Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 01-29-2020, 11:38 AM   #1
paytonzellers
Member#: 503104
Default AF Learning and Bad Gas Mileage
Stupid question, I have a 2013 Wrx, only mods are Cobb SF Intake, N1 catback, and Accessport V3. Currently running OTS Stage 1+SF 91 OCT, and use 93 gas from exxon. My AF Learning numbers are (-3.91,4.18) and AF correction 1 is (-21,14) normally. I am only getting around 14-16 mpg and drive pretty conservative. I let it warm up about 5 minutes, and my commute is about 15 minutes to work. Would this be caused by a boost leak? Or possibly a bad front O2 sensor? Any help would be appreciated. If needed I have data logs of 2 3rd gear pulls.
paytonzellers is offline   Reply With Quote
Old 02-03-2020, 10:25 PM   #2
BurninSTI
Member#: 510655
I'm dealing with AF issues now... how many miles on the car?
BurninSTI is offline   Reply With Quote
Old 02-03-2020, 11:59 PM   #3
paytonzellers
Member#: 503104
88k as of tomorrow most likely
Old 02-04-2020, 09:05 AM   #4
BurninSTI
Member#: 510655
Post or send me the logs, Ill take a look.
Old 02-04-2020, 10:45 PM   #5
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Check your turbo inlet for tears.
Scorpius is offline   Reply With Quote
Old 02-04-2020, 11:12 PM   #6
Jersey Man10
Member#: 427632
2011 Impreza WRX
Satin White Pearl
Custom tune would help since ots tunes are meh. MAF sensor might need replacing. In all honesty its probably the intake causing problems. Try switching back to stock and see what results you get.
Jersey Man10 is offline   Reply With Quote
Old 02-05-2020, 06:30 PM   #7
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
I'm guessing since it's running so rich it's getting unmetered air after the maf somewhere.
Old 02-06-2020, 02:27 PM   #8
BurninSTI
Member#: 510655
Is it dripping gas while idling?
