Welcome to the North American Subaru Impreza Owners Club Tuesday February 18, 2020
Old 01-15-2020, 07:24 AM   #51
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Default Junkyard Journal | a 1999 RS rescue mission
I got to sit in the 22B at the STi museum when I visited Japan last year. Ever since Iíve been dreaming.
D-Rodman is online now   Reply With Quote
Old 01-15-2020, 11:43 AM   #52
WhiteZombie
Member#: 338863
PSM 05 WRX WGN 5MT
95 Caprice 6spd Track Rat
Thumbs up
Originally Posted by JDMJNKY View Post
I'm far too blessed man. I have nothing, I am nothing, and will return to nothing. Being blessed with a plethora of stuff to pass the time can only beheld with humor.
Thank You. The wife came out after the wash and said, "wow it's pretty. I'd drive that, amazing what a wash can do."
Man, that's a stellar outlook and attitude. Made me smile. I've been feeling a little beaten down by wacky stupid problems but fairly easy fixes on my daily this winter, and I need a little attitude adjustment for sure.
WhiteZombie is offline   Reply With Quote
Old 01-15-2020, 10:57 PM   #53
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Originally Posted by D-Rodman View Post
uploads.tapatalk-cdn.com/20200115/9ba94aeffdb0bfb823e3ccbf550ccddd.jpg[/IMG]://uploads.tapatalk-cdn.com/20200115/580e155dfefda51d132184e78ebaa341.jpg[/IMG]
I got to sit in the 22B at the STi museum when I visited Japan last year. Ever since I’ve been dreaming.
//uploads.tapatalk-cdn.com/20200115/2d08e647d5ddb53600442bfa5efff5cc.jpg[/IMG]
Lucky man, lucky man! Bucket list updated. Ironically, my browser has been open for 3 days paused at 5:23
We all go through it man at some point in life, just glad I could be of assistance .
Picking up where we left off yesterday, more gas. First day on the open road in the books. 62 miles of round trip fun and 1 thumbs up, we are back at home.
Things to sort:
Purchase Denso MAF
Exhaust Gaskets
Compression Test
Tune Up
Find Boost Leak
Rear ride height/Suspension pre-load
Braking (needs pads & rotors)
Alignment/Steering wheel position
Headlight Bulb Retainer
Trade hood or hood scoop
JDMJNKY is offline   Reply With Quote
Old 01-18-2020, 12:43 AM   #54
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
New engine time?? after finding this fouled plug and "0" compression on cylinder 3 I've decided to put it may be time for a new engine vs servicing it. I've spoken to an importer and they have the twin turbo ej20, would anyone happen to know if the LONGBLOCK is plug and play? or will I need to do the usually cam gear swap?
Old 01-18-2020, 03:28 AM   #55
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Sorry to hear that. I guess you donít want an avcs motor. The twin turbo legacy long block is probably going to require swapping the timing parts from your existing motor.
Old 01-18-2020, 05:27 AM   #56
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
I don't, keeping it simple IMO. If it was the EJ257 swap I was going to, then definitely. As you can see I'm up late, reading into all the non-definitive posts regarding the longblock swaps. Some do, some don't, key suggestion was get a tune.
Old 01-18-2020, 09:53 AM   #57
tracknerd
Member#: 53793
02 WRX Wagon
Would you really need to change the cam gears or could you just do the cam sensor trick like:
http://elementtuning.com/techdocs/ej...llation-guide/
tracknerd is offline   Reply With Quote
Old 01-18-2020, 01:13 PM   #58
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
we will see. I plan to go inspect the ej206/8 today.
Old 01-18-2020, 04:47 PM   #59
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Just returned from checking out the two engines, one was ID'd as a phase II and the other a phase III. After some more reading, I've learned the "EJ20TT (ej206/208)" Phase III differs so much so, it is the least likely candidate for a simple 02-03 wrx cross over.
By ID'ing the cylinder heads (on the phase II starting with a B, phase III is H), I have come to understand their cam sprocket is possibly the exact match to the USDM V7 WRX sprocket found in OP's link. Thank goodness the timing cover was cracked on that engine I guess lol.
the drawbacks: increased C/R, which is not a HUGE concern but it is, the need for plugging coolant and oil lines from the LEFT side turbo (marginal cost increase), valve covers are different than the USDM wrx so replacement/service parts may differ (future maintenance stress), and lastly the injectors are side feed vs top (the basic cut and solder will cure that, it's only 2 wires).
BH5A - 8.5:1 Compression - "Phase-II", or V5/6 generation.
BH5B - 8.5:1 Compression - "Phase-II", or V5/6 generation.
Being the "rebuild what you have type," armed with this info. I have a convoluted choice of preference to make. Budget replacement or budget rebuild....ugghhhh
Old 01-18-2020, 11:46 PM   #60
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Why not search for a legit ej205 ?
