Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 02-02-2020, 12:12 AM   #1
Rivas GVB
Member#: 511292
Default FP RED 84mm Inlet fitment issues with IAG TGV deletes.
Hello. Has anyone ran into fitment issues running a big inlet FP Turbo using their 84mm inlet? I attempted to use my IAG TGV deletes but no success. Any ideas or past fixes, besides going rotated? Thanks in advance.
Rivas GVB is offline   Reply With Quote
Old 02-07-2020, 09:46 AM   #2
Wfosti35
Member#: 411914
2004 Sti
Default Same
I have an 04 sti that I want to use same set up on. I hope someone can confirm.
Wfosti35 is offline   Reply With Quote
Old 02-07-2020, 09:56 AM   #3
mikeydrives1
Member#: 262117
2001 Forester STI
MKtuned
Even using some Phenolic spacers, its a TIGHT fit for that sized inlet with the FP Black / Red.
8MM spacers should do the trick.
mikeydrives1 is offline   Reply With Quote
Old 02-09-2020, 08:13 PM   #4
james-30
Member#: 430450
2019 STI
Lapis Blue
FP inlet is only 3.3" That being said 3" inlet is a very popular inlet on the ej platform. Lots of people run FP inlet with no issue. Yes, its tight but you shouldn't need spacers. I personally would not trust spacers. Go with a modded long runner factory manifold or AMS.
james-30 is offline   Reply With Quote
Old 02-10-2020, 03:16 AM   #5
Rivas GVB
Member#: 511292
I was looking into the Long Runner intake manifold off a 2.5i Forester and found them to be pretty inexpensive brand new at the dealership. The only issue i have is now I have to convert to a FMIC set up and find someone to fab up the piping.
Old 02-11-2020, 09:01 AM   #6
Brother EddieJ.
Member#: 181617
2004 wrx
Dom3/IAG built hybrid
Ks-tech on eBay sells a 3” to 84mm coupler that is said to be designed for the fp 84mm turbo inlets. I talked to fp and they said it should work but you might not get as much whistle sound (t51r mod sound). This is the route I’m going to try and go. I have the coupler and fp black, just waiting on a few more parts.
His eBay name is kstech*store
Brother EddieJ. is offline   Reply With Quote
Old 02-12-2020, 10:14 AM   #7
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
I had a FP green HTZ with a anti surge compression housing that was 84mm on my 04 STi. I had 8mm spacers and it still was a very tight fit with the silicone coupler. Its doable but a PITA. You can see in the pic, i used a APS hard inlet too.
https://i.imgur.com/AQmEvDu.jpg
https://i.imgur.com/EZJ8P68.jpg
BlackFighter is online now   Reply With Quote
Old Yesterday, 09:34 AM   #8
Boxer112
Member#: 78751
2017 Sti
ISM
I used Spacers on my FP Red with FP inlet. Fits perfectly with no issues.
Boxer112 is offline   Reply With Quote
