Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 07-26-2019, 10:13 PM   #76
james-30
Member#: 430450
2019 STI
Lapis Blue
Originally Posted by pandamaster View Post
Awesome build! Whats the differences you noticed with the bushing upgrades? Also hows the car running with the power your at any issues?
Car is super tight now. Shifting is glass smooth. I dynoed 430whp on a dyno dynamic witch reads super low. Lower then a mustang dyno. So really im around 450-480 whp. Car runs fantastic.
james-30 is offline   Reply With Quote
Old 08-12-2019, 08:28 PM   #77
james-30
Member#: 430450
2019 STI
Lapis Blue
Old 08-14-2019, 12:59 PM   #78
Saturatedfat
Member#: 495781
Awesome build! Might follow on my 19 as well, currently just have the Cobb titanium turboback. I'm thinking just to upgrade the fuel rails, pump, injectors, etc then tune as mine is a daily.
Did you do the fuel parts work yourself? Not sure if I want to deal with the hassle and IAG is actually close to me . Also, how does your car sound with the ELH?
Saturatedfat is offline   Reply With Quote
Old 08-14-2019, 01:27 PM   #79
GravyRobber
Member#: 205568
2017 WRX STi
Thumbs up
Very cool! I've got a similar setup on my '17 with an IAG block, but I'm using an FP Blue turbo. I made 370 on a Dyno Dynamics. Virtual Dynojet said 394 but who knows. Hoping for low-mid 400's on E85 when I decide to do flex fuel. My limiting factor will be my ID1050's and stock fuel lines/regulator.
Love your build, all good stuff.
What is the offset of those wheels? Fitment is perfect.
GravyRobber is offline   Reply With Quote
Old 08-23-2019, 09:53 PM   #80
james-30
Member#: 430450
2019 STI
Lapis Blue
18x9.5 +38, 265/35 tires. I'm lowered abt 2" on FA coilovers, -2.6 camber in the front -1.8 in the rear. My finders are not rolled. No rubbing. I could fit +35 offset if I wanted.
Old 08-23-2019, 09:57 PM   #81
james-30
Member#: 430450
2019 STI
Lapis Blue
I originally started this project thinking I was going to do all the work. I quickly realized I was in way over my head. soooo, I paid a shop to do all the work.
Car sounds amazing with elh, catless down pipe, EWG, and Carven catback.
Old 09-04-2019, 03:03 AM   #82
YoTwizl
Member#: 500121
2019 WRX STI
Lapis Blue
What are the roads like where you are at? Flat, rough, big dips? I have a similar suspension setup with FA500's and my 8k springs are not cutting it on the big dips. I need to get rear control arms so I can get some camber in the back which would probably help a little bit.
YoTwizl is offline   Reply With Quote
Old 10-17-2019, 01:48 AM   #83
08redWRX
Member#: 186068
2019 STi
Just wondering how's the car been doing? How many miles you are on the stock motor with this power.
08redWRX is offline   Reply With Quote
Old 10-26-2019, 07:00 PM   #84
james-30
Member#: 430450
2019 STI
Lapis Blue
My car has around 6k. I dont daily it and only get it out on very nice warm days. Its abt to get cold here in Indiana so car is put away for the winter.
That being said I'm adding a front mount and few other go fast parts and then going for a retune. Hope to hit 500 wheel.
Old 10-26-2019, 09:30 PM   #85
STiSilly
Member#: 502034
2019 WRX STi
Crystal Black Silica
Anyone here maxed out a bonestock 19 sti to the limit?
I was wondering how much more you can get out of the stock turbo with supportin parts...
STiSilly is offline   Reply With Quote
Old 12-07-2019, 03:53 PM   #86
james-30
Member#: 430450
2019 STI
Lapis Blue
Switched to ETS 4" front mount and ETS intake. Also had a custom cover made for her.
Old 12-10-2019, 12:37 AM   #87
siete
Member#: 499183
2019 STI
Sick build. You went with the Carven exhaust as you commented on my thread about exhaust for my 2019. How does it compare with the P&L? What did you do about the other exhaust cutout?
siete is offline   Reply With Quote
Old 12-11-2019, 09:58 AM   #88
Subarudunk
Member#: 179439
2004 STI
JBP
Just curious on how the car is holding up and what kind of mileage you have at this point.
