Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 04-07-2019, 05:37 PM   #1
Whitebomb
Member#: 428667
2007 WRX Sdn
Default Barometric sensor malfunctioning
The sensor (attached to the LH secondary air injection valve) is fluctuating readings of atmospheric pressure between 14-18 psi. I plugged in a new sensor and it held nice and steady at 13.9 (this was at a higher elevation fyi). So I am assuming itís not the wiring causing the issue.
Can I clean/refurbish my sensor in any way or is a replacement a must?
Worth noting that valve was stuck open recently and I installed blockoff plates. I donít fully understand if the corrosion in the valve indicates corrosion in the sensor.
Whitebomb is offline   Reply With Quote
Old 04-09-2019, 02:40 PM   #2
07wrxhaweye
Member#: 495306
2007 Wrx Tr
World Rally Blue
Is there any way to check the wiring on these sensors as well? Ive been battling a P0244 code and already replaced the solenoid with a known good one. I have both the Torque app and OBD link app and neither are showing me a baro reading. I'm almost positive its something with the sensor or something in that area cuz thia all started after i changed my starter last year. If anyone can help me with any kind of diagnostics to determine if the sensor is truely bad or if its a wiring issue i would greatly greatly appreciate it.
07wrxhaweye is offline   Reply With Quote
Old 08-13-2019, 01:43 AM   #3
FPV
Member#: 505239
Where did you get the new baro sensor?
FPV is offline   Reply With Quote
Old 02-11-2020, 03:24 PM   #4
08STIER
Member#: 511527
Maybe no one cares, but this looks like a sadly neglected thread. If we really want to get to the bottom of this, we would need to start compiling a set of either voltage values (or resistances) as a function of altitude. Maybe in the manual...
Based on what I see from the diagnosis part of shop manual, the following pins
exist:
1 = should be 4.5 volts or more. The circuit is shared with the electronic
throttle.
2 = Connection to Engine Control Module, should be R >= 1 MOhms, relative to
ground
3 = ground for sensor, should be less than 5 ohms at the harness. This ground
is shared with the MAP, electronic throttle, and coolant temperature
4 = ground to valve solenoid
5 (missing, not used)
6 = power to valve solenoid from control relay
My interpretation is that the barometric pressure sensor is effectively a variable resistor between the ground (pin 3) and pin 1. The barometric pressure sensor (variable resistor) acts as a voltage divider. This is why the Pin 2 is the ECM, engine control module and is likely using pin 2 to measure the voltage...hence the comment that it should be 4.5 volts or higher (dependent on atmospheric pressure). Then pin 2 reports this value in some look up table to modify the engine parameters.
If we want to crowd source this information, we either want a table of
1. resistances between pin 2 and 3 (ground) for various altitude.
2. or turn the key on (engine off)
and measure the voltage at pin 2 with the key on (measured at A27, connector B134 of the ECM).
Any easy way to do this, would be:
A: If anyone who lives in the bay area and wants to go to Lake Tahoe for the weekend, could measure resistances at different altitudes....or
B: If someone has a spare that is good, but has a stuck valve that I can borrow, I could try simulating altitudes with a bicycle pump and convert psi to altitudes. My sensor is bad, so I wouldn't trust the data.
08STIER is offline   Reply With Quote
Old 02-11-2020, 03:58 PM   #5
Haevn
Member#: 495950
2011 WRX
i have a spare off the driver side valve from when i did my air pump delete, had to use the passenger side one and cut the sensor off so i wouldn't have a code
Haevn is offline   Reply With Quote
Old 02-11-2020, 05:08 PM   #6
08STIER
Member#: 511527
Thank you Haevn! PM sent.
Old 02-11-2020, 11:34 PM   #7
Trob
Member#: 503820
You can cut the sensor off the top of you working valve. I deleted my secondary air and we just cut the sensor off the top of the value. Then zip tie and your off.
Trob is offline   Reply With Quote
