Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 02-05-2020, 12:26 AM   #1
SlowCB7
Member#: 343576
2005 Saab 9-2x Aero
Default Proper Cams for EJ25 swap into 05 WRX
I'm getting ready to buy camshafts for the built 2.5 I'm putting in my Saabaru (identical to 05 WRX). I'm not running AVCS, and I've read that the AVCS cams have the incorrect centerline for the non-AVCS timing setup. Is this something that can be remedied with adjustable cam gears and blocking off the oil ports? Or is that a copout, and I should just buy cams made for an EJ205 and use the cam gears that came off my EJ205? Thanks for any input. Also, I'm assuming I still need the feed lines to the AVCS ports in the heads to maintain oil flow to those cam journals, even if I'm running non AVCS cams, correct?
SlowCB7 is offline   Reply With Quote
Old 02-05-2020, 12:58 AM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
why did ou need to buy cams? what turbo are you going to us?
subaru_gc8 is offline   Reply With Quote
Old 02-05-2020, 07:08 AM   #3
SlowCB7
Member#: 343576
2005 Saab 9-2x Aero
I've already got everything else, I'm using a Borg Warner S200SXE
Old 02-05-2020, 09:49 PM   #4
motorbykemike
Member#: 273868
ok , i'll add
cool cars
correct
yes, well kinda , but with some sneaky surprises so why?
now you're talking , you can use your 205 cams as well , even just the intakes , use cam seals for whatever cams you use
correct and depending on the heads you are using you may need to get a bracket to hold the cam trigger behind the left intake gear
motorbykemike is offline   Reply With Quote
Old 02-06-2020, 03:31 PM   #5
SlowCB7
Member#: 343576
2005 Saab 9-2x Aero
Awesome, thanks a ton. That's exactly what I was hoping for
