Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 02-06-2020, 08:34 PM   #1
edsuusde
Member#: 479436
2012 STi HB
Default Rattling/creaking noise when going over bumpy road or going over bump unevenly.
I searched most of the posts already, didn't exactly find anything that matches my case. I am sorry if I post this to the wrong forum.
My 12 STI hatchback is pretty much stock. It only has the cobb intake and kartboy shifter and bushings.
The noise happen in the following scenarios:
1. when i go over speed bump unevenly at low speed (like left wheel goes on first, then right wheel. Rear left, then rear right). Every time i hear the creaking/squeaking (like the old mattress springs noise). The noise does NOT happen When both wheels go on the speed bump at the same time.
2. It also happen when I drive over bumpy road.
3. After driving like 20 minutes (after work), and turning the engine off, i can hear some rattling (or similar to the noise from #1) 0.5-1 second after the engine completely stop. To me, it feels like exhaust heat shield rattle, but i checked the heat shield from the down pipe already, it's tight. I also checked the exhaust manifold heat shield, it's also tight.) I am not sure if this is the same noise in #1, but it sounds like they are same to me.
the noise does NOT happen at all in normal driving on smooth enough road, accelerating, breaking, changing gears, cornering.
Could you please throw me some ideas? I really appreciate for all the help in advance.
edsuusde is offline   Reply With Quote
Old 02-07-2020, 11:19 AM   #2
shadowsports
Member#: 446364
'17 STI LMT '08 LGT
DGM / QSM
Greetings,
Tell us more about your suspension. When was the last time you changed your struts/shocks? What condition are your undercarriage bushing in? All if these things work together.
shadowsports is offline   Reply With Quote
Old 02-07-2020, 01:27 PM   #3
edsuusde
Member#: 479436
2012 STi HB
Stock suspension, never touched them. I am not sure what undercarriage bushing condition is, I never touched them either. They are all stock.
Old 02-07-2020, 03:11 PM   #4
AgentScarn
Member#: 477230
2007 Impreza WRX STI
UGM
Maybe your strut/shocks, sway bar bushings?
AgentScarn is online now   Reply With Quote
Old 02-07-2020, 05:56 PM   #5
edsuusde
Member#: 479436
2012 STi HB
I checked the sway bar bushing, and endlinks, they are tight.
If swaybar bushing or endlinks, it should make noise when both wheels get on speed bump at the same time. But mine doesn't, it only happen when you go over the bump at an angle (like going over the bump one wheel at a time)
what do i need to check on the struts?
Old 02-07-2020, 06:46 PM   #6
AgentScarn
Member#: 477230
UGM
Your sway bar bushing may be secure, but they need to be re-greased from time to time. I'm not sure how you would be able to check your struts. Mine would make a loud clunking sound over harsh bumps.
Old 02-11-2020, 05:40 PM   #7
edsuusde
Member#: 479436
2012 STi HB
if to re-grease the swaybar bushing, should i take them off and re-grease? I did try to spray some WD40 on them. It didn't help.