Any oil consumption or other issues?
Subarudunk is offline   Reply With Quote
Old 12-12-2019, 10:23 AM   #89
rtv900
Member#: 428511
2016 STI
^facepalm
rtv900 is offline   Reply With Quote
Old 12-14-2019, 11:51 AM   #90
awd2pt5
Member#: 478704
Originally Posted by rtv900 View Post
^facepalm
agreed.
awd2pt5 is offline   Reply With Quote
Old 12-14-2019, 04:52 PM   #91
james-30
Member#: 430450
2019 STI
Lapis Blue
Car is doing fantastic! Zero oil consumption as I check it most days before driving car. Sitting around 6500 miles. So I have put around 2k miles on current mods. I really feel like my current tune really isn't pushing the stock block much at all, as it takes pull after exhilarating pull with ease. Car pulls like a frggin fright train! I feel factory block has so much more potential. We shall see.
Ditching the factory BOV and installing 50mm Tial as I type. Can't wait to hit the dyno again in Jan.
Old 01-18-2020, 06:39 PM   #92
james-30
Member#: 430450
2019 STI
Lapis Blue
Mod list on first page has been updated. My journey to 500whp on factory block continues Feb 25. Stay tuned for dyno video and final results.
Old 01-19-2020, 12:34 AM   #93
BurninSTI
Member#: 510655
Originally Posted by greygonzalez View Post
19 STI
FP Red @ 21 lbs
1000cc injectors - maxed out so 1300s should be perfect for you
ETS FMIC and Intake
TGV delete
IAG fuel rails
Series custom fuel lines
Aeromotive FPR
Cobb flex fuel
ID fuel filter
Walbro 450 w/ Visconti pump hanger
Car was my daily. Have a RW750 block that I am building to crank the boost up to at least 27lbs - have map already for it
Car rides out and is strong. Tuned by M-Tuned
Follow my build @sti_grey
Stock block and clutch. Going on 3,500 miles on this setup with 8,500 on the car now. We tuned it out of the factory and first tuned 19 Sti
https://youtu.be/jDSdGbAvSY0
What fuel pressure are you running?
BurninSTI is offline   Reply With Quote
Old 01-20-2020, 04:09 AM   #94
james-30
Member#: 430450
2019 STI
Lapis Blue
Switching to a forced performance red or black. My bcp isn’t going to get me 500. Perrin inlet and bcp x500+ turbo now for sale. Both items are like new with zero issues. Make someone a killer deal.
Old 01-20-2020, 11:35 PM   #95
flgavilan2002
Member#: 425491
Following!!!
flgavilan2002 is offline   Reply With Quote
Old 02-02-2020, 12:03 AM   #96
Rivas GVB
Member#: 511292
Did you have any issues fitting the 84mm inlet with the TGV's? I'm having trouble fitting my FP 84mm inlet onto my FP RED using my IAG TGV deletes.
Rivas GVB is offline   Reply With Quote
Old 02-07-2020, 09:13 PM   #97
james-30
Member#: 430450
2019 STI
Lapis Blue
I'm paying a shop to do the work for me. I did ask them abt inlet fitment and was told its a tight fit but fits fine.
Old 02-08-2020, 12:46 AM   #98
subaru_gc8
Member#: 29292
2004 WRX wagon
when the 84mm inlet is on it is pinched alot so yeah it fits but not the best.
subaru_gc8 is online now   Reply With Quote
Old 02-09-2020, 08:09 PM   #99
james-30
Member#: 430450
2019 STI
Lapis Blue
I'm probably going with AMS manifold if this is true. Shop is telling me its tight with factory manifold but fits fine without any major deforming to the inlet.
Old 02-12-2020, 11:04 AM   #100
SubeySTi2011
Member#: 303722
2018 WRX STi type RA
pumped to see the new numbers
SubeySTi2011 is offline   Reply With Quote
