Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 09-21-2017, 05:01 PM   #1
03silverbugeye
Member#: 399176
2003 WRX
Default Case Half Dowel Pins
I needed to take out one of the case half alignment dowel pins and in doing so I destroyed the pin. I didn't think twice about it until I found out Subaru doesn't sell them except already installed into a brand new case half. I was wondering if someone could help me out by selling me one or by leading me in the right direction to find one.
Thanks,
Eric
03silverbugeye is offline   Reply With Quote
Old 09-21-2017, 05:04 PM   #2
03silverbugeye
Member#: 399176
2003 WRX
BTW this is off an EJ257 block if that even makes a difference.
Old 09-21-2017, 05:53 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Get a dimension of the pin (diameter and length), then try a place like McMaster-Carr which is an industrial supply house.
Old 09-21-2017, 10:43 PM   #4
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
03 WRB GD 205/22T 20G-XT
Try posting an ad in the WTB classifieds.
monkeyposeur is offline   Reply With Quote
Old 09-21-2017, 11:29 PM   #5
03silverbugeye
Member#: 399176
2003 WRX
I have posted in the WTB already and I know its a 12 mm O.D., I already measured the I.D. and length but I can't even find a 12mm O.D. hollow dowel pin so if I could at least get that I could cut to length and drill out the center to make it fit
Old 09-22-2017, 05:33 AM   #6
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Any chance you could buy an otherwise-damaged case-half, and pull out a dowel pin without damaging it?
I honestly have no idea, but people break motors all the time, so it might not be hard to find a trashed case-half to experiment on. Try any local Subaru shop that does performance work.
I got a couple of connectors removed from trashed wiring harnesses this way, though of course removal was a lot easier in my scenario.
Old 09-22-2017, 07:59 AM   #7
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
flatirons tuning has them
https://www.flatironstuning.com/p-24...dowel-pin.aspx
they have everything. if its not listed then contact them. 99% chance they'll get it for you.
Titter is offline   Reply With Quote
Old 09-22-2017, 12:39 PM   #8
03silverbugeye
Member#: 399176
2003 WRX
That link is for the case to head ones which I need as well but those aren't hard to find, I need the ones that go between the two cases which is not on their website. I did however email Flat Irons Tuning to see if they had any sitting around or could find them for me. I myself actually have 2 sets of cases sitting around that I am not using so I may try this on it, https://forums.nasioc.com/forums/sho...93&postcount=2. I was just trying to see if I could find a new one because then I know for a fact the I.D. and O.D. would be perfect therefore aligning my cases perfectly. Also once I take one out of my old block then when I go to sell that I would need one again.
Old 09-22-2017, 10:33 PM   #9
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
damn my bad, didnt read hard enough.
Old 02-06-2020, 03:45 PM   #10
iKhmaiFoSho
Member#: 494584
Whats the conclusion of the block halve dowel pins? I'm also in need of a pair. I'm rebuilding a ej257 and was wondering if the ej253 SOHC dowel pins will work.
iKhmaiFoSho is offline   Reply With Quote