I realize you are on the other side of the country but check out JDM NY, Iíve visited their warehouse few times, they have a lot of ej205 motors for $900
Their website does not show all the motors they have in stock, itís best to call them. Iím planing on buying a motor from them in the spring when I resume working on my bugeye.
Old 01-19-2020, 01:03 AM   #61
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Well nothing is proper. Between both options IM, cam, and crank sprockets must be changed. The cost justifies the means if one was buying an EJ20TT. In the $900 range I can buy all the parts needed for an aftermarket OE rebuild. I was just trying to be mr.simple for once, but itís not working. I have the cart loaded for my mondaysí click n ship jic - 48hrs to make up my mind ��.
Old 01-19-2020, 09:38 PM   #62
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Gotcha, decisions decisions.
Old 01-21-2020, 03:48 PM   #63
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
indeed. had some phone with the iPhone and tried to make some youtube content. I've officially named her "faye." I'll expand on that overtime. As for the build one more video will go up tomorrow talking about the ISB failure for the 5spd.
Old 01-22-2020, 01:30 PM   #64
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
PT.II is up w/ leak down results. One more vid and it's back to pics until we stir up some new content. Trying to get my boys at the shop involved.
Old 01-22-2020, 09:44 PM   #65
kaos200
Member#: 2692
Sub'd
kaos200 is offline   Reply With Quote
Old 01-26-2020, 10:48 AM   #66
D-Rodman
Member#: 110078
05 Saabaru JDM STi
I like the vids, keep making them.
Old 01-28-2020, 03:13 PM   #67
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Thanks Gents. a Video covering ISB failure is up. I'll be posting some pics tonight/tomorrow.
Old 01-29-2020, 01:12 PM   #68
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Something about images just resonates with me. Due to that fact, not sure if I'll keep doing videos & post. It's nearly 3/4x the work, only time will tell. As of right now, let's just enjoy the journey.
Engine Removal - ď0Ē compression cylinder 3.
Disassembly - after hearing air hissing out the turbo on the leak down test, I began taking apart the RH head
I also noted timing had moved and belt tension was extremely sloppy. Even though the tensioner was strong it would move as if it were seized and suddenly freed up. While checking everything I noticed the broken rear tooth on the cam gear. Is this from being pried off?
this cam cap bolt was seized. after cutting a grove wide enough for an impact driver I was finally able to get it out.
AAA to the rescue, back home she goes until I can sort the heads.
Old 01-29-2020, 01:12 PM   #69
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Gave the heads a quick rinse; not a fan of greasy / oil saturated parts when preforming cast cleaning.
To avoid going apes, but still wanting to improve the situation, I set out to clean some cast flaws, and blend some bowls. I would not be going all out as I did with my B25 Heads.
Old 01-29-2020, 01:13 PM   #70
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
another bath
I find the infamous crack I didn’t see earlier
somewhere in the timeline I began “porting the TB & IM runners.” In the name of efficiency I do these things, I swear.
a member on FB was kind enough to donate these to the repair
more cleaning, pete peeves I tell ya! I’m plagued with them.
Old 01-29-2020, 01:13 PM   #71
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Then this deal reared its head. I couldnít pass it up as I plan to BAR both this car and my bugeye. 200 miles huh? I say give or take 1000. Let's be frank, some sellers like to hype up sales.
Old 01-29-2020, 04:53 PM   #72
Fndragn
Member#: 470845
2011 Sti
I like the pixs, the videos are definitely good also. On that note I love this car! I’ve been looking for one since the first day you posted about it. I can’t find anything here in the Midwest. This is the best build thread on nasioc right now. Keep it up!
Fndragn is offline   Reply With Quote
Old 01-29-2020, 05:11 PM   #73
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
+1 for pics because I only browse Nasioc at work and my work blocks youtube
master c is offline   Reply With Quote
Old 01-30-2020, 01:56 AM   #74
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Those cracks on the spark plug holes are not a problem ?
Old 01-30-2020, 02:28 AM   #75
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Originally Posted by Fndragn View Post
I like the pixs, the videos are definitely good also. On that note I love this car! Iíve been looking for one since the first day you posted about it. I canít find anything here in the Midwest. This is the best build thread on nasioc right now. Keep it up!
Feedback appreciated man, but there are some sicker builds going down on this forum. I definitely hope you find one. There are some gems out there to be had. I'd love to find an unmolested stock one for a sweet deal, but I'm happy with this one if I don't.
haha....well hopefully by the end of the week I'll have some more work footage for you.
They are a problem, in fact a common one. Will I be addressing it now? no sir. In the back of my mind I've already committed to doing a full 05 sti swap. This a "run what you brung" journal for now.
