2UjH.jpg
https://i.imgur.com/03moFDy.jpg
But on the Plus side, We started working on the ABS relocation and we have plenty of room to make everything work. The stock ABS pump bracket was cut up a bit and then mounted to the frame rail with some nutserts.
https://i.imgur.com/Jmv1au8.jpg
https://i.imgur.com/p0QseP9.jpg
https://i.imgur.com/qB1n47B.jpg
Old 10-01-2018, 06:23 PM   #35
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
Update - 10/1/18
Alright I guess it's time for another update. Finally got the car on the ground so I was able to see how it sits on the new wheels and its gonna need a bit of adjusting to get things sitting better. But I like it so far.
https://i.imgur.com/5Kg37ux.jpg
https://i.imgur.com/eYXNc5v.jpg
https://i.imgur.com/QQhHZ6x.jpg
I also finally got around to painting my valve covers and coolant crossover pipe with that VHT wrinkle paint and it came out pretty nicely actually. Very close to the wrinkle finish on my powder coated intercooler piping.
https://i.imgur.com/uBnLjkt.jpg
https://i.imgur.com/zMGR1UF.jpg
https://i.imgur.com/eaikgqv.jpg
We also got the Tigwerks AN fittings pressed into my valve covers and Block
https://i.imgur.com/ntzGZpX.jpg
https://i.imgur.com/AMUCnX6.jpg
https://i.imgur.com/657Udh8.jpg
I'll have more pics of the engine in the next few days.
Old 10-15-2018, 08:49 PM   #36
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
Update 10/15/2018
Still plugging away with the build. The brake lines are finally finished and look awesome!
https://i.imgur.com/XI2zNsm.jpg
https://i.imgur.com/q1O72Vt.jpg
https://i.imgur.com/3UZz4VG.jpg
They decided to mount the adjustment knob in a spot that's pretty stealthy. I wouldn't have thought of that, but I like it.
https://i.imgur.com/IWPXAC1.jpg
The new engine is also finally done, the guys at Funk E Built did a great job again. This one got pretty pricy
2.5L closed deck block done locally
OEM Nitrated crank
Manley H-Tuff rods
JE pistons
ACL race bearings
Orbit 12mm oil pump
Killer Bee windage tray
Killer Bee oil pickup tube
PNP heads
GSC S2 cams
Super Tech dual valve springs
Super Tech +1mm valves
Tigwerks AN breather fitting set
Tigwerks AN oil drain fitting
Fluidampr crank pulley
https://i.imgur.com/oNxUK5I.jpg
https://i.imgur.com/MUHIuHm.jpg
https://i.imgur.com/MTaN723.jpg
https://i.imgur.com/u4UcCZr.jpg
https://i.imgur.com/Lr6yMAa.jpg
https://i.imgur.com/11FGVz8.jpg
Old 03-22-2019, 08:57 AM   #37
Scargod
Member#: 260314
2007 STI
silver gray metallic
Any updates on this build? Curious since I am doing one that's similar.
Scargod is offline   Reply With Quote
Old 03-22-2019, 02:32 PM   #38
dev6565
Member#: 424131
2006 WRX Limited
Looks like a really awesome project. Lets get more updates!
Old 04-23-2019, 04:54 PM   #39
RunnyChiliDog
Member#: 478225
2006 WRX STI
Silver Grey Metallic
WOW. Once I get to California im hoping to pull the motor and do some serious tucking and cleaning up. Thank you for the inspiration.
RunnyChiliDog is offline   Reply With Quote
Old 04-24-2019, 04:26 PM   #40
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Nice project.
BlueSTI4Me is offline   Reply With Quote
Old 05-13-2019, 06:28 PM   #41
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
Originally Posted by BlueSTI4Me View Post
Nice project.
Thanks! I'm hoping to get it out of the shop in August and then I'll be able to really start finishing it up quick.
Old 12-17-2019, 07:15 PM   #42
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
Bumping this back from the dead finally. I got my balance aid off with 3R and the car is back in my possession. I didn't waste any time getting to work on it.
I got the Singular Motorsports Louvers all riveted up pretty quickly after getting the frame rails under the fender painted black to hide things better in there.
Then the next most exciting thing was getting the Kogniton wing and Singular Motorsports end plates put on and man did it change the look of the car. The thing is just so massive and insanely sturdy compared to any other wing I have seen. It definitely took a while to install but going slow paid off well. I would do a write up if people are interested in that since the directions from Kognition were not exactly super helpful.
Old 12-17-2019, 07:17 PM   #43
BlueSTI4Me
Member#: 34361
04.7 STI
Yep looking good. Now make up your mind on that engine setup. (saw the for sale post in FB)
Old 12-17-2019, 07:20 PM   #44
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
I also went full idiot and decided to pick up a Process West V Mount intercooler as it would make many things with this build easier as well as be a nice upgrade from my old FMIC setup that would be better suited for Time Attack Racing. I'm planning on flipping the manifold and installing a short runner 2.5i manifold once the funds allow me to pick it up. I can also provide a write up of the install on this as well if people are interested.
Old 12-17-2019, 07:22 PM   #45
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
Man that is the hardest part of this build lol. Hopefully I'll be installing soon the engine and everything else soon. Just gotta build my turbo coolant and oil lines before i put the engine in.
Old 02-11-2020, 04:48 AM   #46
davidsti1
Member#: 210923
2002 Bug-Attack
15 slow STI
Updates?
davidsti1 is offline   Reply With Quote
